visualDSP++ loader file
Started by abasili October 22, 2008
Hi everyone, I'm using a VisualDSP++ 3.5 to develop some software for an
ADSP-2187L.
Before starting to develop any software I need a way to load it into my
target without the use of an EZ-Ice and I have to go through a
spacewire-like protocol in order to program the FLASH.
My system has already a "built-in" software which will allow me to write
and erase the flash memory without any problem.
I thought it would have been easy to get the Intel hex format file to be
loaded in the flash, but unfortunately I don't know why I'm not able to
set the Project Type to "DSP loader file", which is the way it is
explained in the loader manual (loader_manual_16bits_dsp.pdf, pag. 23).
Apparently my only options are:
- dsp executable file
- dsp library file
- dsp object file
- splitter file
- vcse component library
So far we have use the dsp executable file and then through the ez-ice
loaded it into the target.
I know there is a command line approach but i would have preferred to
have everything done with the IDDE.
Thanks a lot in advance for any suggestion or advice,
regards
Al
