On Sun, 26 Oct 2008 08:05:48 -0700 (PDT), "dvsarwate@yahoo.com" <dvsarwate@gmail.com> wrote:>On Oct 24, 6:32�pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > >> >> The relative complexities (of the encoders and decoders) are an >> important metric to consider as well. � Running an RS encoder or >> decoder at such a low rate is usually inefficient compared to a decent >> Viterbi decoder. � The RS encoder will always be far more complex than >> the CC encoder, especially at R=1/2. >> > >True. But an RS encoder/decoder for a (32,16) RS code over >GF(256) obtained by shortening a (255,239) RS code has the >same complexity as the original code.Yes, and since the larger codeword has to be processed far more frequently (every 32 bytes received rather than every 255 or 204 or whatever) there may need to be parallel instantiations needed in order to keep up. That's just comparing to the typical 255 or 204-byte codewords.> On the other hand, >a (256,128) RS code or (255,127) RS code would be totally >impractical.Agreed. I suspect that's why we don't see them used in practice. ;)>A (32,16) RS code over GF(256) s a very powerful code but >with *many* weak spots for use on an AWGN channel where >it would typically be implemented as a (256,128) binary code >with antipodal PSK signaling. This code is guaranteed to >correct all (single) bursts of errors as long as 50 bits of the 256 >bits in a block, and *some* bursts of longer lengths (up to 64 >bits) can also be corrected. But there are random bit errors >of as few as 9 bits that the code is unable to correct. >Unfortunately, >on an AWGN channel, random bit errors are generally more >likely to occur than long bursts. A better modulation scheme for >an RS code on an AWGN channel would be M-ary orthogonal >FSK, but nobody wants to use that, do they? > >--Dilip SarwateNot if M is very large at all. Agreed on your points, as usual. Depending on what the OP is doing I'm interested in his results. There are cases in industry where RS-only FEC is used in practice, usually with reasonably high order modulation and the typical high code rates. I've not seen such a low-rate used before, though. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
Reed Solomon Simulation
Started by ●October 24, 2008
Reply by ●October 26, 20082008-10-26
dvsarwate@yahoo.com <dvsarwate@gmail.com> wrote:>But an RS encoder/decoder for a (32,16) RS code over >GF(256) obtained by shortening a (255,239) RS code has the >same complexity as the original code.Slight nitpick: on a per-decoded bit basis, it has higher complexity. On a per-codeword basis, it has about the same complexity, but the codewords have fewer bits.>A (32,16) RS code over GF(256) s a very powerful code but >with *many* weak spots for use on an AWGN channel where >it would typically be implemented as a (256,128) binary code >with antipodal PSK signaling. This code is guaranteed to >correct all (single) bursts of errors as long as 50 bits of the 256 >bits in a block, and *some* bursts of longer lengths (up to 64 >bits) can also be corrected. But there are random bit errors >of as few as 9 bits that the code is unable to correct.On an AWGN channel, if you are using a RS code with a given code rate and a given number of bits per codeword, you are best off using the smallest possible field size. Thus, this rate 1/2 code has 256 bits per codeword; a 6-bit (42,21) RS code has roughly the same number of bits per codeword but performs better. (And, a binary BCH code performs better still, if the channel is truly AWGN without bursts.) An interesting possibility for larger codeword sizes is to use an algebraic geometry code. Steve
Reply by ●October 27, 20082008-10-27
Hello I have completed the simulation of rate 1/2 RS code as Dr. Sarwate suggested. Now, the way I have done is as follows, the channel is AWGN and BPSK modulation: data=randint(1,16,256); data_pad=[zeros(1,223) data]; code=rsenc(data_pad,255,239); actual_code=code(224:end); which gives me 32 symbols. and exactly opp at receiver. This works fine and if I remove noise I am getting 0 BER. But the way I am scaling the noise is: sigma=sqrt(1/(2*R_c*snr_lin)); where R_c=239/255. By doing this way, at 4.5 dB, I am getting BER of 9e-5; Ideally, R_c=1/2, but if I use R_c=0.5, at 4.5 dB I am geting BER of 1e-2. Is this correct? Chintan
Reply by ●October 29, 20082008-10-29
On Oct 26, 11:24�pm, "cpshah99" <cpsha...@rediffmail.com> wrote:> the channel is AWGN and BPSK modulation: > > data=randint(1,16,256); > data_pad=[zeros(1,223) data]; > code=rsenc(data_pad,255,239); > actual_code=code(224:end); which gives me 32 symbols.> But the way I am scaling the noise is: > > sigma=sqrt(1/(2*R_c*snr_lin)); > > where R_c=239/255. By doing this way, at 4.5 dB, I am getting BER of > 9e-5; > > Ideally, R_c=1/2, but if I use R_c=0.5, at 4.5 dB I am geting BER of > 1e-2.Chintan: You ask, Is this correct? Well, it depends on whether you want to get the right answer or the answer that you *want* to get, viz., your RS code will perform better than a rate 1/2 convolutional code. The code that you are using is a rate 1/2 code, and so you should use R_c = 1/2, and not R_c = 239/255, shouldn't you? Uncoded PSK on an AWGN channel has BER just a little below 10^-2 at 4.5 dB. If a rate 1/2 code is used, the raw channel bit error rate is much higher, about 0.046 or so, and thus an 8-bit RS symbol has a high probability of being incorrect, likely enough to overwhelm the error correcting capability of the code. It is not surprising that your simulation gives a rather large decoded BER (assuming that it has been done correctly). Making the answer more palatable (to yourself) by using the wrong code rate and hence the wrong SNR is not the way to go. It will make the denizens of comp.dsp very suspicious of any results that you report in the future. Dilip Sarwate
Reply by ●October 30, 20082008-10-30
Hi Sir! I really want the *right* answer not the answer *I want*. Even I had some doubts regarding my simulation, so what I did is that I used RS code of (255,127) which is definately rate 1/2 code. So, now I am getting BER of 1e-4 at 5.5 dB. I *think* this correct, I might be wrong. I would really appreciate your opinion. I dont want to report any wrong results. Regards, Chintan
