Hi all I have a DSK 6416 , before I asked for a way to load a COFF file to the DSK 6416 without CCS but I didn't get much help, basically I was asking to see if there is a HPI library provided with DSK6416 as it is with some other DSKs. I will be gratefull if anybody is aware of any library or any method. If not , imagine to have a program running in DSK(from Flash) without CCS , how can I read or write data to the memory without CCS in DSK6416, is it possible to do it with RTDX. Thanks in advance : Hamid
Host application without CCS in DSK6416
Started by ●March 29, 2004
Reply by ●March 30, 20042004-03-30
Hello Hamid,> ... but I didn't get much help, ...The reason for that was that your question was not clear. You think of what you want but you don't write it. As I suppose you want to load a program over the USB port to the dsk board over the 320DA250 with a tool supplied by TI. But that has nothing to do with HPI. HPI of your DSK6416 is connected to an available daughter board connector ... There are a lot of ways to read or write data to the memory without CCS in DSK6416 but which way do you want to use ? Clear questions -> clear answers. Wolfgang
