A baseband signal m(t) that has a Gaussian (amplitude) distribution frequency modulates a transmitter. Assume that the modulation has a zero-mean value and a peak value of Vp = 4*(sigma). The FM signal is transmitted over an additive white Gaussian noise channel. Let Beta = 3 and B = 15KHz. Find (S/N)out/(S/N)baseband when: A. No deemphasis is used. B. 75-u sec deemphasis is used. Again I desperately need help with this problem too. I would appreciate any help.
Other Modulation Problem
Started by ●March 31, 2004
Reply by ●April 1, 20042004-04-01
Texas Longhorns wrote:> A baseband signal m(t) that has a Gaussian (amplitude) distribution > frequency modulates a transmitter. Assume that the modulation has a > zero-mean value and a peak value of Vp = 4*(sigma). The FM signal is > transmitted over an additive white Gaussian noise channel. Let Beta = > 3 and B = 15KHz. Find (S/N)out/(S/N)baseband when: > > A. No deemphasis is used. > B. 75-u sec deemphasis is used. > > Again I desperately need help with this problem too. I would > appreciate any help.How do you hope to learn if you get other people to do your homework for you? Carlos
