Phase rotation
Started by cpshah99 October 2, 2008
On Oct 2, 1:10&#4294967295;pm, "cpshah99" <cpsha...@rediffmail.com> wrote:
> >On Oct 2, 12:27=A0pm, "cpshah99" <cpsha...@rediffmail.com> wrote: > >> >On Oct 2, 11:31=3DA0am, "cpshah99" <cpsha...@rediffmail.com> wrote: > >> >> >On Oct 2, 8:50=3D3DA0am, julius <juli...@gmail.com> wrote: > >> >> >> On Oct 2, 8:38 am, John <sampson...@gmail.com> wrote: > > >> >> >> > For the simple case, just multiply your transmitted signal by > >> >> exp(jwt) > >> >> >> > where w is the Doppler offset frequency (rad/sec). > > >> >> >> > John > > >> >> >> That's correct for baseband. =3D3DA0For passband it's a bit more > >> involve=3D > >> >d, > >> >> >> what > >> >> >> is needed is a frequency shift of a real-valued signal. > =3D3DA0It's > >> >> >> sufficient to use > >> >> >> a real-valued mixer and a filter to reject the extraneous images > in > >> >> >> the > >> >> >> frequency domain. > > >> >> >> Julius > > >> >> >You are correct, but I think the OP specified phase rotation at > >> >> >baseband anyway. > > >> >> >John > > >> >> %%%% > > >> >> Hello > > >> >> Thanks a lot John and Julius. > > >> >> I would like to read more about this topic. Can u please suggest > any > >> >> starting point. > > >> >> One day julius had said, synchronisation is really tough topic...i > >> have > >> >> realised that....so I am going step by step....first phase > >> synchronisatio=3D > >> >n > >> >> and then time synchronisation..... > > >> >> and in the abover eqn exp(jwt), how i put value of 't', i knw it is > >> silly > >> >> que but please tell me. > > >> >> Thanks a lot. > > >> >> Regards, > > >> >> Chintan > > >> >t is a time vector. It goes from 0 to your last sample instant, with > a > >> >spacing of one over your sample rate. > > >> >For example, in Matlab you could do this: > > >> >Fs=3D3D1e6; > >> >w=3D3D2*pi*1e3; > >> >t=3D3D[0:Fs-1]/Fs; > >> >osc=3D3Dexp(j*w*t); > > >> >John > > >> %%%% > > >> Hi John > > >> Thanks a lot. > > >> But I am just using one sample per symbol. > > >> so if my tx signal is 100 symbols then > > t=3D[0:length(msg-1)]./length(msg) > > > > >> is that correct? > > >Not quite. the -1 should be outside the parens (typo?). The > >denominator should equal the sample rate ( same as symbol rate in your > >case). > > >John > > %%%% > > Sorry for the typo. for my qpsk modulation, is this correct: > > msg=(sign(randn(1,100))+j*sign(randn(1,100)))/sqrt(2); % qpsk symbols > t=[0:length(msg)-1]./100; > op=msg.*exp(2*pi*1*t); % doppler of 1 Hz > > and how do I do for multipath channels, i.e. multipath and also all the > path has got phase rotation. > > I can apply individual phase rotation and after adding proper delay, add > them together.
Depends on your sampling rate.... and you're missing a 'j' like John said.
>On Oct 2, 1:10=A0pm, "cpshah99" <cpsha...@rediffmail.com> wrote: >> >On Oct 2, 12:27=3DA0pm, "cpshah99" <cpsha...@rediffmail.com> wrote: >> >> >On Oct 2, 11:31=3D3DA0am, "cpshah99" <cpsha...@rediffmail.com>
wrote:
>> >> >> >On Oct 2, 8:50=3D3D3DA0am, julius <juli...@gmail.com> wrote: >> >> >> >> On Oct 2, 8:38 am, John <sampson...@gmail.com> wrote: >> >> >> >> >> > For the simple case, just multiply your transmitted signal
by
>> >> >> exp(jwt) >> >> >> >> > where w is the Doppler offset frequency (rad/sec). >> >> >> >> >> > John >> >> >> >> >> That's correct for baseband. =3D3D3DA0For passband it's a bit
mo=
>re >> >> involve=3D3D >> >> >d, >> >> >> >> what >> >> >> >> is needed is a frequency shift of a real-valued signal. >> =3D3D3DA0It's >> >> >> >> sufficient to use >> >> >> >> a real-valued mixer and a filter to reject the extraneous
images
>> in >> >> >> >> the >> >> >> >> frequency domain. >> >> >> >> >> Julius >> >> >> >> >You are correct, but I think the OP specified phase rotation at >> >> >> >baseband anyway. >> >> >> >> >John >> >> >> >> %%%% >> >> >> >> Hello >> >> >> >> Thanks a lot John and Julius. >> >> >> >> I would like to read more about this topic. Can u please suggest >> any >> >> >> starting point. >> >> >> >> One day julius had said, synchronisation is really tough
topic...i
>> >> have >> >> >> realised that....so I am going step by step....first phase >> >> synchronisatio=3D3D >> >> >n >> >> >> and then time synchronisation..... >> >> >> >> and in the abover eqn exp(jwt), how i put value of 't', i knw it
is
>> >> silly >> >> >> que but please tell me. >> >> >> >> Thanks a lot. >> >> >> >> Regards, >> >> >> >> Chintan >> >> >> >t is a time vector. It goes from 0 to your last sample instant,
with
>> a >> >> >spacing of one over your sample rate. >> >> >> >For example, in Matlab you could do this: >> >> >> >Fs=3D3D3D1e6; >> >> >w=3D3D3D2*pi*1e3; >> >> >t=3D3D3D[0:Fs-1]/Fs; >> >> >osc=3D3D3Dexp(j*w*t); >> >> >> >John >> >> >> %%%% >> >> >> Hi John >> >> >> Thanks a lot. >> >> >> But I am just using one sample per symbol. >> >> >> so if my tx signal is 100 symbols then >> >> t=3D3D[0:length(msg-1)]./length(msg) >> >> >> >> >> is that correct? >> >> >Not quite. the -1 should be outside the parens (typo?). The >> >denominator should equal the sample rate ( same as symbol rate in
your
>> >case). >> >> >John >> >> %%%% >> >> Sorry for the typo. for my qpsk modulation, is this correct: >> >> msg=3D(sign(randn(1,100))+j*sign(randn(1,100)))/sqrt(2); % qpsk
symbols
>> t=3D[0:length(msg)-1]./100; >> op=3Dmsg.*exp(2*pi*1*t); % doppler of 1 Hz >> >> and how do I do for multipath channels, i.e. multipath and also all
the
>> path has got phase rotation. >> >> I can apply individual phase rotation and after adding proper delay,
add
>> them together. > >Depends on your sampling rate.... and you're missing a 'j' like John >said. >
%%%%%% I am sorry...i missed that 'j'...... and if u can explain abt what depends on sampling rate? thanks...
On Oct 2, 3:29&#4294967295;pm, "cpshah99" <cpsha...@rediffmail.com> wrote:
> >On Oct 2, 1:10=A0pm, "cpshah99" <cpsha...@rediffmail.com> wrote: > >> >On Oct 2, 12:27=3DA0pm, "cpshah99" <cpsha...@rediffmail.com> wrote: > >> >> >On Oct 2, 11:31=3D3DA0am, "cpshah99" <cpsha...@rediffmail.com> > wrote: > >> >> >> >On Oct 2, 8:50=3D3D3DA0am, julius <juli...@gmail.com> wrote: > >> >> >> >> On Oct 2, 8:38 am, John <sampson...@gmail.com> wrote: > > >> >> >> >> > For the simple case, just multiply your transmitted signal > by > >> >> >> exp(jwt) > >> >> >> >> > where w is the Doppler offset frequency (rad/sec). > > >> >> >> >> > John > > >> >> >> >> That's correct for baseband. =3D3D3DA0For passband it's a bit > mo= > >re > >> >> involve=3D3D > >> >> >d, > >> >> >> >> what > >> >> >> >> is needed is a frequency shift of a real-valued signal. > >> =3D3D3DA0It's > >> >> >> >> sufficient to use > >> >> >> >> a real-valued mixer and a filter to reject the extraneous > images > >> in > >> >> >> >> the > >> >> >> >> frequency domain. > > >> >> >> >> Julius > > >> >> >> >You are correct, but I think the OP specified phase rotation at > >> >> >> >baseband anyway. > > >> >> >> >John > > >> >> >> %%%% > > >> >> >> Hello > > >> >> >> Thanks a lot John and Julius. > > >> >> >> I would like to read more about this topic. Can u please suggest > >> any > >> >> >> starting point. > > >> >> >> One day julius had said, synchronisation is really tough > topic...i > >> >> have > >> >> >> realised that....so I am going step by step....first phase > >> >> synchronisatio=3D3D > >> >> >n > >> >> >> and then time synchronisation..... > > >> >> >> and in the abover eqn exp(jwt), how i put value of 't', i knw it > is > >> >> silly > >> >> >> que but please tell me. > > >> >> >> Thanks a lot. > > >> >> >> Regards, > > >> >> >> Chintan > > >> >> >t is a time vector. It goes from 0 to your last sample instant, > with > >> a > >> >> >spacing of one over your sample rate. > > >> >> >For example, in Matlab you could do this: > > >> >> >Fs=3D3D3D1e6; > >> >> >w=3D3D3D2*pi*1e3; > >> >> >t=3D3D3D[0:Fs-1]/Fs; > >> >> >osc=3D3D3Dexp(j*w*t); > > >> >> >John > > >> >> %%%% > > >> >> Hi John > > >> >> Thanks a lot. > > >> >> But I am just using one sample per symbol. > > >> >> so if my tx signal is 100 symbols then > > >> t=3D3D[0:length(msg-1)]./length(msg) > > >> >> is that correct? > > >> >Not quite. the -1 should be outside the parens (typo?). The > >> >denominator should equal the sample rate ( same as symbol rate in > your > >> >case). > > >> >John > > >> %%%% > > >> Sorry for the typo. for my qpsk modulation, is this correct: > > >> msg=3D(sign(randn(1,100))+j*sign(randn(1,100)))/sqrt(2); % qpsk > symbols > >> t=3D[0:length(msg)-1]./100; > >> op=3Dmsg.*exp(2*pi*1*t); % doppler of 1 Hz > > >> and how do I do for multipath channels, i.e. multipath and also all > the > >> path has got phase rotation. > > >> I can apply individual phase rotation and after adding proper delay, > add > >> them together. > > >Depends on your sampling rate.... and you're missing a 'j' like John > >said. > > %%%%%% > > I am sorry...i missed that 'j'...... > > and if u can explain abt what depends on sampling rate? > > thanks...
Sigh. The phase increment of the complex oscillator depends on the sample rate (Fs). For a one Hz Doppler, you want rotation of 2*pi radians per second. Therefore the phase increment is 2*pi/Fs and the phase vector is 2*pi*[0,1,2,...]/Fs. John
>Sigh. The phase increment of the complex oscillator depends on the >sample rate (Fs). For a one Hz Doppler, you want rotation of 2*pi >radians per second. Therefore the phase increment is 2*pi/Fs and the >phase vector is 2*pi*[0,1,2,...]/Fs. > >John >
%%% Hi John Thanks a lot. One last favour. Can u suggest me some good book on this or something where i can read abt this?
On Oct 3, 5:53&#4294967295;am, "cpshah99" <cpsha...@rediffmail.com> wrote:
> >Sigh. The phase increment of the complex oscillator depends on the > >sample rate (Fs). For a one Hz Doppler, you want rotation of 2*pi > >radians per second. Therefore the phase increment is 2*pi/Fs and the > >phase vector is 2*pi*[0,1,2,...]/Fs. > > >John > > %%% > > Hi John > > Thanks a lot. > > One last favour. Can u suggest me some good book on this or something > where i can read abt this?
I don't know of a specific reference. Any introductory DSP book should give you enough background to understand how to generate sines and cosines. John
