Hi all, In ofdma the preamble is of 2 symbol long first one consist of 4 shorth and then long of some sequence. how do we use second symbol preamble (or long preamble) to find the freq response of channel to train equalizer? currently when i do a cross correlation of a preamble received after channel with known sequence of preamble i don't see the frequency response of the channel am i doing something wrong??
channel estimation in ofdm using preamble
Started by ●December 3, 2008
Reply by ●December 3, 20082008-12-03
On Wed, 03 Dec 2008 09:23:16 -0600, "adi_sharma1984" <sharmaa@rohan.sdsu.edu> wrote:>Hi all, > >In ofdma the preamble is of 2 symbol long first one consist of 4 shorth >and then long of some sequence. > >how do we use second symbol preamble (or long preamble) to find the freq >response of channel to train equalizer? currently when i do a cross >correlation of a preamble received after channel with known sequence of >preamble i don't see the frequency response of the channel am i doing >something wrong?? >Take the FFT of both symbols of the long portion of the preamble. Add them together to suppress the noise. You can use the same FFT that would be used for the demodulation. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
