i have implemented MUSIC and ESPRIT algorithm using Matlab.i want to know what are the variations or modifications that can be done to these algorithms.i have studied effect of varying SNR,antenna elements,angular separation on these algorithms.but something more is required.
DOA estimation
Started by ●November 27, 2008
Reply by ●November 27, 20082008-11-27
On 27 Nov, 14:29, preetigup...@gmail.com wrote:> i have implemented MUSIC and ESPRIT algorithm using Matlab.i want to > know what are the variations or modifications �that can be done to > these algorithms.i have studied effect of varying SNR,antenna > elements,angular separation on these algorithms.but something more is > required.With ESPRIT you can check the Least Means Square method against the Total Least Squares method. With MUSIC you can check e.g. Classical MUSIC agains Root MUSIC (I remember having read somewhere about a Pop MUSIC variation too...) The most interesting tests are with model mis-match scenarios. Both these methods are designed with a non-damped unscaled expunential signal in mind. Try them with either a damping term or a scale term and see how well they perform. Then try and increase the number of signals. At some point, near N/2 where N is the number of elements in the array, you might notice some changes in the behaviour of the methods. Rune
Reply by ●November 28, 20082008-11-28
>On 27 Nov, 14:29, preetigup...@gmail.com wrote: >> i have implemented MUSIC and ESPRIT algorithm using Matlab.i want to >> know what are the variations or modifications =A0that can be done to >> these algorithms.i have studied effect of varying SNR,antenna >> elements,angular separation on these algorithms.but something more is >> required. > >With ESPRIT you can check the Least Means Square method >against the Total Least Squares method. With MUSIC you >can check e.g. Classical MUSIC agains Root MUSIC (I remember >having read somewhere about a Pop MUSIC variation too...) > >The most interesting tests are with model mis-match scenarios. >Both these methods are designed with a non-damped unscaled >expunential signal in mind. Try them with either a damping term >or a scale term and see how well they perform. Then try and >increase the number of signals. At some point, near N/2 where >N is the number of elements in the array, you might notice >some changes in the behaviour of the methods. > >Rune >thanks for replying.i cant compare LS-ESPRIT with TLS.cant work with existing methods.have to do some little modification in MUSIC and ESPRIT.i am not getting your point that how to use damping term or scale term.can you give an example that what exactly signal can i take.it will be of help. Preeti
On 28 Nov, 13:59, "preetigupta" <preeti_engin...@yahoo.com> wrote:> >On 27 Nov, 14:29, preetigup...@gmail.com wrote: > >> i have implemented MUSIC and ESPRIT algorithm using Matlab.i want to > >> know what are the variations or modifications =A0that can be done to > >> these algorithms.i have studied effect of varying SNR,antenna > >> elements,angular separation on these algorithms.but something more is > >> required. > > >With ESPRIT you can check the Least Means Square method > >against the Total Least Squares method. With MUSIC you > >can check e.g. Classical MUSIC agains Root MUSIC (I remember > >having read somewhere about a Pop MUSIC variation too...) > > >The most interesting tests are with model mis-match scenarios. > >Both these methods are designed with a non-damped unscaled > >expunential signal in mind. Try them with either a damping term > >or a scale term and see how well they perform. Then try and > >increase the number of signals. At some point, near N/2 where > >N is the number of elements in the array, you might notice > >some changes in the behaviour of the methods. > > >Rune > > thanks for replying.i cant compare LS-ESPRIT with TLS.cant work with > existing methods.have to do some little modification in MUSIC and ESPRIT.i > am not getting your point that how to use damping term or scale term.can > you give an example that what exactly signal can i take.it will be of > help.The basic signal model for MUSIC and ESPRIT is the complex exponential s(x) = exp(jkx) where k is the wavenumber you use to derive the DoA, k = cos(phi)/c. In the real world there will be a damping term, s(x) = exp(jkx + ax) and with point sources there might be scaling terms as well, if you measure the signal close to the source s(x) = 1/sqrt(kx) exp(jkx). So try and model the signals with daming terms or scaling terms, and see how well the DoA estimators perform. - How large daming terms can they cope with? - How close to the source can you get and still get good results? And so on. Rune
Reply by ●December 2, 20082008-12-02
>On 28 Nov, 13:59, "preetigupta" <preeti_engin...@yahoo.com> wrote: >> >On 27 Nov, 14:29, preetigup...@gmail.com wrote: >> >> i have implemented MUSIC and ESPRIT algorithm using Matlab.i wantto>> >> know what are the variations or modifications =A0that can be doneto>> >> these algorithms.i have studied effect of varying SNR,antenna >> >> elements,angular separation on these algorithms.but something moreis>> >> required. >> >> >With ESPRIT you can check the Least Means Square method >> >against the Total Least Squares method. With MUSIC you >> >can check e.g. Classical MUSIC agains Root MUSIC (I remember >> >having read somewhere about a Pop MUSIC variation too...) >> >> >The most interesting tests are with model mis-match scenarios. >> >Both these methods are designed with a non-damped unscaled >> >expunential signal in mind. Try them with either a damping term >> >or a scale term and see how well they perform. Then try and >> >increase the number of signals. At some point, near N/2 where >> >N is the number of elements in the array, you might notice >> >some changes in the behaviour of the methods. >> >> >Rune >> >> thanks for replying.i cant compare LS-ESPRIT with TLS.cant work with >> existing methods.have to do some little modification in MUSIC andESPRIT.i>> am not getting your point that how to use damping term or scaleterm.can>> you give an example that what exactly signal can i take.it will be of >> help. > >The basic signal model for MUSIC and ESPRIT is the complex >exponential > >s(x) = exp(jkx) > >where k is the wavenumber you use to derive the DoA, > >k = cos(phi)/c. > >In the real world there will be a damping term, > >s(x) = exp(jkx + ax) > >and with point sources there might be scaling terms >as well, if you measure the signal close to the source > >s(x) = 1/sqrt(kx) exp(jkx). > >So try and model the signals with daming terms or scaling >terms, and see how well the DoA estimators perform. > >- How large daming terms can they cope with? >- How close to the source can you get and still > get good results? > >And so on. > >Rune > >Thanks for giving such valuable information.but i am facing problem.when i add damping terms to my algorithm,then it is not giving accurate results.i have tried both positive and negative term for damping.can u help. Preeti
On 2 Des, 11:39, "preetigupta" <preeti_engin...@yahoo.com> wrote:> >On 28 Nov, 13:59, "preetigupta" <preeti_engin...@yahoo.com> wrote: > >> >On 27 Nov, 14:29, preetigup...@gmail.com wrote: > >> >> i have implemented MUSIC and ESPRIT algorithm using Matlab.i want > to > >> >> know what are the variations or modifications =A0that can be done > to > >> >> these algorithms.i have studied effect of varying SNR,antenna > >> >> elements,angular separation on these algorithms.but something more > is > >> >> required. > > >> >With ESPRIT you can check the Least Means Square method > >> >against the Total Least Squares method. With MUSIC you > >> >can check e.g. Classical MUSIC agains Root MUSIC (I remember > >> >having read somewhere about a Pop MUSIC variation too...) > > >> >The most interesting tests are with model mis-match scenarios. > >> >Both these methods are designed with a non-damped unscaled > >> >expunential signal in mind. Try them with either a damping term > >> >or a scale term and see how well they perform. Then try and > >> >increase the number of signals. At some point, near N/2 where > >> >N is the number of elements in the array, you might notice > >> >some changes in the behaviour of the methods. > > >> >Rune > > >> thanks for replying.i cant compare LS-ESPRIT with TLS.cant work with > >> existing methods.have to do some little modification in MUSIC and > ESPRIT.i > >> am not getting your point that how to use damping term or scale > term.can > >> you give an example that what exactly signal can i take.it will be of > >> help. > > >The basic signal model for MUSIC and ESPRIT is the complex > >exponential > > >s(x) = exp(jkx) > > >where k is the wavenumber you use to derive the DoA, > > >k = cos(phi)/c. > > >In the real world there will be a damping term, > > >s(x) = exp(jkx + ax) > > >and with point sources there might be scaling terms > >as well, if you measure the signal close to the source > > >s(x) = 1/sqrt(kx) exp(jkx). > > >So try and model the signals with daming terms or scaling > >terms, and see how well the DoA estimators perform. > > >- How large daming terms can they cope with? > >- How close to the source can you get and still > > �get good results? > > >And so on. > > >Rune > > Thanks for giving such valuable information.but i am facing problem.when i > add damping terms to my algorithm,then it is not giving accurate results.i > have tried both positive and negative term for damping.can u help.That's what the test was intended to demonstrate. There is nothing you can do about that, other than do tests and see how sensitive the DoA estimate is with respect to all these terms that are not included in the sum-of-sines signal. Rune
