I have made a simulation of ofdm on baseband and it works fine. to simulate the sampling clock synchronization problem, i have resampled the baseband waveform using resample function in MATLAB. yt = resample(yt, 1601, 1600); Now, even with such a small offset, my receiver does not work (yt contains 1600 samples comprising 20 ofdm symbols each of 64 point + 16 cyclic prefix = 80 samples). My questions is i). how much performance degradation (SNR degradation) i should expect with a given offset? ii). i cannot perceive that what possibly can hurt ofdm when there is a very small clock synchronization problem. If i take a time domain waveform and takes it fft and then i just append a random sample to the end of it and again takes its fft, the result is not different a lot. thanks
Sampling Clock Problem in OFDM
Started by ●January 22, 2009
Reply by ●January 22, 20092009-01-22
On Jan 22, 1:16�am, aitezaz....@gmail.com wrote:> I have made a simulation of ofdm on baseband and it works fine. to > simulate the sampling clock synchronization problem, i have resampled > the baseband waveform using resample function in MATLAB. > yt = resample(yt, 1601, 1600); > > Now, even with such a small offset, my receiver does not work (yt > contains 1600 samples comprising 20 ofdm symbols each of 64 point + 16 > cyclic prefix = 80 samples). My questions is > i). how much performance degradation (SNR degradation) i should expect > with a given offset? > ii). i cannot perceive that what possibly can hurt ofdm when there is > a very small clock synchronization problem. If i take a time domain > waveform and takes it fft and then i just append a random sample to > the end of it and again takes its fft, the result is not different a > lot. > > thanksThe offset accumulates as you move through the vector. The performance will get progressively worse if you don't track it out. John
