On Dec 23, 7:35�am, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> Nils <n.pipenbri...@cubic.org> wrote:...> > > If you smear the phase of a sawtooth-wave in a way that the short > > transient disappears it will sound different than a unphased sawtooth. > > I believe this is true, but it doesn't sound as different as > it looks.of course, with two or more loudspeakers (and channels), if some phase change is applied to one channel, but not to another, that will mess up localization. but i see little reason to think that if identical phase changes were applied to both channels, that this would affect the perceived localization much. however, if such a sweeping statement is applied to a single (mono) sound source, i am not sure that this is true at all. rapidly *changing* phases, sure, but a static phase change, i am not very convinced at all that we can hear it. in this post, http://groups.google.com/group/comp.dsp/msg/184713978f96dd4c i listed a short MATLAB program to create a nyquist (or below) bandlimited square wave where the harmonic phases are slowly messed up (slowly enough that the harmonic detuning would not be noticed). the waveform drastically changes shape, but, if your sound reproduction system remains linear (so the peaks are not flattened), i doubt you will hear any difference. r b-j
Halfing biquad filter response
Started by ●December 21, 2008
Reply by ●December 23, 20082008-12-23
