hi all, small doubt..i was Spectrum analyzer..all along in place..where i work.but..i was wondering..how..by providing external trigger..the time domain (zero span signal) is stabilized and locked to external trigger and its stable and not moving in the view screen.. ofcourse..i will select..trigger option as external trigger...instead of free run.. can anyone..point to some literature or explain..the underlying events happening.. thanks particlereddy
why does..a SPECTRUM ANALYZER's time domain signal.stabilies after connecting external trigger
Started by ●October 23, 2008
Reply by ●October 23, 20082008-10-23
PARTICLEREDDY (STRAYDOG) wrote:> hi all, > small doubt..i was Spectrum analyzer..all along in place..where > i work.but..i was wondering..how..by providing external trigger..the > time domain (zero span signal) is stabilized and locked to external > trigger and its stable and not moving in the view screen.. > > ofcourse..i will select..trigger option as external trigger...instead > of free run.. > > can anyone..point to some literature or explain..the underlying events > happening..What instrument do you mean? It seems to me that you described an oscilloscope display. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Thu, 23 Oct 2008 10:02:33 -0400, Jerry Avins <jya@ieee.org> wrote:>PARTICLEREDDY (STRAYDOG) wrote: >> hi all, >> small doubt..i was Spectrum analyzer..all along in place..where >> i work.but..i was wondering..how..by providing external trigger..the >> time domain (zero span signal) is stabilized and locked to external >> trigger and its stable and not moving in the view screen.. >> >> ofcourse..i will select..trigger option as external trigger...instead >> of free run.. >> >> can anyone..point to some literature or explain..the underlying events >> happening.. > >What instrument do you mean? It seems to me that you described an >oscilloscope display. > >JerryHe's talking about zero-span on typical spectrum analyzers, which allows a time-domain view of the signal like an oscilloscope. I think it boils down to working a lot like an oscilloscope in that mode. I'm not completely sure what the question is in that regard. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
Eric Jacobsen wrote:> On Thu, 23 Oct 2008 10:02:33 -0400, Jerry Avins <jya@ieee.org> wrote: > >> PARTICLEREDDY (STRAYDOG) wrote: >>> hi all, >>> small doubt..i was Spectrum analyzer..all along in place..where >>> i work.but..i was wondering..how..by providing external trigger..the >>> time domain (zero span signal) is stabilized and locked to external >>> trigger and its stable and not moving in the view screen.. >>> >>> ofcourse..i will select..trigger option as external trigger...instead >>> of free run.. >>> >>> can anyone..point to some literature or explain..the underlying events >>> happening.. >> What instrument do you mean? It seems to me that you described an >> oscilloscope display. >> >> Jerry > > He's talking about zero-span on typical spectrum analyzers, which > allows a time-domain view of the signal like an oscilloscope. > > I think it boils down to working a lot like an oscilloscope in that > mode. I'm not completely sure what the question is in that regard.He's probably too young to remember vertical- and horizontal hold controls on TV sets. To OP: the signal's amplitude is shown on the vertical axis, with a sawtooth (sweep) waveform providing the effect of time on the horizontal axis. For the signal to appear stationary on the display, the sweep time must contain an integer number of periods of the displayed waveform. The sync functions like a PLL to achieve that. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●October 24, 20082008-10-24
On Oct 23, 1:23 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote:> He's talking about zero-span on typical spectrum analyzers, which > allows a time-domain view of the signal like an oscilloscope. > > I think it boils down to working a lot like an oscilloscope in that > mode. I'm not completely sure what the question is in that regard.Yes, but it sounds like he's got it free running. HP/Agilent (and probably most other) analyzers offer a video level trigger mode, but in my experiments it is primitive compared to a scope's trigger circuit. On the other hand, it's implicitly a storage scope so you can single shot it. But again, on ours at least there's not single shot button, you have to change to repetitive and change back. Basically - the start of a good capability, but not finished in the model I was playing with.
