I'm looking for a simple (need not be very efficient) VC++/C++ library that does the image (png) convolution, 2D FFT. I would like to develop a image search feature (http://www.dspguide.com/ch24/6.htm) with a VC+ + based GUI around it. http://www.codeproject.com/KB/graphics/ImageConvolution.aspx does have the convolution feature but not FFT. Anybody gone through the same requirement? Thank you
Image FFT Convolution - C++/VC++ source code
Started by ●November 12, 2008
Reply by ●November 13, 20082008-11-13
>I'm looking for a simple (need not be very efficient) VC++/C++ library >that does the image (png) convolution, 2D FFT. I would like to develop >a image search feature (http://www.dspguide.com/ch24/6.htm) with a VC+ >+ based GUI around it.http://www.codeproject.com/KB/graphics/ImageConvolution.aspx>does have the convolution feature but not FFT. Anybody gone through >the same requirement? > >Thank you >The technique you mention is just image convolution with a target signal. The FFT is nothing more than a way of making the computations faster. So if you want something simple, without needing efficency, you should be implementing the algorithm with convolution and forget about 2d FFTs. Regards, Steve
On Nov 13, 8:12�am, "SteveSmith" <Steve.Smi...@SpectrumSDI.com> wrote:> >I'm looking for a simple (need not be very efficient) VC++/C++ library > >that does the image (png) convolution, 2D FFT. I would like to develop > >a image search feature (http://www.dspguide.com/ch24/6.htm) with a VC+ > >+ based GUI around it. > > http://www.codeproject.com/KB/graphics/ImageConvolution.aspx > > >does have the convolution feature but not FFT. Anybody gone through > >the same requirement? > > >Thank you > > The technique you mention is just image convolution with a target signal. > The FFT is nothing more than a way of making the computations faster. �So > if you want something simple, without needing efficency, you should be > implementing the algorithm with convolution and forget about 2d FFTs. > Regards, > SteveThank you steve, that should work for me!! I'm trying to implement the image search described here http://www.dspguide.com/ch24/6.htm. I have to check for existence of a target image. Upon convolution we will have some values, each value proportional to the match. There may one or more maximas depending on repetition of the target. so is the case If target does not exist in the source image. How could one conclusively say that target does exist in the source or not?
