This relates to an earlier post - "filter of amplitude versus filter of (I,Q)?". I would like to learn what is the effect in the frequency domain of taking the square root of a quantity on the time domain. Also, of taking the square (actually magnitude of a complex number) in the time domain? I think I know the second - the magnitude is number*complex_conjugate which is autocorrelation of the frequency spectrum - but I dont know the first. Thanks, Chris ================== Chris Bore BORES Signal processing www.bores.com chris@bores.com
sqrt in time - effect in freq?
Started by ●January 23, 2009
Reply by ●January 23, 20092009-01-23
Chris Bore wrote:> This relates to an earlier post - "filter of amplitude versus filter > of (I,Q)?". > > I would like to learn what is the effect in the frequency domain of > taking the square root of a quantity on the time domain. Also, of > taking the square (actually magnitude of a complex number) in the time > domain? > > I think I know the second - the magnitude is number*complex_conjugate > which is autocorrelation of the frequency spectrum - but I dont know > the first.I don't have my notes from '55 and I won't do it over, but I can quote a result that might be relevant. If you remove one sideband from an ordinary double-sideband signal (leaving the other sideband and the carrier intact) the demodulated result will be increasingly distorted as the modulation percentage increases. One way to achieve low-distortion is increasing the carrier amplitude ("exalted carrier operation") to reduce the modulation percentage. A more interesting way is using a square-law detector, effectively squaring the signal. To a first order of approximation, removing one of the sidebands effectively creates the square root of the modulation. (That's not to imply that using the square root of the modulation will eliminate a sideband! :-) ) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Chris Bore schrieb:> This relates to an earlier post - "filter of amplitude versus filter > of (I,Q)?". > > I would like to learn what is the effect in the frequency domain of > taking the square root of a quantity on the time domain. Also, of > taking the square (actually magnitude of a complex number) in the time > domain? > > I think I know the second - the magnitude is number*complex_conjugate > which is autocorrelation of the frequency spectrum - but I dont know > the first. > > Thanks, > > Chris > ================== > Chris Bore > BORES Signal processing > www.bores.com > chris@bores.comHello, your right on the part with the multiplication. This is basically a convolution of the signal in the frequency domain with itself. When using sinoids this has the same effect like a mixer which doubles the carrier frequency. However taking the square root is something much more complicated, since the considered signal neither represents a linear time invariant nor a linear frequency invariant system and therefore I am afraid there does not exist a closed form solution for the Fourier Transform. So you have to do try it numerically or use a linearization operation (taylor series) for the specific signal. Greetz, Sebastian Doht
