is 8051 CPU still around?
Started by Nasser Abbasi December 18, 2008
hi;
I bought a used book on Intel 8051 and it has some code (in C) for things
like A/D and such. It seems interesting, but was wondering if this CPU is
still around and if one can buy it from some where?
I thought someone here might know. I googled a little around, and there
seems to be number of sites related to this, even though this is a very old
cpu?. Is it actually still used these days?
Thanks,
--Nasser
Nasser Abbasi <nma@12000.org> wrote:
> I bought a used book on Intel 8051 and it has some code (in C) for things > like A/D and such. It seems interesting, but was wondering if this CPU is > still around and if one can buy it from some where?
I recommend Unicorn Electronics: http://www.unicornelectronics.com/IC/8000.html They even have the 8080 if you are looking for older CPUs, but the 8051 is also there. The 8751 is the version with built-in EPROM, the 8031 is without any internal ROM, which seems to be a better deal. You can also get an 8051 core to load into an FPGA and run it that way. See: http://en.wikipedia.org/wiki/Intel_8051 -- glen
Atmel sells quite cheap 8051-based microcontrollers: 8051 core, some RAM, some FlashROM for code, timers, UART, IO pins, optionally DAC, USB, CAN all in a single chip package. The basic versions are quite cheap, in Germany you can order them for 0.80&#4294967295; in single quantities (89C2051: 2KB Flash, 128B RAM). <http://atmel.com/dyn/products/param_table.asp?family_id=604&OrderBy=part_no&Direction=ASC> Atmel also has a lot of chips based on the more modern and faster AVR architecture. Hendrik vdH
On Thu, 18 Dec 2008 03:08:44 -0800, Nasser Abbasi wrote:
> hi; > > I bought a used book on Intel 8051 and it has some code (in C) for > things like A/D and such. It seems interesting, but was wondering if > this CPU is still around and if one can buy it from some where? > > I thought someone here might know. I googled a little around, and there > seems to be number of sites related to this, even though this is a very > old cpu?. Is it actually still used these days? > > Thanks, > > --Nasser
Intel has stopped making the 8051, but plenty of other manufacturers do -- somehow the core passed into the public domain, so the 8051 has become the least common denominator of 8-bit processors. Atmel, Crystal, Xilinx (as a soft core), Altera (ditto), Dallas, and Analog Devices (as part of an ADC, no less) are all ones that I know of, but there are many many more. -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
> hi; > > I bought a used book on Intel 8051 and it has some code (in C) for things > like A/D and such. It seems interesting, but was wondering if this CPU is > still around and if one can buy it from some where? > > I thought someone here might know. I googled a little around, and there > seems to be number of sites related to this, even though this is a very old > cpu?. Is it actually still used these days?
There are more modern, augmented versions of the 8051 that overcome some of the original's serious shortcomings. The 8052 has a data pointer that can be incremented but not decremented, address-carry arithmetic that needs do be implemented by hand, and other (ahem) infelicities. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Albeit being old fashioned, the x51 is still used in our days. There are the numerous clones of x51 from NXP, Siemens, Atmel, etc. Also, the x51 is often used as the soft core in ASICs. However I wouldn't recommend spending much time learning about this dinosaur. The modern equivalent to x51 are the low end ARM series. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Dec 18, 7:08&#4294967295;pm, "Nasser Abbasi" <n...@12000.org> wrote:
> hi; > > I bought a used book on Intel 8051 and it has some code (in C) for things > like A/D and such. It seems interesting, but was wondering if this CPU is > still around and if one can buy it from some where? > > I thought someone here might know. I googled a little around, and there > seems to be number of sites related to this, even though this is a very old > cpu?. Is it actually still used these days? > > Thanks, > > --Nasser
Every engineering student in China learns the 8051 core in intimate detail. Hence almost every MCU developed in China or Taiwan is based on the 8051, unless it really needs a more powerful core. Its so much easier to sell people something they already know. Mountains of 8051 based MCUs are made each year. Regards, Steve
steveu@coppice.org wrote:
> Every engineering student in China learns the 8051 core in intimate > detail.
Is it because x51 core became generic whereas most other CPUs are proprietary to their vendors?
> Hence almost every MCU developed in China or Taiwan is based > on the 8051, unless it really needs a more powerful core. Its so much > easier to sell people something they already know. > > Mountains of 8051 based MCUs are made each year.
Yes, the x51 is the workhorse of home electronics. But it is an ugly core. Only PIC can be worse. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky wrote:
> Yes, the x51 is the workhorse of home electronics. But it is an ugly > core. Only PIC can be worse.
Nothing is ever so bad that it can't get worse. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 A pessimist is an optimist with experience
i've used the silicon labs f-series a lot:
https://www.silabs.com/products/mcu/pages/default.aspx
i think they are ok: fast, cheap, reliable, good range of feature
sets, relatively easy to debug.
only big problem i have is being locked into stupid proprietary
devchains (silabs IDE, which is free, or Keil uVision, which isn't)...
i've had no luck finding anyone using gcc with these, so far...
On Dec 18, 8:25&#4294967295;am, Vladimir Vassilevsky <antispam_bogus@hotmail.com>
wrote:
> Nasser Abbasi wrote: > > ... > However I wouldn't recommend spending much time learning about this > dinosaur. The modern equivalent to x51 are the low end ARM series.
i like how there's really not much to learn about the 8051 architecture itself: the opcodes: http://www.keil.com/support/man/docs/is51/is51_opcodes.htm and yr device registers, not much else. ARM, on the other hand.... i'm probably never going to read all of this: http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dvi0014a/ar01s04s18.html and hence i will forever be dealing with other people's code between me and the device... for me and others who are not-so-hard-core, its more like working with an OS... for better or worse
