Hello I guess it is one of the most basic topics, but I am not able to understand this topic, mainly because I have not found yet any reference explaining it: I am trying to understand the iterative turbo decoding, but I am still trying to understand the APP decoding part. The computation of gamma implies to find gamma(s',s)=P(yk|xk), being yk the received codeword and xk the transmitted codeword. Ok, my doubt is so simple as: how yk is obtained? It is obtained by means of a soft demodulation algorithm, but I am not acquainted with this topic, and I do not understand the equations which give me the probability of receiving a certain bit of the codeword yk having sent a certain bit of the transmitted codeword xk: gamma(s',s)=P(yk|xk)=Prod_l=1_to_l=n of P(ykl|xkl), being yk=[yk1,yk2,..ykn] and P(ykl|xkl)=1/(sqrt(2*pi)*sigma)*exp(-Eb/(2*sigma^2)*(ykl-a*xkl)^2) being a the fading amplitude of a Gaussian channel. This modulation is given for a BPSK modulation. Well, may you give me any reference in which soft demodulation is explained? Then I think I will be able to understand why these formulas. Thank you
Soft QAM demodulation
Started by ●January 21, 2009
Reply by ●January 21, 20092009-01-21
Crisanquito <crisancost@hotmail.com> wrote:>I guess it is one of the most basic topics, but I am not able to >understand this topic, mainly because I have not found yet any reference >explaining it:>I am trying to understand the iterative turbo decoding, but I am still >trying to understand the APP decoding part.Let me try to state the appropriate expression. The APP that a transmitted bit is a one is P(1) = poss(1) / (poss(1) + poss(0)) where poss(1) = sum over (constellations points p corresponding to a transmitted 1) of poss(1,p) where for additive white noise of variance v and received signal x poss(1,p) = exp(-(x-p)^2/(2*v)) Use a simlar formula for poss(0). You compute P(1) for each transmitted bit. Obviously p, x, and v are computed using the same units (based on the scale of the Cartestian coordinate system upon which you have defined your constellation). For BPSK there is only one constellation point for each possible value of the transmitted bit and the log of this expression reduces to the familiar distance metric used in most Viterbi decoders. For higher-order QAM, either use the full expression, or just use the dominant term in which case you are using the "nearest neighbor approximation" or "slicing" which entails an implementation loss. You are on the right track doing this computation in the probability domain, rather than the log probability domain as the arithmetic (both for this part and within the turbo decoder) is much simpler. Hope this helps. Steve
