have u got any solution for getting gaussian noise(100 samples) with exactly zero mean and variance=1 in matlab?
gaussian noise
Started by ●December 29, 2008
Reply by ●December 29, 20082008-12-29
>have u got any solution for getting gaussian noise(100 samples) with >exactly zero mean and variance=1 in matlab?help randn
On Dec 29, 10:13�pm, Greg Berchin <gberc...@comicast.net.invalid> wrote:> >have u got any solution for getting gaussian noise(100 samples) with > >exactly zero mean and variance=1 in matlab? > > help randnit will not give the random noise with mean=0 and var=1. mean and var will change as seed value changes. they are not fixed
charanchar wrote:> On Dec 29, 10:13 pm, Greg Berchin <gberc...@comicast.net.invalid> > wrote: >>> have u got any solution for getting gaussian noise(100 samples) with >>> exactly zero mean and variance=1 in matlab? >> help randn > > it will not give the random noise with mean=0 and var=1. mean and var > will change as seed value changes. they are not fixedI think you are confusing a random process with a sample thereof. If you take a Gaussian random process with mean = 0 and variance = 1, and take 100 samples, you will _not_ get sample sets with mean = 0 and variance = 1. What you'll get is samples whose means and variances are themselves random variables, with _expected_ values of 0 and 1, respectively. A Gaussian process that is guaranteed to generate a mean = 0 and variance = 1 for every 100 sample set would not be i.i.r., if it were even possible in general. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
charanchar wrote:> On Dec 29, 10:13 pm, Greg Berchin <gberc...@comicast.net.invalid> > wrote: >>> have u got any solution for getting gaussian noise(100 samples) with >>> exactly zero mean and variance=1 in matlab? >> help randn > > it will not give the random noise with mean=0 and var=1. mean and var > will change as seed value changes. they are not fixedThe seed doesn't affect the statistics. -- Oli
On Dec 29, 10:22�pm, Tim Wescott <t...@seemywebsite.com> wrote:> charanchar wrote: > > On Dec 29, 10:13 pm, Greg Berchin <gberc...@comicast.net.invalid> > > wrote: > >>> have u got any solution for getting gaussian noise(100 samples) with > >>> exactly zero mean and variance=1 in matlab? > >> help randn > > > it will not give the random noise with mean=0 and var=1. mean and var > > will change as seed value changes. they are not fixed > > I think you are confusing a random process with a sample thereof. > > If you take a Gaussian random process with mean = 0 and variance = 1, > and take 100 samples, you will _not_ get sample sets with mean = 0 and > variance = 1. �What you'll get is samples whose means and variances are > themselves random variables, with _expected_ values of 0 and 1, > respectively. > > A Gaussian process that is guaranteed to generate a mean = 0 and > variance = 1 for every 100 sample set would not be i.i.r., if it were > even possible in general. > > -- > > Tim Wescott > Wescott Design Serviceshttp://www.wescottdesign.com > > Do you need to implement control loops in software? > "Applied Control Theory for Embedded Systems" gives you just what it says. > See details athttp://www.wescottdesign.com/actfes/actfes.htmlthank u Tim, that is if we run the process several times, then the average of all means will be zero and var will be 1. am i correct?
charanchar wrote:> On Dec 29, 10:22 pm, Tim Wescott <t...@seemywebsite.com> wrote: >> charanchar wrote: >>> On Dec 29, 10:13 pm, Greg Berchin <gberc...@comicast.net.invalid> >>> wrote: >>>>> have u got any solution for getting gaussian noise(100 samples) with >>>>> exactly zero mean and variance=1 in matlab? >>>> help randn >>> it will not give the random noise with mean=0 and var=1. mean and var >>> will change as seed value changes. they are not fixed >> I think you are confusing a random process with a sample thereof. >> >> If you take a Gaussian random process with mean = 0 and variance = 1, >> and take 100 samples, you will _not_ get sample sets with mean = 0 and >> variance = 1. What you'll get is samples whose means and variances are >> themselves random variables, with _expected_ values of 0 and 1, >> respectively. >> >> A Gaussian process that is guaranteed to generate a mean = 0 and >> variance = 1 for every 100 sample set would not be i.i.r., if it were >> even possible in general. >> >> -- >> >> Tim Wescott >> Wescott Design Serviceshttp://www.wescottdesign.com >> >> Do you need to implement control loops in software? >> "Applied Control Theory for Embedded Systems" gives you just what it says. >> See details athttp://www.wescottdesign.com/actfes/actfes.html > thank u Tim, that is if we run the process several times, then the > average of all means will be zero and var will be 1. am i correct?No. You can only guarantee a particular mean and variance by generating an infinite number of samples. However, given a set of 100 samples, you can normalise them to have zero sample-mean and unit sample-variance. -- Oli
charanchar wrote:> On Dec 29, 10:22 pm, Tim Wescott <t...@seemywebsite.com> wrote: >> charanchar wrote: >>> On Dec 29, 10:13 pm, Greg Berchin <gberc...@comicast.net.invalid> >>> wrote: >>>>> have u got any solution for getting gaussian noise(100 samples) with >>>>> exactly zero mean and variance=1 in matlab? >>>> help randn >>> it will not give the random noise with mean=0 and var=1. mean and var >>> will change as seed value changes. they are not fixed >> I think you are confusing a random process with a sample thereof. >> >> If you take a Gaussian random process with mean = 0 and variance = 1, >> and take 100 samples, you will _not_ get sample sets with mean = 0 and >> variance = 1. What you'll get is samples whose means and variances are >> themselves random variables, with _expected_ values of 0 and 1, >> respectively. >> >> A Gaussian process that is guaranteed to generate a mean = 0 and >> variance = 1 for every 100 sample set would not be i.i.r., if it were >> even possible in general. >> >> -- >> >> Tim Wescott >> Wescott Design Serviceshttp://www.wescottdesign.com >> >> Do you need to implement control loops in software? >> "Applied Control Theory for Embedded Systems" gives you just what it says. >> See details athttp://www.wescottdesign.com/actfes/actfes.html > thank u Tim, that is if we run the process several times, then the > average of all means will be zero and var will be 1. am i correct?No. The average of the means and vars will tend toward 0 and 1 respectively. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Dec 29, 10:43�pm, Oli Charlesworth <ca...@olifilth.co.uk> wrote:> charanchar wrote: > > On Dec 29, 10:22 pm, Tim Wescott <t...@seemywebsite.com> wrote: > >> charanchar wrote: > >>> On Dec 29, 10:13 pm, Greg Berchin <gberc...@comicast.net.invalid> > >>> wrote: > >>>>> have u got any solution for getting gaussian noise(100 samples) with > >>>>> exactly zero mean and variance=1 in matlab? > >>>> help randn > >>> it will not give the random noise with mean=0 and var=1. mean and var > >>> will change as seed value changes. they are not fixed > >> I think you are confusing a random process with a sample thereof. > > >> If you take a Gaussian random process with mean = 0 and variance = 1, > >> and take 100 samples, you will _not_ get sample sets with mean = 0 and > >> variance = 1. �What you'll get is samples whose means and variances are > >> themselves random variables, with _expected_ values of 0 and 1, > >> respectively. > > >> A Gaussian process that is guaranteed to generate a mean = 0 and > >> variance = 1 for every 100 sample set would not be i.i.r., if it were > >> even possible in general. > > >> -- > > >> Tim Wescott > >> Wescott Design Serviceshttp://www.wescottdesign.com > > >> Do you need to implement control loops in software? > >> "Applied Control Theory for Embedded Systems" gives you just what it says. > >> See details athttp://www.wescottdesign.com/actfes/actfes.html > > thank u Tim, that is if we run the process several times, then the > > average of all means will be zero and var will be 1. am i correct? > > No. �You can only guarantee a particular mean and variance by generating > an infinite number of samples. > > However, given a set of 100 samples, you can normalise them to have zero > sample-mean and unit sample-variance. > > -- > Oliyes that is correct. my problem is for phase noise correction algorithm in ofdm system, i want to introduce phase noise as wiener process. for example if we set variance(using randn in matlab) as .1 that var is changing from symbol to symbol by + or - .02. this small change will affect the estimation badly. becoz the ofdm is more sensitive to phase noise
charanchar wrote:> On Dec 29, 10:43 pm, Oli Charlesworth <ca...@olifilth.co.uk> wrote: >> charanchar wrote: >>> On Dec 29, 10:22 pm, Tim Wescott <t...@seemywebsite.com> wrote: >>>> charanchar wrote: >>>>> On Dec 29, 10:13 pm, Greg Berchin <gberc...@comicast.net.invalid> >>>>> wrote: >>>>>>> have u got any solution for getting gaussian noise(100 samples) with >>>>>>> exactly zero mean and variance=1 in matlab? >>>>>> help randn >>>>> it will not give the random noise with mean=0 and var=1. mean and var >>>>> will change as seed value changes. they are not fixed >>>> I think you are confusing a random process with a sample thereof. >>>> If you take a Gaussian random process with mean = 0 and variance = 1, >>>> and take 100 samples, you will _not_ get sample sets with mean = 0 and >>>> variance = 1. What you'll get is samples whose means and variances are >>>> themselves random variables, with _expected_ values of 0 and 1, >>>> respectively. >>>> A Gaussian process that is guaranteed to generate a mean = 0 and >>>> variance = 1 for every 100 sample set would not be i.i.r., if it were >>>> even possible in general. >>>> -- >>>> Tim Wescott >>>> Wescott Design Serviceshttp://www.wescottdesign.com >>>> Do you need to implement control loops in software? >>>> "Applied Control Theory for Embedded Systems" gives you just what it says. >>>> See details athttp://www.wescottdesign.com/actfes/actfes.html >>> thank u Tim, that is if we run the process several times, then the >>> average of all means will be zero and var will be 1. am i correct? >> No. You can only guarantee a particular mean and variance by generating >> an infinite number of samples. >> >> However, given a set of 100 samples, you can normalise them to have zero >> sample-mean and unit sample-variance. >> >> -- >> Oli > > yes that is correct. > my problem is for phase noise correction algorithm in ofdm system, i > want to introduce phase noise as wiener process. for example if we set > variance(using randn in matlab) as .1 that var is changing from symbol > to symbol by + or - .02. this small change will affect the estimation > badly. becoz the ofdm is more sensitive to phase noiseNot sure I understand. randn() should generate a stationary sequence, i.e. the variance of each sample will be the same. What do you mean when you say that the "var is changing from symbol to symbol"? How are you measuring this? -- Oli
