RESTORING BINARY SIGNAL FROM LOW FREQUENCIES
Started by Ostap ●October 31, 2008
>>Is the function s(x) cyclostationary or not? >> >>If it is cyclostationary, then the task is the typical problem of the >>digital communication and there are many ways for solution depending on
>>L(x). >> >>If s(x) is not cyclostationary, then the problem is non-trivial and the
>>solution may not be unique. > >I don't see how cyclostationarity is relevant. The OP did not say it >comes from a random process. In fact his example is rather
deterministic. I understand a deterministic signal can also be cyclostationary; so never mind that part. Still, I don't see why exactly one needs this condition. Does anyone have a good explanation? Emre
On Oct 31, 6:44&#4294967295;pm, "emre" <egu...@ece.neu.edu> wrote:
> To the OP: there may be an extremely neat solution to your problem. &#4294967295;If > you have enough Fourier domain measurements, you can reconstruct your > signal *exactly* with an overwhelming probability, assuming the number of > jumps and/or the nonzero values in your signal is &#4294967295;small (i.e. sparse) with > respect to the total number of the samples. &#4294967295;See the below reference [1]. > > Hope this helps, > > Emre > > [1] E. J. Cand&#4294967295;s, J. Romberg and T. Tao. Robust uncertainty principles: > exact signal reconstruction from highly incomplete frequency information. > IEEE Trans. Inform. Theory, 52 489-509.
Emre, Perfect reference! Thank you very much. We can consider this thread to be over. Yuri
