eric.jacobsen@delete.ieee.org (Eric Jacobsen) writes:> On Tue, 30 Mar 2004 11:52:17 -0500, Raymond Toy <toy@rtp.ericsson.se> > wrote: > >>>>>>> "Randy" == Randy Yates <randy.yates@sonyericsson.com> writes: >> >> Randy> "A BCH code over GF(p)" is a contradiction according to the way it has >> Randy> been presented to me. A BCH code is, BY DEFINITION, a BINARY code, >> Randy> according to my notes. >> >>I had learned that a Reed-Solomon code was a special type of >>(non-binary) BCH code. So I guess it depends on the book you are >>using as your reference. I always take BCH to be the non-binary one, >>unless it's clear from context that some other BCH code is being >>discussed. >> >>Ray > > That's my understanding as well, RS codes are a subset of BCH, not the > other way around. I've seen this classification and description in > multiple places, so I tend to think of them that way. Makes sense to > me as well.Hi Eric/Ray, Could you please give me a reference or two on where RS codes are defined this way? RS codes were defined to us in terms of the Vandermonde matrix over GF(q) of dimension 2*t by n, where t is the number of correctable errors and 2t <= q-1. Here q can be any p^m. Then it was narrowed to BCH codes by the codewords that only have elements over GF(p). -- % Randy Yates % "Ticket to the moon, flight leaves here today %% Fuquay-Varina, NC % from Satellite 2" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
BCH Codes and Reed-Solomon Codes
Started by ●March 26, 2004
Reply by ●March 31, 20042004-03-31
Randy Yates <yates@ieee.org> writes:> [...] > Then it was narrowed to BCH codes by > the codewords that only have elements over GF(p).I should have added "where p = 2". -- % Randy Yates % "So now it's getting late, %% Fuquay-Varina, NC % and those who hesitate %%% 919-577-9882 % got no one..." %%%% <yates@ieee.org> % 'Waterfall', *Face The Music*, ELO http://home.earthlink.net/~yatescr
"Randy Yates" <yates@ieee.org> wrote in message news:u105iohz.fsf@ieee.org...> >> > >>I had learned that a Reed-Solomon code was a special type of > >>(non-binary) BCH code. So I guess it depends on the book you are > >>using as your reference. I always take BCH to be the non-binary one, > >>unless it's clear from context that some other BCH code is being > >>discussed. > >> > >>Ray > > > > That's my understanding as well, RS codes are a subset of BCH, not the > > other way around. I've seen this classification and description in > > multiple places, so I tend to think of them that way. Makes sense to > > me as well. > > Hi Eric/Ray, > > Could you please give me a reference or two on where RS codes are defined > this way?Hello Randy, One classic that describes the RS codes as a special case of the BCH codes is "Error Correcting Codes" by Peterson and Weldon, section 9.2. Another reference that makes this same claim is "Coding and Information Theory" by Roman, section 4.3. I hope this helps. -- Clay S. Turner, V.P. Wireless Systems Engineering, Inc. Satellite Beach, Florida 32937 (321) 777-7889 www.wse.biz csturner@wse.biz> > RS codes were defined to us in terms of the Vandermonde matrix over GF(q) > of dimension 2*t by n, where t is the number of correctable errors and > 2t <= q-1. Here q can be any p^m. Then it was narrowed to BCH codes by > the codewords that only have elements over GF(p). > -- > % Randy Yates % "Ticket to the moon, flight leaves heretoday> %% Fuquay-Varina, NC % from Satellite 2" > %%% 919-577-9882 % 'Ticket To The Moon' > %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra > http://home.earthlink.net/~yatescr
>>>>> "Clay" == Clay S Turner <CSTurner@WSE.Biz> writes:Clay> Hello Randy, Clay> One classic that describes the RS codes as a special case of the BCH codes Clay> is "Error Correcting Codes" by Peterson and Weldon, section 9.2. Another Clay> reference that makes this same claim is "Coding and Information Theory" by Clay> Roman, section 4.3. Add Michelson and Levesque to the list. This is what I used to learn about block codes. Ray
Reply by ●April 1, 20042004-04-01
On Wed, 31 Mar 2004, Raymond Toy wrote:> Add Michelson and Levesque to the list. This is what I used to learn > about block codes. > > Ray >for algebraic block codes, i highly recommend MacWilliams and Sloane's "the theory of error-correcting codes" as your second book. it's a bit dense, but if you are mathematically inclined, it's a very thorough treatment of the subject matter. this book defines Reed-Solomon codes as: "A Reed-Solomon code over GF(q) is a BCH code of length N=q-1. Of course q is never 2. Thus the length is the number of nonzero elements in the ground field." cyclic codes tend to work better over larger finite fields; in fact, if i recall correctly, this is one motivation for Forney's thesis on concatenated codes: if we wish to use these powerful cyclic codes, how do we map it to the channel? of course, this is among other things contributed in the said thesis. julius -- The most rigorous proofs will be shown by vigorous handwaving. http://www.mit.edu/~kusuma opinion of author is not necessarily of the institute
Julius, Ray, Clay, Thank you. --Randy Julius Kusuma <kusuma@mit.edu> writes:> On Wed, 31 Mar 2004, Raymond Toy wrote: > > > Add Michelson and Levesque to the list. This is what I used to learn > > about block codes. > > > > Ray > > > > for algebraic block codes, i highly recommend MacWilliams and Sloane's > "the theory of error-correcting codes" as your second book. it's a bit > dense, but if you are mathematically inclined, it's a very thorough > treatment of the subject matter. > > this book defines Reed-Solomon codes as: > > "A Reed-Solomon code over GF(q) is a BCH code of length N=q-1. Of course > q is never 2. Thus the length is the number of nonzero elements in the > ground field." > > cyclic codes tend to work better over larger finite fields; in fact, if i > recall correctly, this is one motivation for Forney's thesis on > concatenated codes: if we wish to use these powerful cyclic codes, how do > we map it to the channel? of course, this is among other things > contributed in the said thesis. > > julius > > -- > The most rigorous proofs will be shown by vigorous handwaving. > http://www.mit.edu/~kusuma > > opinion of author is not necessarily of the institute-- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
