Is there an easier way to calculate a frequency on a set of wav samples?
Started by SA Dev March 29, 2004
Hi,
I'm trying to measure the maximum volume of a real-time wav output using 16
bit signed integers.
I have heard that running them through a FFT could get me a frequency, but I
don't have the CPU power to accomplish this in real time.
Could I do something more crude that would give me an estimate of frequency
but at much less CPU time cost.
How about counting the number of times the samples when from positive to
negative and back to positive again.  Could I use this to determine a rough
frequency?
If I took 50ms samples, estimated the frequency using this technique and
then ran them through an equal loudness curve, would this be a rough way to
determine the perceived volume?
Thanks,
SA Dev
On Mon, 29 Mar 2004 10:07:55 -0600, "SA Dev" <nospam38925@forme.com>
wrote:
>Hi, > >I'm trying to measure the maximum volume of a real-time wav output using 16 >bit signed integers. > >I have heard that running them through a FFT could get me a frequency, but I >don't have the CPU power to accomplish this in real time. > >Could I do something more crude that would give me an estimate of frequency >but at much less CPU time cost. > >How about counting the number of times the samples when from positive to >negative and back to positive again. Could I use this to determine a rough >frequency?
If the signal has only one frequency component, then counting zero crossings will work perfectly. Or, if the signal is otherwise in some special catgory, such as square waves, then it will work fine. But in general, counting zero crossings won't even get you close. You would probably end up counting something related to the frequency with the highest amplitude, or most likely, you will get complete garbage. -Robert Scott Ypsilanti, Michigan (Reply through this forum, not by direct e-mail to me, as automatic reply address is fake.)
SA Dev wrote:
> Hi, > > I'm trying to measure the maximum volume of a real-time wav output using 16 > bit signed integers. > > I have heard that running them through a FFT could get me a frequency, but I > don't have the CPU power to accomplish this in real time. > > Could I do something more crude that would give me an estimate of frequency > but at much less CPU time cost. > > How about counting the number of times the samples when from positive to > negative and back to positive again. Could I use this to determine a rough > frequency? > > If I took 50ms samples, estimated the frequency using this technique and > then ran them through an equal loudness curve, would this be a rough way to > determine the perceived volume? > > Thanks, > > SA Dev
1) To measure volume, what do you want with frequency? 2) You write of real-time output. Do you want to simulate a meter that shows the actual volume at any instant? 3) So-called equal-loudness curves depend very much on the gain settings when the material was recorded. What you need to do is much simpler if you can ignore Fletcher-Munsen. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Hi Jerry,
> 1) To measure volume, what do you want with frequency? > 2) You write of real-time output. Do you want to simulate a meter that > shows the actual volume at any instant? > 3) So-called equal-loudness curves depend very much on the gain settings > when the material was recorded. What you need to do is much simpler > if you can ignore Fletcher-Munsen.
My goal is to "normalize" the volume from different sources (video games) so that the loudest parts of each one are similar. The problem is that some games have sounds that are very low such as old discrete electronics explosions to sounds that are very high. Given this, do you think I could ignore Fletcher-Munsen? What technique would you recommend I try? Thanks, SA Dev
SA Dev wrote:
> Hi Jerry, > > >>1) To measure volume, what do you want with frequency? >>2) You write of real-time output. Do you want to simulate a meter that >> shows the actual volume at any instant? >>3) So-called equal-loudness curves depend very much on the gain settings >> when the material was recorded. What you need to do is much simpler >> if you can ignore Fletcher-Munsen. > > > My goal is to "normalize" the volume from different sources (video games) so > that the loudest parts of each one are similar. The problem is that some > games have sounds that are very low such as old discrete electronics > explosions to sounds that are very high. Given this, do you think I could > ignore Fletcher-Munsen? What technique would you recommend I try? > > Thanks, > > SA Dev
You can't normalize a whole file to make its loudest sound match the loudest sound in some other file in real time. I can't even imagine what that might mean. AGC was discussed in this connection before, but that doesn't seem to do what you want. There is probably a design for a digital VU meter somewhere that you can have; look for it with Google. If you want to account for the ear's selective sensitivity, Google for an A-weighting filter. For a simple approximation to the whole setup, make a filter with a broad peak around 1.5 KHz, square the samples out if it, and feed them to a leaky integrator aka a simple low-pass, and remember the largest output from that. That number will pretty well indicate the loudest that file ever gets. After you have a number for each of your sound tracks, use the inverses to set the playback gain. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
As I recall, the presense of DC is what was tripping you up before. I recommend that you run the signal through a high-pass filter, calculate the power in the result, and use that as the gain control. I also don't see why you need to do this in real-time. You could simply adjust the volume manually on each game until it sounds right to you, and then save and use the adjusted results. Then you could throw the CPU at other tasks (such as video rendering). -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 The secret to enjoying your job is to have a hobby that's even worse - Calvin's Dad
Jim Thomas <jthomas@bittware.com> wrote in message
news:106h28brqevda47@corp.supernews.com...
> SA Dev wrote: > > My goal is to "normalize" the volume from different sources (video games) so > > that the loudest parts of each one are similar. The problem is that some > > games have sounds that are very low such as old discrete electronics > > explosions to sounds that are very high. Given this, do you think I could > > ignore Fletcher-Munsen? What technique would you recommend I try? > > As I recall, the presense of DC is what was tripping you up before. I > recommend that you run the signal through a high-pass filter, calculate > the power in the result, and use that as the gain control. > > I also don't see why you need to do this in real-time. You could simply > adjust the volume manually on each game until it sounds right to you, > and then save and use the adjusted results. Then you could throw the > CPU at other tasks (such as video rendering).
I think the idea was to automate this, i.e. no matter what video game was playing, the volume sounded "right" with no need to tell the software what the game was. I get the impression that the OP doesn't have access to the original sound effects at all, he just gets an audio feed. If I'm on the right track, I think Jim's suggestion of a AGC based on a high-pass version of the audio is right on the money. However, based on previous posts, I'm not sure the OP has the know-how to make this work without quite a bit more research...
Hi Jon,
> I think the idea was to automate this, i.e. no matter what video game was > playing, the volume sounded "right" with no need to tell the software what
the
original
track, I
is
has
Yes, that is exactly right. Can you post some links where I can investigate "AGC based on a high-pass version of the audio"? I'm willing to learn... Thanks, Alan
Jon,
track, I
is
> right on the money.
Ok, I think I'm understanding at least what you are suggesting. If I create a high-pass version of the audio (a version of the audio which cuts out the lower frequencies leaving only the higher ones?), and run an AGC on this higher version, it will determine a ratio I can use to alter the original version of the audio? I'm guessing that the reason for the high-pass version is because these are the sounds that are loudest to the ear and in a sense I will be ignoring the low frequency rumbles that have been throwing me off? If this is right, do you have any C code examples of producing a high pass version (is this a low pass filter?), and/or AGC code? Thanks, SA Dev
SA Dev wrote:
> Ok, I think I'm understanding at least what you are suggesting. If I create > a high-pass version of the audio (a version of the audio which cuts out the > lower frequencies leaving only the higher ones?), and run an AGC on this > higher version, it will determine a ratio I can use to alter the original > version of the audio?
Yes.
> I'm guessing that the reason for the high-pass > version is because these are the sounds that are loudest to the ear and in a > sense I will be ignoring the low frequency rumbles that have been throwing > me off?
Well... kinda. The ear is completely deaf to DC, but a typical AGC circuit is not. The high pass removes that.
> > If this is right, do you have any C code examples of producing a high pass > version (is this a low pass filter?), and/or AGC code?
How about some psuedo code? First calculate the DC value (init dc to 0): dc = a * dc + (1-a)*input; Here, "a" should be a number close to but less than 1.0. The closer it is to 1.0, the sharper the filter, but the longer it will take to converge. Once you have the DC, you can subtract it out from the input to get the output: hp_out = input - dc; Now for the AGC portion. This is untested code, and it could probably be done better. It certainly needs tuning. rect = abs(hp_out); // rectify the high pass if (rect > envelope) // if it's bigger than the envelope, attack { envelope += (rect-envelope) * attack; } else // the signal is smaller than envelope, so decay { envelope *= decay; } attack and decay are tuneable constants. decay should be a little less than 1.0. The closer it is to 1.0, the longer it will take for the gain to rise up in the presense of a weak signal. attack should also be less than one. The closer it is to one, the quicker the gain will decrease with the onset of a strong signal. I guess it could be pretty small. Once you have the envelope of the signal, you can come up with a gain value, but you need to have both a maximum and a minimum gain. if (envelope < too_weak) gain = max_gain; else if (envelope > too_strong) gain = min_gain; else gain = env2gain(envelope); I'm too lazy to figure out the env2gain function for you, but it should produce max_gain when passed an envelope == too_weak, and it should produce min_gain when env==too_strong. You will probably want too_weak*max_gain < too_strong*min_gain, so that quiet parts ARE quieter - just not so MUCH quieter than before. Finally, apply the gain to the signal. You can use either the original signal, or the output of the high pass. I'd be inclined to use the high-pass output - otherwise, you might clip: output = hp_out * gain; -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 I'm Jim Thomas, and I approve this message.
