Periodogram returning extra values
Started by Unknown October 29, 2008
On Thu, 30 Oct 2008 15:20:53 -0800, Glen Herrmannsfeldt
<gah@ugcs.caltech.edu> wrote:
>dbd wrote: >(snip) > >> The N point DFT of a real signal returns a real value at DC, N/2 - 1 >> complex values, and an imaginary value at fs/2; a total of N values >> from N real samples. > >And by symmetry, the DFT of an imaginary signal should return an >imaginary value at DC, N/2-1 complex values, and a real value at fs/2. > >I don't believe that there is a mathematical symbol for 'less than >and partially equal to'. > >-- glen
Hmmm..... <~= :) Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
On Oct 30, 9:32 pm, Glen Herrmannsfeldt <g...@ugcs.caltech.edu> wrote:
> dbd wrote: > > (snip) > > > What non-periodic band limited signal can you > > reconstruct from N+1 sample points? > > Doesn't Nyquist deal with bandwidths and > > rates, not numbers of samples? > > One that is N divided by the appropriate sampling rate long. > > -- glen
This rectangular pulse is not band limited, nor can it be uniquely reconstructed from N+1 samples Dale B. Dalrymple
On Thu, 30 Oct 2008 14:05:37 -0700 (PDT), dbd <dbd@ieee.org> wrote:
   (snipped by Lyons)
>The N point DFT of a real signal returns a real value at DC, N/2 - 1 >complex values, and an imaginary value at fs/2; a total of N values >from N real samples. > >Dale B. Dalrymple
Hi, Are you sure it's an imaginary value at fs/2? The complex exponential in the N-point DFT equation (when N is even) is: exp(-j*pi*n) where "n" is the time-domain index. That exponential is real-valued for all "n". [-Rick-]
On Nov 1, 2:33 pm, Rick Lyons <R.Lyons@_BOGUS_ieee.org> wrote:
> On Thu, 30 Oct 2008 14:05:37 -0700 (PDT), dbd <d...@ieee.org> wrote: > > (snipped by Lyons) > > >The N point DFT of a real signal returns a real value at DC, N/2 - 1 > >complex values, and an imaginary value at fs/2; a total of N values > >from N real samples. > > >Dale B. Dalrymple > > Hi, > Are you sure it's an imaginary value > at fs/2? > > The complex exponential in the N-point DFT > equation (when N is even) is: > > exp(-j*pi*n) > > where "n" is the time-domain index. That > exponential is real-valued for all "n". > > [-Rick-]
No, should be real. Dale B. Dalrymple
>>The N point DFT of a real signal returns a real value at DC, N/2 - 1 >>complex values, and an imaginary value at fs/2; a total of N values >>from N real samples.
> exp(-j*pi*n)
You want exp(-j*2*pi*n*k/N) where n and k are integers from 0 and N-1, inclusive. http://en.wikipedia.org/wiki/Discrete_Fourier_transform#Definition -- glen
On Nov 1, 6:06 pm, Glen Herrmannsfeldt <g...@ugcs.caltech.edu> wrote:
> > You want exp(-j*2*pi*n*k/N) where n and k are > integers from 0 and N-1, inclusive. > > http://en.wikipedia.org/wiki/Discrete_Fourier_transform#Definition > > -- glen
Gee, does this mean that glen is suggesting that the Nth term is in some sense imaginary? Unfortunately, this is a reference to that great repository of urban legend, wikipedia. As is often the case in technical areas, the material in the wiki differs from the version in the references cited. Take for example Steven Smith's chapter 8, cited in the wiki (see the third reference in the wiki for the full citation), which refers to this as "a common bug in DFT programs" on page 148. Now it may be that the bug is sometimes intentional, but that is a matter of engineering practice departing from theoretical accuracy. Dale B. Dalrymple
Another way to look at it is you get two real and two imaginary values at fs/2 (for both the positive and negative frequency), the two real values are of the same sign, but the two imaginary values are of the opposite sign, so always cancel, giving you an imaginary sum of zero. That's also why the amplitudes in the bins for DC and fs/2 seem to have an factor of 2X compared to all of all the other bins. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M http://www.nicholson.com/rhn/dsp.html
