Good afternoon: I have implemented an RS encoder and decoder in GF16 and GF256. It works for the case when the first root of the generator polynomial is alpha^1, the usual case shown in textbooks. I have been able to reproduce the textbook examples and it worked for a test of 10,000 random messages with random error locations and error values (t=3). However, when I try to use alpha^2 as the first root, I am able to obtain the error locations, but the error values. When I computed the syndromes I used S[0+i] = R[alpha^(m0+i)] where R is the received message polynomial and m0 is the location of the first root of the generator polynomial. I obtained the syndromes, then the Berlekamp-Massey algorithm worked and the error locations were correct. The problem is in finding the error values. Right now I am looking at the syndrome equations in terms of the error locations. This is a matrix equation S = AE where the error values E[i] are unknown. I implemented the matrix inverse solution for the case of three errors. This works for the situation when the first root of the gen poly is alpha^1, but as soon as I run the algorithm for the first root being alpha^2, the syndrome equation doesn't work. This suggests to me that the syndrome equation has to be different for the case when the first gen poly root is not at location 1, but I don't know why or how. In other words, I don't think the problem is in an implementation of the Forney algorithm, I think the problem is in writing the syndrome equation S=AE that one is starting with. Thank you for any information, as my work is usually on speech, audio or medical imaging DSP, and this is not my expertise area. Linda Seltzer
Reed-Solomon syndrome equation solution question
Started by ●October 22, 2008
Reply by ●October 22, 20082008-10-22
On Oct 22, 2:58 pm, "lindasel" <lselt...@alumni.caltech.edu> wrote:> Good afternoon: > > I have implemented an RS encoder and decoder in GF16 and GF256. It works > for the case when the first root of the generator polynomial is alpha^1, > the usual case shown in textbooks. I have been able to reproduce the > textbook examples and it worked for a test of 10,000 random messages with > random error locations and error values (t=3). However, when I try to > use > alpha^2 as the first root, I am able to obtain the error locations, but > the error values. > When I computed the syndromes I used > S[0+i] = R[alpha^(m0+i)] > where R is the received message polynomial and m0 is the location of the > first root of the generator polynomial. I obtained the syndromes, then the > Berlekamp-Massey algorithm worked and the error locations were correct. > The problem is in finding the error values. > > Right now I am looking at the syndrome equations in terms of the error > locations. This is a matrix equation > S = AE > where the error values E[i] are unknown. > I implemented the matrix inverse solution for the case of three errors. > This works for the situation when the first root of the gen poly is > alpha^1, but as soon as I run the algorithm for the first root being > alpha^2, the syndrome equation doesn't work. > This suggests to me that the syndrome equation has to be different for > the > case when the first gen poly root is not at location 1, but I don't know > why or how. In other words, I don't think the problem is in an > implementation of the Forney algorithm, I think the problem is in writing > the syndrome equation S=AE that one is starting with. > > Thank you for any information, as my work is usually on speech, audio or > medical imaging DSP, and this is not my expertise area. > > Linda SeltzerHi Linda, You can find the correct error values by using m0 in the Forney algorithm as follows: e(i) = [Xi^(2-m0) * Omega(1/Xi)] / [Lambda'(1/Xi)] Darol Klawetter
Reply by ●October 23, 20082008-10-23
On Oct 22, 2:58�pm, "lindasel" <lselt...@alumni.caltech.edu> wrote:> Good afternoon: > > I have implemented an RS encoder and decoder in GF16 and GF256. �It works > for the case when the first root of the generator polynomial is alpha^1, > the usual case shown in textbooks. �I have been able to reproduce the > textbook examples and it worked for a test of 10,000 random messages with > random error locations and error values (t=3). �However, when I try to > use > alpha^2 as the first root, I am able to obtain the error locations, but > the error values. � > When I computed the syndromes I used > S[0+i] = R[alpha^(m0+i)] > where R is the received message polynomial and m0 is the location of the > first root of the generator polynomial. I obtained the syndromes, then the > Berlekamp-Massey algorithm worked and the error locations were correct. > The problem is in finding the error values. > > Right now I am looking at the syndrome equations in terms of the error > locations. This is a matrix equation > S = AE > where the error values E[i] are unknown. > I implemented the matrix inverse solution for the case of three errors. > This works for the situation when the first root of the gen poly is > alpha^1, but as soon as I run the algorithm for the first root being > alpha^2, the syndrome equation doesn't work. > This suggests to me that the syndrome equation has to be different for > the > case when the first gen poly root is not at location 1, but I don't know > why or how. �In other words, I don't think the problem is in an > implementation of the Forney algorithm, I think the problem is in writing > the syndrome equation S=AE that one is starting with. > > Thank you for any information, as my work is usually on speech, audio or > medical imaging DSP, and this is not my expertise area. > > Linda SeltzerS = AE where S is a vector of syndromes and E the vector of error values and A is (in essence) a Vandermonde matrix can be solved by computing the inverse of A and finding E as SA^{-1}. The inverse of a Vandermonde matrix is known explicitly, that is, there is a formula for each entry in the inverse matrix, which is often ill-conditioned when floating-point computations are in use. No such problem arises in finite fields. Forney's formula is a clever way of combining the inverse computation and the SA^{-1} calculation to give the error values directly. It also does not require one to know ALL the error locations X_i (needed to find A and hence A^{-1}) before beginning the computation of error values. Each error value Y_i can be found immediately after finding the corresponding error location X_i. For the case of three errors and a generator polynomial g(z) = (z-alpha^2)(z-alpha^3)....(z-alpha^{2t+1}) where t is 3 or more, the equations to be solved are S_0 = (X_1)^2(Y_1) + (X_2)^2(Y_2) + (X_3)^2(Y_3) S_1 = (X_1)^3(Y_1) + (X_2)^3(Y_2) + (X_3)^3(Y_3) S_2 = (X_1)^4(Y_1) + (X_2)^4(Y_2) + (X_3)^4(Y_3) where S_0 = R(alpha^2), S_1 = R(alpha^3), S_2= R(alpha^4) and X_1, X_2, X_3 are the error locations. A standard Vandermonde matrix is usually defined as (read in monospaced font, please) 1 1 1 X_1 X_2 X_3 (X_1)^2 (X_2)^2 (X_3)^2 The matrix manipulations needed to transform this to the one needed (and the corresponding transformations of the inverse) should be worked out by interested parties. Hope this helps --Dilip Sarwate
Reply by ●November 9, 20082008-11-09
I formed this matrix and was able to take the inverse. I tested product of the matrix and the inverse and got the identity matrix. However, when I computed the error magnitudes for the set of equations Y = [Ainv] S, there were still some errors: (1) the error values dont come out in a consistent order for the error locations for different test cases. (2) it doesn't get the correct error value for the second equation. There seems to be more to it than just getting the inverse and multiplying it by the syndrome vector. Thank you for any suggestions.>For the case of three errors and a generator polynomial >g(z) =3D (z-alpha^2)(z-alpha^3)....(z-alpha^{2t+1}) where t is 3 or >more, >the equations to be solved are > >S_0 =3D (X_1)^2(Y_1) + (X_2)^2(Y_2) + (X_3)^2(Y_3) >S_1 =3D (X_1)^3(Y_1) + (X_2)^3(Y_2) + (X_3)^3(Y_3) >S_2 =3D (X_1)^4(Y_1) + (X_2)^4(Y_2) + (X_3)^4(Y_3) > >where S_0 =3D R(alpha^2), S_1 =3D R(alpha^3), S_2=3D R(alpha^4) >and X_1, X_2, X_3 are the error locations.
Reply by ●April 23, 20092009-04-23
I've been away from error correction for a while, but I was able to get it to work back then. Here is a sample result. Thank you for answering my questions. -Linda Seltzer _______________________________________________________________ transmitted message [0] = f transmitted message [1] = 0 transmitted message [2] = 5 transmitted message [3] = 5 transmitted message [4] = 4 transmitted message [5] = 7 transmitted message [6] = 0 transmitted message [7] = f transmitted message [8] = 0 transmitted message [9] = a transmitted message [a] = 7 transmitted message [b] = 6 transmitted message [c] = 4 transmitted message [d] = 8 transmitted message [e] = 0 ---------------------------------------- ******ERROR CORRECTION TEST - Arbitrary example Before errors inserted: recd_msg[0] = f Before errors inserted: recd_msg[1] = 0 Before errors inserted: recd_msg[2] = 5 Before errors inserted: recd_msg[3] = 5 Before errors inserted: recd_msg[4] = 4 Before errors inserted: recd_msg[5] = 7 Before errors inserted: recd_msg[6] = 0 Before errors inserted: recd_msg[7] = f Before errors inserted: recd_msg[8] = 0 Before errors inserted: recd_msg[9] = a Before errors inserted: recd_msg[a] = 7 Before errors inserted: recd_msg[b] = 6 Before errors inserted: recd_msg[c] = 4 Before errors inserted: recd_msg[d] = 8 Before errors inserted: recd_msg[e] = 0 inserted error at location 8, value b inserted error at location 9, value 2 inserted error at location e, value 2 After errors inserted: recd_msg[0] = f After errors inserted: recd_msg[1] = 0 After errors inserted: recd_msg[2] = 5 After errors inserted: recd_msg[3] = 5 After errors inserted: recd_msg[4] = 4 After errors inserted: recd_msg[5] = 7 After errors inserted: recd_msg[6] = 0 After errors inserted: recd_msg[7] = f After errors inserted: recd_msg[8] = b After errors inserted: recd_msg[9] = 2 After errors inserted: recd_msg[a] = 7 After errors inserted: recd_msg[b] = 6 After errors inserted: recd_msg[c] = 4 After errors inserted: recd_msg[d] = 8 After errors inserted: recd_msg[e] = 2 synd[0] = 0 synd[1] = e synd[2] = f synd[3] = 2 synd[4] = f synd[5] = e synd[0] = 0 synd[1] = e synd[2] = f synd[3] = 2 synd[4] = f synd[5] = e Length of Syndrome 6 Error Locator polynomial LL0 = 1 LL1 = 6 LL2 = a LL3 = 2 nroots = 3 power representation of root = 1 in hex inverse root val = e power representation of root = 6 in hex inverse root val = 9 power representation of root = 7 in hex inverse root val = 8 error found at location e error found at location 9 error found at location 8 root = 1 root = 6 root = 7 rootsofsigma 1 6 7 syndrome vector for matrix equation = 0 e f Printing 3x3 matrix row1 before squaring: [5 a 9] element (1,1): alpha^ 8 element (1,2): alpha^ 9 element (1,3): alpha^ e row1: [ 2 8 d ] row2: [ a f f ] row3: [ 4 c e ] Matrix in power representation element (1,1): alpha^ 1 element (1,2): alpha^ 3 element (1,3): alpha^ d element (2,1): alpha^ 9 element (2,2): alpha^ c element (2,3): alpha^ c element (3,1): alpha^ 2 element (3,2): alpha^ 6 element (3,3): alpha^ b Transpose Matrix in power representation element (1,1): alpha^ 1 element (1,2): alpha^ 9 element (1,3): alpha^ 2 element (2,1): alpha^ 3 element (2,2): alpha^ c element (2,3): alpha^ 6 element (3,1): alpha^ d element (3,2): alpha^ c element (3,3): alpha^ b Computing ca11 XOR of element (3,2): alpha^ 8 element (3,3): alpha^ 3 Cofactors element (1,1): alpha^ d element (1,2): alpha^ 9 element (1,3): alpha^ 5 element (2,1): alpha^ c element (2,2): alpha^ b element (2,3): alpha^ 5 element (3,1): alpha^ 3 element (3,2): alpha^ d element (3,3): alpha^ 1 Determinant = a = alpha ** 9 Matrix inverse in power representation element (1,1): alpha^ 4 element (1,2): alpha^ 0 element (1,3): alpha^ b element (2,1): alpha^ 3 element (2,2): alpha^ 2 element (2,3): alpha^ b element (3,1): alpha^ 9 element (3,2): alpha^ 4 element (3,3): alpha^ 7 Product of matrix and inverse element (1,1): alpha^ 0 element (1,2) = 0 element (1,3) = 0 element (2,1) = 0 element (2,2): alpha^ 0 element (2,3) = 0 element (3,1) = 0 element (3,3) = 0 element (3,3): alpha^ 0 errmags at 8 = b = alpha^7 errmags at 9 = 8 = alpha^3 errmags at e = 2 = alpha^1 Error at location 8 is b Error at location 8 is b Error at location 9 is 8 Error at location 9 is 8 Error at location e is 2 Error at location e is 2 Error vector [0] = 0 Error vector [1] = 0 Error vector [2] = 0 Error vector [3] = 0 Error vector [4] = 0 Error vector [5] = 0 Error vector [6] = 0 Error vector [7] = 0 Error vector [8] = b Error vector [9] = 8 Error vector [a] = 0 Error vector [b] = 0 Error vector [c] = 0 Error vector [d] = 0 Error vector [e] = 2 Add to recd_msg[0] = f Add to recd_msg[1] = 0 Add to recd_msg[2] = 5 Add to recd_msg[3] = 5 Add to recd_msg[4] = 4 Add to recd_msg[5] = 7 Add to recd_msg[6] = 0 Add to recd_msg[7] = f Add to recd_msg[8] = b Add to recd_msg[9] = 2 Add to recd_msg[a] = 7 Add to recd_msg[b] = 6 Add to recd_msg[c] = 4 Add to recd_msg[d] = 8 Add to recd_msg[e] = 2 ************Doing error correction correctedmsg [0] = f correctedmsg [1] = 0 correctedmsg [2] = 5 correctedmsg [3] = 5 correctedmsg [4] = 4 correctedmsg [5] = 7 correctedmsg [6] = 0 correctedmsg [7] = f correctedmsg [8] = 0 correctedmsg [9] = a correctedmsg [a] = 7 correctedmsg [b] = 6 correctedmsg [c] = 4 correctedmsg [d] = 8 correctedmsg [e] = 0>>>
