I'm trying to implement the image search described here http://www.dspguide.com/ch24/6.htm. I have to check for existence of a target image. Upon convolution we will have some values, each value proportional to the match. There may one or more maximas depending on repetition of the target. so is the case If target does not exist in the source image.Although in the latter case, values will be far lower in magnitude. Yet, how could one conclusively say if target does exist in the source?
Image search
Started by ●November 13, 2008
Reply by ●November 14, 20082008-11-14
>Yet, how could one conclusively say if target does exist in the >source?You can't. As the peak becomes higher above the noise, it is less likely that the peak is just a random result of the noise. That is, as the peak becomes higher, the probability of the target being present approaches 100%, but never exactly becomes 100%. You simply have to set an arbitray threshold for a yes/no answer. Regards, Steve
