Hello, Bear with me while I explain my situation here. I have a test setup. This test setup is a big analog contraption that works when I connect a wire between two aluminum blocks within the test setup. The contraption "comes to life" when the wire is connected and "dies off" when the wire is disconnected. Don't worry about the "comes alive" and "dies off". Don't even worry about what the rest of the contraption is there isn't any more information there on what the signal is other than what I will relate here. The important thing is that I have a signal in a wire and I can tell when it is there and when it isn't by behavior of the system at large. I know that the signal is contained within 100 Hz centered at 5 kHz. When I put my test setup in an anechoic chamber and look at the signal in the wire with one of Agilent's best spectrum analyzers, I can see no power attributable to this signal. All I see is noise. Even when I integrate the signal over long periods of time. So apparently this signal doesn't come out of the noise using an FFT. I can break the wire and put one end into a laptop sound input and bring the other end out of the output. I can run Spectrum Lab (DL4YHFs free and excellent software) and do an FFT on the input, filter the signal, and output the signal and the system at large will work. If I pass any 30 Hz band between 4.95 and 5.05 kHz the system "comes alive" and if I move the filter down to say 4.9 kHz, the system dies off. So obviously with a sound card I am capturing this signal, which is somewhat bizarre because I can't see any power with that Agilent setup which has a noise floor way down below the sound card setup. I have recorded this digital signal that I have captured and tried to looked at the power spectral density with Matlab and can't see anything. I already tried listening for the signal and I can't pick it out by ear. What I would like to do is capture the signal in real time with Matlab and then insert various filters, then output the signal and see what kills the signal and what allows it to pass. I almost have the Matlab framework for this in place but my problem is that I don't know what filters to use and once I do figure out some filters, how do I interpret the results? For example if I use filter x and change the y parameter to five different values and the first three work, what will that tell me about the signal. I would greatly appreciate any suggestions on what filters to use, what parameters to change, and some insight into what that would mean for what the signal is. Thank you! -xerxes
Elusive signal in the noise
Started by ●November 23, 2008
Reply by ●November 23, 20082008-11-23
xerxes73 wrote:> Hello, > > Bear with me while I explain my situation here. I have a test setup. > This test setup is a big analog contraption that works when I connect a > wire between two aluminum blocks within the test setup. The contraption > "comes to life" when the wire is connected and "dies off" when the wire is > disconnected. Don't worry about the "comes alive" and "dies off". Don't > even worry about what the rest of the contraption is there isn't any more > information there on what the signal is other than what I will relate here. > The important thing is that I have a signal in a wire and I can tell when > it is there and when it isn't by behavior of the system at large. > > I know that the signal is contained within 100 Hz centered at 5 kHz. When > I put my test setup in an anechoic chamber and look at the signal in the > wire with one of Agilent's best spectrum analyzers, I can see no power > attributable to this signal. All I see is noise. Even when I integrate > the signal over long periods of time. So apparently this signal doesn't > come out of the noise using an FFT. > > I can break the wire and put one end into a laptop sound input and bring > the other end out of the output. I can run Spectrum Lab (DL4YHFs free and > excellent software) and do an FFT on the input, filter the signal, and > output the signal and the system at large will work. If I pass any 30 Hz > band between 4.95 and 5.05 kHz the system "comes alive" and if I move the > filter down to say 4.9 kHz, the system dies off. So obviously with a sound > card I am capturing this signal, which is somewhat bizarre because I can't > see any power with that Agilent setup which has a noise floor way down > below the sound card setup. > > I have recorded this digital signal that I have captured and tried to > looked at the power spectral density with Matlab and can't see anything. > > I already tried listening for the signal and I can't pick it out by ear. > > What I would like to do is capture the signal in real time with Matlab and > then insert various filters, then output the signal and see what kills the > signal and what allows it to pass. I almost have the Matlab framework for > this in place but my problem is that I don't know what filters to use and > once I do figure out some filters, how do I interpret the results? For > example if I use filter x and change the y parameter to five different > values and the first three work, what will that tell me about the signal. > I would greatly appreciate any suggestions on what filters to use, what > parameters to change, and some insight into what that would mean for what > the signal is.Is it an acoustic signal? If not, what is the use of an anechoic chamber? You might try analyzing the system with a Hieronymus machine. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>xerxes73 wrote: >> Hello, >> >> Bear with me while I explain my situation here. I have a test setup. >> This test setup is a big analog contraption that works when I connecta>> wire between two aluminum blocks within the test setup. Thecontraption>> "comes to life" when the wire is connected and "dies off" when the wireis>> disconnected. Don't worry about the "comes alive" and "dies off".Don't>> even worry about what the rest of the contraption is there isn't anymore>> information there on what the signal is other than what I will relatehere.>> The important thing is that I have a signal in a wire and I can tellwhen>> it is there and when it isn't by behavior of the system at large. >> >> I know that the signal is contained within 100 Hz centered at 5 kHz.When>> I put my test setup in an anechoic chamber and look at the signal inthe>> wire with one of Agilent's best spectrum analyzers, I can see no power >> attributable to this signal. All I see is noise. Even when Iintegrate>> the signal over long periods of time. So apparently this signaldoesn't>> come out of the noise using an FFT. >> >> I can break the wire and put one end into a laptop sound input andbring>> the other end out of the output. I can run Spectrum Lab (DL4YHFs freeand>> excellent software) and do an FFT on the input, filter the signal, and >> output the signal and the system at large will work. If I pass any 30Hz>> band between 4.95 and 5.05 kHz the system "comes alive" and if I movethe>> filter down to say 4.9 kHz, the system dies off. So obviously with asound>> card I am capturing this signal, which is somewhat bizarre because Ican't>> see any power with that Agilent setup which has a noise floor way down >> below the sound card setup. >> >> I have recorded this digital signal that I have captured and tried to >> looked at the power spectral density with Matlab and can't seeanything.>> >> I already tried listening for the signal and I can't pick it out byear.>> >> What I would like to do is capture the signal in real time with Matlaband>> then insert various filters, then output the signal and see what killsthe>> signal and what allows it to pass. I almost have the Matlab frameworkfor>> this in place but my problem is that I don't know what filters to useand>> once I do figure out some filters, how do I interpret the results?For>> example if I use filter x and change the y parameter to five different >> values and the first three work, what will that tell me about thesignal.>> I would greatly appreciate any suggestions on what filters to use,what>> parameters to change, and some insight into what that would mean forwhat>> the signal is. > >Is it an acoustic signal? If not, what is the use of an anechoic >chamber? You might try analyzing the system with a Hieronymus machine. > >Jerry >-- >Engineering is the art of making what you want from things you can get. >�����������������������������������������������������������������������The anechoic chamber is just for a quiet RF space in those frequencies, i.e. just dropping the noise floor so the power of the signal would be visible. It wasn't. The Heironymus machine is an "interesting" idea, but I would like to know what filtering methods I use to pull a hard to find signal out of a captured digital stream of data.... -xerxes
xerxes73 wrote:>> xerxes73 wrote: >>> Hello, >>> >>> Bear with me while I explain my situation here. I have a test setup. >>> This test setup is a big analog contraption that works when I connect > a >>> wire between two aluminum blocks within the test setup. The > contraption >>> "comes to life" when the wire is connected and "dies off" when the wire > is >>> disconnected. Don't worry about the "comes alive" and "dies off". > Don't >>> even worry about what the rest of the contraption is there isn't any > more >>> information there on what the signal is other than what I will relate > here. >>> The important thing is that I have a signal in a wire and I can tell > when >>> it is there and when it isn't by behavior of the system at large. >>> >>> I know that the signal is contained within 100 Hz centered at 5 kHz. > When >>> I put my test setup in an anechoic chamber and look at the signal in > the >>> wire with one of Agilent's best spectrum analyzers, I can see no power >>> attributable to this signal. All I see is noise. Even when I > integrate >>> the signal over long periods of time. So apparently this signal > doesn't >>> come out of the noise using an FFT. >>> >>> I can break the wire and put one end into a laptop sound input and > bring >>> the other end out of the output. I can run Spectrum Lab (DL4YHFs free > and >>> excellent software) and do an FFT on the input, filter the signal, and >>> output the signal and the system at large will work. If I pass any 30 > Hz >>> band between 4.95 and 5.05 kHz the system "comes alive" and if I move > the >>> filter down to say 4.9 kHz, the system dies off. So obviously with a > sound >>> card I am capturing this signal, which is somewhat bizarre because I > can't >>> see any power with that Agilent setup which has a noise floor way down >>> below the sound card setup. >>> >>> I have recorded this digital signal that I have captured and tried to >>> looked at the power spectral density with Matlab and can't see > anything. >>> I already tried listening for the signal and I can't pick it out by > ear. >>> What I would like to do is capture the signal in real time with Matlab > and >>> then insert various filters, then output the signal and see what kills > the >>> signal and what allows it to pass. I almost have the Matlab framework > for >>> this in place but my problem is that I don't know what filters to use > and >>> once I do figure out some filters, how do I interpret the results? > For >>> example if I use filter x and change the y parameter to five different >>> values and the first three work, what will that tell me about the > signal. >>> I would greatly appreciate any suggestions on what filters to use, > what >>> parameters to change, and some insight into what that would mean for > what >>> the signal is. >> Is it an acoustic signal? If not, what is the use of an anechoic >> chamber? You might try analyzing the system with a Hieronymus machine. >> >> Jerry >> -- >> Engineering is the art of making what you want from things you can get. > The anechoic chamber is just for a quiet RF space in those frequencies, > i.e. just dropping the noise floor so the power of the signal would be > visible.There's no reason to think that an anechoic chamber would provide any electromagnetic shielding. Do you perhaps mean a screen room?> It wasn't. The Heironymus machine is an "interesting" idea, but > I would like to know what filtering methods I use to pull a hard to find > signal out of a captured digital stream of data.... -xerxesWell, a Heironymus machine is said to be uniquely capable of responding to signals that aren't there. Jerry -- Engineering is the art of making what you want from things you can get.
>>> -- >>> Engineering is the art of making what you want from things you canget.>> The anechoic chamber is just for a quiet RF space in thosefrequencies,>> i.e. just dropping the noise floor so the power of the signal would be >> visible. It wasn't. > >There's no reason to think that an anechoic chamber would provide any >electromagnetic shielding. Do you perhaps mean a screen room?The wikipedia article on anechoic chambers indicates that I am using the term correctly: http://en.wikipedia.org/wiki/Anechoic_chamber although it would probably be clearer if I said rf anechoic chamber.> >> The Heironymus machine is an "interesting" idea, but >> I would like to know what filtering methods I use to pull a hard tofind>> signal out of a captured digital stream of data.... -xerxes > >Well, a Heironymus machine is said to be uniquely capable of responding >to signals that aren't there. >This is a signal that is clearly there but invisible in the digital analysis I have done thus far. Perhaps a filter based on wavelets will detect a signal that is invisible to an fft because of the nature of the fft as it grabs a large chunk of data in time. The wavelet grabbing differently scaled time data may pick this up but I don't have enough experience to know if this is worth implementing or not. Or perhaps some sort of adaptive filter. That's what I am looking for advice on what filters to use when an fft-based filter is not working. Thanks. -xerxes
Reply by ●November 24, 20082008-11-24
xerxes73 wrote:>>>> -- >>>> Engineering is the art of making what you want from things you can > get. >>> The anechoic chamber is just for a quiet RF space in those > frequencies, >>> i.e. just dropping the noise floor so the power of the signal would be >>> visible. It wasn't. >> There's no reason to think that an anechoic chamber would provide any >> electromagnetic shielding. Do you perhaps mean a screen room? > > The wikipedia article on anechoic chambers indicates that I am using the > term correctly: http://en.wikipedia.org/wiki/Anechoic_chamber although it > would probably be clearer if I said rf anechoic chamber.As I read that article, RF anechoic chambers are used at microwave frequencies to prevent reflections off the walls, floor, and ceiling of signals generated inside the chamber. Acoustic chambers also greatly attenuate sound from outside. The low frequencies you use are not amenable to anechoic techniques in structures of reasonable size. (The wavelength of EM radiation at 5 KHz is 37.5 miles.) Rour anexhoic chamber _may_ include electrostatic shielding (Faraday shield). If it does, it is also a screen room.>>> The Heironymus machine is an "interesting" idea, but >>> I would like to know what filtering methods I use to pull a hard to > find >>> signal out of a captured digital stream of data.... -xerxes >> Well, a Heironymus machine is said to be uniquely capable of responding >> to signals that aren't there.I meant it as a joke. http://en.wikipedia.org/wiki/Hieronymus_machine> This is a signal that is clearly there but invisible in the digital > analysis I have done thus far. Perhaps a filter based on wavelets will > detect a signal that is invisible to an fft because of the nature of the > fft as it grabs a large chunk of data in time. The wavelet grabbing > differently scaled time data may pick this up but I don't have enough > experience to know if this is worth implementing or not. Or perhaps some > sort of adaptive filter. That's what I am looking for advice on what > filters to use when an fft-based filter is not working. Thanks. -xerxesKnowledge of how the signal is generated and what it affects should put a lower limit on its strength. Recall that if the circuit impedance is very low, measuring voltage could be futile. Can you measure the current in the wire? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>> The wikipedia article on anechoic chambers indicates that I am usingthe>> term correctly: http://en.wikipedia.org/wiki/Anechoic_chamber althoughit>> would probably be clearer if I said rf anechoic chamber. > >As I read that article, RF anechoic chambers are used at microwave >frequencies to prevent reflections off the walls, floor, and ceiling of >signals generated inside the chamber. Acoustic chambers also greatly >attenuate sound from outside. The low frequencies you use are not >amenable to anechoic techniques in structures of reasonable size. (The >wavelength of EM radiation at 5 KHz is 37.5 miles.) Rour anexhoic >chamber _may_ include electrostatic shielding (Faraday shield). If it >does, it is also a screen room. >Ah, I see. That's right that kHz will go through most things. I went back through my notes (it was about a year and a half ago that it was in the chamber). We actually built another faraday cage in the chamber to get the noise way down there. We didn't see it with an FFT and a really low noise floor.>>>> The Heironymus machine is an "interesting" idea, but >>>> I would like to know what filtering methods I use to pull a hard to >> find >>>> signal out of a captured digital stream of data.... -xerxes >>> Well, a Heironymus machine is said to be uniquely capable ofresponding>>> to signals that aren't there. > >I meant it as a joke. http://en.wikipedia.org/wiki/Hieronymus_machine >Okay good. I was worried about bringing this conversation back to hardcore dsp techniques.>> This is a signal that is clearly there but invisible in the digital >> analysis I have done thus far. Perhaps a filter based on waveletswill>> detect a signal that is invisible to an fft because of the nature ofthe>> fft as it grabs a large chunk of data in time. The wavelet grabbing >> differently scaled time data may pick this up but I don't have enough >> experience to know if this is worth implementing or not. Or perhapssome>> sort of adaptive filter. That's what I am looking for advice on what >> filters to use when an fft-based filter is not working. Thanks.-xerxes> >Knowledge of how the signal is generated and what it affects should put >a lower limit on its strength. Recall that if the circuit impedance is >very low, measuring voltage could be futile. Can you measure the current>in the wire? >I did try a Keithley 6430 Electrometer which is a heck of an instrument but just connecting the electrometer seemed to screw up the signal both when trying to measure amperage and voltage. It is an extremely low impedance I believe. I can't say I am an expert in this though so perhaps I could have done it better. I talked it over with their app engineers quite a bit and although they were very helpful, we couldn't figure out an approach that worked. It seems like the signal is right in front of me now in this captured data but I can't figure out a way to figure out what it is. Very strange.
christopher wrote: ...> I have recorded this digital signal that I have captured and tried to > looked at the power spectral density with Matlab and can't see anything.Can you post the data for download?
xerxes73 wrote: I wrote>> Knowledge of how the signal is generated and what it affects should put >> a lower limit on its strength. Recall that if the circuit impedance is >> very low, measuring voltage could be futile. Can you measure the current >> in the wire? >> > I did try a Keithley 6430 Electrometer which is a heck of an instrument > but just connecting the electrometer seemed to screw up the signal both > when trying to measure amperage and voltage. It is an extremely low > impedance I believe. I can't say I am an expert in this though so perhaps > I could have done it better. I talked it over with their app engineers > quite a bit and although they were very helpful, we couldn't figure out an > approach that worked. It seems like the signal is right in front of me now > in this captured data but I can't figure out a way to figure out what it > is. Very strange.An electrometer is a voltmeter with an extremely high impedance. The 6430 is a sub-femtoamp instrument. Since you can apparently break the wire to run the signal through a computer's sound card, it can't be low impedance. I hadn't considered that bit you wrote. Since the computer can deal with the signal, it must see it. Why don't you record what the computer sees? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
