Hi all, I've some queries regarding the above subj. 1) QPSK is actually 2 BPSK. Is there any difference in their power? What I understand, Power (P) = [sqrt(real(signal).^2 + imag(signal).^2)].^2 = amplitude.^2 2) If QPSK requires 2P (BPSK needs P), and I transmit both using the same amplitude, will I get 2P for QPSK and 1P for BPSK when I plot it in terms of power? 3) With regards to 2), will the BER get affected if amplitude are the same for both QPSK and BPSK? Thank you. Yingmu
QPSK and BPSK
Started by ●January 21, 2009
Reply by ●January 21, 20092009-01-21
On Jan 21, 10:17�am, "yingmu" <yingm...@yahoo.com.sg> wrote:> Hi all, > > I've some queries regarding the above subj. > > 1) QPSK is actually 2 BPSK. Is there any difference in their power? �What > I understand, Power (P) = [sqrt(real(signal).^2 + imag(signal).^2)].^2 > � � � � � � � � � � = amplitude.^2 > > 2) If QPSK requires 2P (BPSK needs P), and I transmit both using the same > amplitude, will I get 2P for QPSK and 1P for BPSK when I plot it in terms > of power? > > 3) With regards to 2), will the BER get affected if amplitude are the same > for both QPSK and BPSK? > > Thank you. > > YingmuI can provide you answers to within 3 dB.
On Jan 21, 10:17�am, "yingmu" <yingm...@yahoo.com.sg> wrote:> Hi all, > > I've some queries regarding the above subj. > > 1) QPSK is actually 2 BPSK. Is there any difference in their power? �What > I understand, Power (P) = [sqrt(real(signal).^2 + imag(signal).^2)].^2 > � � � � � � � � � � = amplitude.^2 > > 2) If QPSK requires 2P (BPSK needs P), and I transmit both using the same > amplitude, will I get 2P for QPSK and 1P for BPSK when I plot it in terms > of power? >If you use the same amplitude in both dimensions for QPSK as compared to a single dimension in BPSK, then yes, you will have 2P for QPSK and P for BPSK.> 3) With regards to 2), will the BER get affected if amplitude are the same > for both QPSK and BPSK? >BER will be the same if the amplitude is the same.> Thank you. > > Yingmu
