Guys, I am making an FFT of a sin() wave from a signal generator (a few tens of Hz) with a sampling rate of 2500/sec. my FFT size is 8192 or 16384. In either case I observe harmonics with multiples of the sine frequency with decreasing amplitude. I assume that the discrete FFT will create such artifacts, but how can I tell how much of these are real (my signal generator in principle may also have some harmonics)? Thanks Peter
FFT harmonics question
Started by ●October 15, 2008
Reply by ●October 15, 20082008-10-15
"Peter123" <pr20@cornell.edu> writes:> Guys, I am making an FFT of a sin() wave from a signal generator (a few > tens of Hz) with a sampling rate of 2500/sec. my FFT size is 8192 or > 16384. > In either case I observe harmonics with multiples of the sine frequency > with decreasing amplitude. I assume that the discrete FFT will create such > artifacts, but how can I tell how much of these are real (my signal > generator in principle may also have some harmonics)?Hi Peter, The FFT won't produce "harmonics". Those must be from your signal generator. What the FFT will do (potentially) is smear your nice spectral lines, but it doesn't produce harmonics. -- % Randy Yates % "...the answer lies within your soul %% Fuquay-Varina, NC % 'cause no one knows which side %%% 919-577-9882 % the coin will fall." %%%% <yates@ieee.org> % 'Big Wheels', *Out of the Blue*, ELO http://www.digitalsignallabs.com
On 15 Okt., 14:40, Randy Yates <ya...@ieee.org> wrote:> "Peter123" <p...@cornell.edu> writes: > > Guys, I am making an FFT of a sin() wave from a signal generator (a few > > tens of Hz) �with a sampling rate of 2500/sec. my FFT size is 8192 or > > 16384. > > In either case I observe harmonics with multiples of the sine frequency > > with decreasing amplitude. I assume that the discrete FFT will create such > > artifacts, but how can I tell how much of these are real (my signal > > generator in principle may also have some harmonics)? > > Hi Peter, > > The FFT won't produce "harmonics". Those must be from your signal > generator. What the FFT will do (potentially) is smear your nice > spectral lines, but it doesn't produce harmonics.Agreed. A typical problem is fixed-point signal generators that don't dither. Regards, Andor
In article <EIydnSUp6-UtQmjVnZ2dnUVZ_hadnZ2d@giganews.com>, "Peter123" <pr20@cornell.edu> wrote:> Guys, I am making an FFT of a sin() wave from a signal generator (afewtens of Hz) with a sampling rate of 2500/sec. my FFT size is 8192 or16384.> In either case I observe harmonics with multiples of the sinefrequencywith decreasing amplitude. I assume that the discrete FFT will create suchartifacts, but how can I tell how much of these are real (my signalgenerator in principle may also have some harmonics)? Are you windowing the input before applying the FFT?
On 15 Okt, 14:18, "Peter123" <p...@cornell.edu> wrote:> Guys, I am making an FFT of a sin() wave from a signal generator (a few > tens of Hz) �with a sampling rate of 2500/sec. my FFT size is 8192 or > 16384. > In either case I observe harmonics with multiples of the sine frequency > with decreasing amplitude. I assume that the discrete FFT will create such > artifacts, but how can I tell how much of these are real (my signal > generator in principle may also have some harmonics)?Unless you compute the FFT using a fixed-point number format with the signal scaled to just a few bits of dynamic range, the harmonics are caused by the signal generator. To check this, make sure you use a floating-point number format when you compute the FFT. As for causes of the harmonics, there might be stability issues with the signal generator or fixed-point quantization issues with the ADC. Rune
On Oct 15, 8:18�am, "Peter123" <p...@cornell.edu> wrote:> Guys, I am making an FFT of a sin() wave from a signal generator (a few > tens of Hz) �with a sampling rate of 2500/sec. my FFT size is 8192 or > 16384. > In either case I observe harmonics with multiples of the sine frequency > with decreasing amplitude. I assume that the discrete FFT will create such > artifacts, but how can I tell how much of these are real (my signal > generator in principle may also have some harmonics)? > > �Thanks > � � PeterIs the fundamental frequency exactly where you expect it to be? Are the higher harmonics really at (not sort of at) multiples of the expected fundamanetal frequency? Is there an integer number of periods of the waveform within the the FFT duration? Dirk
>On Oct 15, 8:18=A0am, "Peter123" <p...@cornell.edu> wrote: >> Guys, I am making an FFT of a sin() wave from a signal generator (afew>> tens of Hz) =A0with a sampling rate of 2500/sec. my FFT size is 8192or>> 16384. >> In either case I observe harmonics with multiples of the sinefrequency>> with decreasing amplitude. I assume that the discrete FFT will createsuc=>h >> artifacts, but how can I tell how much of these are real (my signal >> generator in principle may also have some harmonics)? >> >> =A0Thanks >> =A0 =A0 Peter > >Is the fundamental frequency exactly where you expect it to be? Are >the higher harmonics really at (not sort of at) multiples of the >expected fundamanetal frequency? > >Is there an integer number of periods of the waveform within the the >FFT duration? > >Dirk >Thank you guys all the answers. (1) I am doing FFT on double values. (2) BUT: I have checked the periodigram with an internally generated generated sin() wave and there was no harmonics - as you all predicted. (3) So it is indeed my lousy function generator. (a TENMA 72-6644) Maybe it is because it can also generate other waveforms (square, sawtooth, etc) and that could bleed in a bit... (???) Peter
Peter123 wrote:> Guys, I am making an FFT of a sin() wave from a signal generator (a few > tens of Hz) with a sampling rate of 2500/sec. my FFT size is 8192 or > 16384. > In either case I observe harmonics with multiples of the sine frequency > with decreasing amplitude. I assume that the discrete FFT will create such > artifacts, but how can I tell how much of these are real (my signal > generator in principle may also have some harmonics)? > > Thanks > PeterAs stated, the FFT doesn't 'generate' harmonics when done properly. It's much more likely in your generator or your signal acquisition. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
Peter123 wrote: ...> (3) So it is indeed my lousy function generator. (a TENMA 72-6644) > Maybe it is because it can also generate other waveforms (square, > sawtooth, etc) and that could bleed in a bit... (???)Probably not crosstalk. More likely, an artifact of the sine generation technique. Is there a purity (distortion) spec for the instrument? Jerry -- Engineering is the art of making what you want from things you can get. ����������������������������������������������������������������������� ** Posted from http://www.teranews.com **
dbell wrote:> On Oct 15, 8:18 am, "Peter123" <p...@cornell.edu> wrote:>>Guys, I am making an FFT of a sin() wave from a signal generator (a few >>tens of Hz) with a sampling rate of 2500/sec. my FFT size is 8192 or >>16384.>>In either case I observe harmonics with multiples of the sine frequency >>with decreasing amplitude. I assume that the discrete FFT will create such >>artifacts, but how can I tell how much of these are real (my signal >>generator in principle may also have some harmonics)?(snip)> Is there an integer number of periods of the waveform within the the > FFT duration?You didn't answer this one. Unless you phase lock the sampling frequency to the generator, or the other way around, it is very unlikely that you have an integer number of periods in the FFT. If not, you will see exactly what you say you get. -- glen
