Hi, Is there a good algorithms to perform soft decision decoding (maybe iterative) for binary BCH codes ? Thanks.
soft decision decoder for binary BCH codes
Started by ●January 19, 2009
Reply by ●January 19, 20092009-01-19
edim <edim0@walla.com> wrote:>Is there a good algorithms to perform soft decision decoding (maybe >iterative) for binary BCH codes ?If the number r of check bits is reasonably small you can use a Viterbi, BCJR, or generalized Viterbi algorithm with 2^r states. Constructing the appropriate trellis is quite simple. The BCJR algorithm will give you the same exact result as a brute-force, maximum-likelyhood decoder that searches all possible codewords. "Small" might mean something like r < 10 or 12, depending on your implementation constraints. For larger r iterative decoding is not a bad idea, but I don't think there's an accepted best way to construct such a decoder. Steve
edim wrote:> Hi, > Is there a good algorithms to perform soft decision decoding (maybe > iterative) for binary BCH codes ?There are two general approaches, but they are not so good. 1) You can use any trellis search algorithm such as Viterbi, M-algorithm or Fano sequential decoder. 2) You can find the nearest valid BCH codeword by hard decision, then construct all codewords within some distance from that word, then check those codewords to find which makes the best match with the signal. Binary BCH codes are designed for the simple algebraic decoding. If the soft decision is meant, then there are *lot* better codes. Why looking for the difficulties? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●January 20, 20092009-01-20
Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote:>Binary BCH codes are designed for the simple algebraic decoding. If the >soft decision is meant, then there are *lot* better codes. Why looking >for the difficulties?I can speculate that sometimes, one is handed a BCH code and needs (or think one needs) to decode it past its hard-decision limit. Furthermore some BCH codes are close to optimal for their length. (Optimal meaning approaching the sphere-packing limit described by Pollara et.al.) A (23,12) Golay code is also a BCH code and there is no more optimal code of the same rate and size. Steve
On Jan 20, 9:36�am, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote:> edim wrote: > > Hi, > > Is there a good algorithms to perform soft decision decoding (maybe > > iterative) for binary BCH codes ? > > There are two general approaches, but they are not so good. > > 1) You can use any trellis search algorithm such as Viterbi, M-algorithm > or Fano sequential decoder. > > 2) You can find the nearest valid BCH codeword by hard decision, then > construct all codewords within some distance from that word, then check > those codewords to find which makes the best match with the signal. > > Binary BCH codes are designed for the simple algebraic decoding. If the > soft decision is meant, then there are *lot* better codes. Why looking > for the difficulties? > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comI tried soft decoding POCSAG once, and it improved performance significantly. The signal you are decoding is usually a given you need to do your best with. Regards, Steve
<steveu@coppice.org> wrote:>I tried soft decoding POCSAG once, and it improved performance >significantly.I would expect maybe 2 dB improvement in AWGN for that code. Steve
"Steve Pope" <spope33@speedymail.org> wrote in message news:gl3jvo$hq4$1@blue.rahul.net...> Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote: > > >Binary BCH codes are designed for the simple algebraic decoding. If the > >soft decision is meant, then there are *lot* better codes. Why looking > >for the difficulties? > > I can speculate that sometimes, one is handed a BCH code and > needs (or think one needs) to decode it past its hard-decision > limit. > > Furthermore some BCH codes are close to optimal for their length. > (Optimal meaning approaching the sphere-packing limit described > by Pollara et.al.) A (23,12) Golay code is also a BCH code > and there is no more optimal code of the same rate and size.IIRC there is a tailbiting convolutional code with the constraint length of only 4, which is equvalent to the binary Golay code (Zigangirov's book). If the soft decision is meant, there is no point in using BCH codes. Vladimir Vassilevsky DSP and Mixed Signal Consultant www.abvolt.com
"Steve Pope" <spope33@speedymail.org> wrote in message news:gl3ma8$kcr$1@blue.rahul.net...> <steveu@coppice.org> wrote: > > >I tried soft decoding POCSAG once, and it improved performance > >significantly. > > I would expect maybe 2 dB improvement in AWGN for that code. >That's about right for AWGN, however the POCSAG decoder is located after the FM discriminator. So I doubt if there will be much difference of soft decision vs hard decision. Vladimir Vassilevsky DSP and Mixed Signal Consultant www.abvolt.com
On Jan 20, 5:58�am, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> wrote:> "Steve Pope" <spop...@speedymail.org> wrote in message > > news:gl3ma8$kcr$1@blue.rahul.net... > > > <ste...@coppice.org> wrote: > > > >I tried soft decoding POCSAG once, and it improved performance > > >significantly. > > > I would expect maybe 2 dB improvement in AWGN for that code. > > That's about right for AWGN, however the POCSAG decoder is located after the > FM discriminator. So I doubt if there will be much difference of soft > decision vs hard decision. > > Vladimir Vassilevsky > DSP and Mixed Signal Consultantwww.abvolt.comWhy can't soft values after FM discriminator provide some gain in a soft decoder? John
