I'm trying to find a 64-point FFT/IFFT core. Target is Actel IGLOO FPGA family. Needs to run fast enough to complete in 3.2us, which is tough in an IGLOO. Actel has a free FFT core but it is not quite fast enough. It's a radix-2 core, which is not optimal for this application. Radix-4 would be better. I've looked at the cfft core on Opencores and it may work for us, but also want to check commercial options. Thanks, Rob
looking for FFT/IFFT core for FPGA
Started by ●January 15, 2009
Reply by ●January 15, 20092009-01-15
On Thu, 15 Jan 2009 10:34:51 -0800, robj wrote:> I'm trying to find a 64-point FFT/IFFT core. Target is Actel IGLOO FPGA > family. Needs to run fast enough to complete in 3.2us, which is tough in > an IGLOO. Actel has a free FFT core but it is not quite fast enough. > It's a radix-2 core, which is not optimal for this application. Radix-4 > would be better. > > I've looked at the cfft core on Opencores and it may work for us, but > also want to check commercial options. > > Thanks, > RobThere's a fellow who hangs out on the fpga newsgroup (comp.fpga?) who does DSP on FPGAs a _lot_. You may be able to get good results by cross- posting over there (if you do, the tidiest thing to do would be to reply to your own post and cross-post it, instead of multiple posting). -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
Tim Wescott wrote: ...> There's a fellow who hangs out on the fpga newsgroup (comp.fpga?) who > does DSP on FPGAs a _lot_.... Do you mean Ray Andraka? He used to be a regular here. http://www.andraka.com/ Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
There are one or two sites with lots of open-source verilog cores, but I do not have the links to them. Googling on something like "open source verilog" produces lots of hits. But often, it is easier to just write your own code than have to interpret and apply someone else's design. Steve
On Jan 15, 12:34�pm, "robj" <r...@abc.net> wrote:> I'm trying to find a 64-point FFT/IFFT core.Check out http://www.dilloneng.com/. They have high performance commercial cores that would be applicable.
Reply by ●January 16, 20092009-01-16
