Problems estimating frequencies from the Root-MUSIC algorithm. Starting from the noise & signal subspaces, I form the polynomies from the noise subspace. Then I choose the x roots closest to the unit circle (roots whose absolute values are the closest to the unit circle) (being x the number of signal eigenvectors) Having the complexes roots I can calculate the DoA (direction of arrival) My question is: are there any way to estimate the distance the signal travelled from the emitter? Thanks for your cooperation, Ra�l
Root MUSIC
Started by ●March 30, 2004
Reply by ●March 30, 20042004-03-30
Root MUSIC itself can not estimate the distance between a source and the array since it assumes plane waves. "Ra?l Gonz?lez" <tante_ju@teleline.es> wrote in message news:1d807096.0403301040.45385d17@posting.google.com...> Problems estimating frequencies from the Root-MUSIC algorithm. > Starting from the noise & signal subspaces, I form the polynomies from the > noise subspace. Then I choose > the x roots closest to the unit circle (roots whose absolute values arethe> closest to the unit circle) > (being x the number of signal eigenvectors) > Having the complexes roots I can calculate the DoA (direction of arrival) > My question is: are there any way to estimate the distance the signal > travelled from the emitter? > Thanks for your cooperation, > Ra�l
