On Dec 29, 8:55�am, Rune Allnor <all...@tele.ntnu.no> wrote:> On 29 Des, 17:29, KP <ken.pra...@gmail.com> wrote: > > > On Dec 27, 10:49�am, Rune Allnor �wrote: > > Because we need to estimate multiple frequencies per sequence, we were > > using a DFT-based method which worked fairly well. �However, due to > > noise, we were having to use sequence lengths longer than can be > > optimally implemented in our processor (due to cache size, etc.). > > There is a significant difference between 'we can not get this to > work' and 'we can not get this to work optimally'. > > If you can get the methods you already tested to work at all, > even suboptimally, use them. If the operational constraints > pose problems, these can be solved by means of faster, larger > computers. Of course, that might take $$$ which might seem like > a big hurdle up front, but on the other hand it *only* takes > $$$ to get a larger faster computer. You don't risk aything > in terms of operational feasability or robustness. > > If you can get the method to work, use it. If it works too > slow for your application, document this fact and apply for > the funding necessary to get more CPU power.There are other reasons to use a shorter sequence length. One is platform motion: the longer the time taken to collect the sequence, the greater the possibility that platform motion will degrade the accuracy of the measurement. Ken P.
Frequency estimation using Fourier coefficients from multiple series
Started by ●December 21, 2008
Reply by ●December 29, 20082008-12-29
