Hello , I am developing a application in which I want to output the data stored in the SDRAM via PPI Interface. The data speed must be around 30 MHZ. In other words PPI_CLK needs to be 30 MHz. I understand that the PPI is clocked through PF15 pin. I also observed that there is a PPI connector (P8) for PF-15 pin on the board. My questions:- 1) How will I clock the PPI interface?? 2) Can I clock the PPI with the external clock/source connected to the "PF15_CAN_STB~" pin in P8. -- Regards, Nithin K S
PPI Interface Clock in BF537 EZLITE Board
Started by ●December 19, 2008
