I have a confusion here. So please help. I have a message signal given as : m(t) = 0.5 cos(wt) + 0.3 sin (2wt) I also have a carrier signal whose amplitude is known. and now i want to calculate the modulation index. which is given as amplitude of message signal divided by amplitude of carrier. (Remember that i am doing AM.) The confusion is that: Does the amplitude of message signal be 0.5+0.3=0.8 ??? or what else??...I am unable to calculate the amplitude of message signal which I need to calculate modulation index. Waiting for your positive reply.
What is the modulation index?
Started by ●October 19, 2008
Reply by ●October 19, 20082008-10-19
qoo wrote:> I have a confusion here. So please help. > > I have a message signal given as : > > m(t) = 0.5 cos(wt) + 0.3 sin (2wt) > > I also have a carrier signal whose amplitude is known. > > and now i want to calculate the modulation index. which is given as > amplitude of message signal divided by amplitude of carrier. (Remember > that i am doing AM.) > > The confusion is that: > > Does the amplitude of message signal be 0.5+0.3=0.8 ??? > or what else??...I am unable to calculate the amplitude of message > signal which I need to calculate modulation index. > > Waiting for your positive reply.Modulation index is a property of an FM signal. The property you want is modulation percentage. Most circumstances that make the modulation percentage useful call for peak values. A quick bit of calculus will reveal the peak value of m(t). You probably should know how to do that. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Oct 19, 3:13�pm, Jerry Avins <j...@ieee.org> wrote:> qoo wrote: > > I have a confusion here. So please help. > > > I have a message signal given as : > > > m(t) = 0.5 cos(wt) + 0.3 sin (2wt) > > > I also have �a carrier signal whose amplitude is known. > > > and now i want to calculate the modulation index. which is given as > > amplitude of message signal divided by amplitude of carrier. (Remember > > that i am doing AM.) > > > The confusion is that: > > > Does the amplitude of message signal be 0.5+0.3=0.8 �??? > > or what else??...I am unable to calculate the amplitude of message > > signal which I need to calculate modulation index. > > > Waiting for your positive reply. > > Modulation index is a property of an FM signal. The property you want is > modulation percentage. Most circumstances that make the modulation > percentage useful call for peak values. A quick bit of calculus will > reveal the peak value of m(t). You probably should know how to do that. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > �����������������������������������������������������������������������Thanks jerry :)
On Oct 19, 3:13�pm, Jerry Avins <j...@ieee.org> wrote:> qoo wrote: > > I have a confusion here. So please help. > > > I have a message signal given as : > > > m(t) = 0.5 cos(wt) + 0.3 sin (2wt) > > > I also have �a carrier signal whose amplitude is known. > > > and now i want to calculate the modulation index. which is given as > > amplitude of message signal divided by amplitude of carrier. (Remember > > that i am doing AM.) > > > The confusion is that: > > > Does the amplitude of message signal be 0.5+0.3=0.8 �??? > > or what else??...I am unable to calculate the amplitude of message > > signal which I need to calculate modulation index. > > > Waiting for your positive reply. > > Modulation index is a property of an FM signal. The property you want is > modulation percentage. Most circumstances that make the modulation > percentage useful call for peak values. A quick bit of calculus will > reveal the peak value of m(t). You probably should know how to do that. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > �����������������������������������������������������������������������Thanks Jerry :) :) :)
qoo wrote: ...> Thanks Jerry :) :) :):) :) :) You're welcome! :) :) :) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
