Memory of depth and size of look up table?
Started by A.E lover ●January 27, 2009
Hi all,
In a technical report about hardware implementation, I see that they
use  the term 25 bit depth to describe a 1-D LUT. Also on the diagram,
they use the notation 25x14 on this 1-D LUT.
From this, is it true that the memory of this 1-D LUT is 2^25 * 2
bytes= 64Mbytes?
Thanks
A.E lover wrote:
> Hi all, > > In a technical report about hardware implementation, I see that they > use the term 25 bit depth to describe a 1-D LUT. Also on the diagram, > they use the notation 25x14 on this 1-D LUT. > > From this, is it true that the memory of this 1-D LUT is 2^25 * 2 > bytes= 64Mbytes?
In plain English, I take that to mean 14 words of 25 bits each. In jargon, it could be anything. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins <jya@ieee.org> writes:
> A.E lover wrote: >> Hi all, >> >> In a technical report about hardware implementation, I see that they >> use the term 25 bit depth to describe a 1-D LUT. Also on the diagram, >> they use the notation 25x14 on this 1-D LUT. >> >> From this, is it true that the memory of this 1-D LUT is 2^25 * 2 >> bytes= 64Mbytes? > > In plain English, I take that to mean 14 words of 25 bits each. In > jargon, it could be anything.
It has been my experience that such dimensions are usually in "address x width" form so I would say it's 25 14-bit words, but who knows in such a case? -- % Randy Yates % "Remember the good old 1980's, when %% Fuquay-Varina, NC % things were so uncomplicated?" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://www.digitalsignallabs.com
Randy Yates wrote:
> Jerry Avins <jya@ieee.org> writes: > >> A.E lover wrote: >>> Hi all, >>> >>> In a technical report about hardware implementation, I see that they >>> use the term 25 bit depth to describe a 1-D LUT. Also on the diagram, >>> they use the notation 25x14 on this 1-D LUT. >>> >>> From this, is it true that the memory of this 1-D LUT is 2^25 * 2 >>> bytes= 64Mbytes? >> In plain English, I take that to mean 14 words of 25 bits each. In >> jargon, it could be anything. > > It has been my experience that such dimensions are usually in "address x > width" form so I would say it's 25 14-bit words, but who knows in such a > case?
I normally construe "bit depth" to be akin to "bus width". Do you think that's misguided? jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
> Randy Yates wrote: >> Jerry Avins <jya@ieee.org> writes: >> >>> A.E lover wrote: >>>> Hi all, >>>> >>>> In a technical report about hardware implementation, I see that they >>>> use the term 25 bit depth to describe a 1-D LUT. Also on the diagram, >>>> they use the notation 25x14 on this 1-D LUT. >>>> >>>> From this, is it true that the memory of this 1-D LUT is 2^25 * 2 >>>> bytes= 64Mbytes? >>> In plain English, I take that to mean 14 words of 25 bits each. In >>> jargon, it could be anything. >> >> It has been my experience that such dimensions are usually in "address x >> width" form so I would say it's 25 14-bit words, but who knows in such a >> case? > > I normally construe "bit depth" to be akin to "bus width". Do you > think that's misguided?
No, I don't. Therin lies the inconsistency in their terminology, purportedly. -- % Randy Yates % "How's life on earth? %% Fuquay-Varina, NC % ... What is it worth?" %%% 919-577-9882 % 'Mission (A World Record)', %%%% <yates@ieee.org> % *A New World Record*, ELO http://www.digitalsignallabs.com
>>>> A.E lover wrote:
>>>>> In a technical report about hardware implementation, I see >>>>> that they use the term 25 bit depth to describe a 1-D LUT. Also >>>>> on the diagram, they use the notation 25x14 on this 1-D LUT.
A 25x14 table would almost always mean 25 words, 14 bits per words. Not 2^25 words.
>>>>> From this, is it true that the memory of this 1-D LUT is 2^25 * 2 >>>>> bytes= 64Mbytes?
>>>> In plain English, I take that to mean 14 words of 25 bits each. In >>>> jargon, it could be anything.
>>> It has been my experience that such dimensions are usually in "address x >>> width" form so I would say it's 25 14-bit words, but who knows in such a >>> case?
>> I normally construe "bit depth" to be akin to "bus width". Do you >> think that's misguided?
>No, I don't. Therin lies the inconsistency in their terminology, >purportedly.
"Bit depth" is pretty non-standard so that could mean anything. If they're saying 25x14 and they mean something other than 25 words in the table, that is very non-standard. Steve
I just learnt that the notation 25x14 means  15 bit address for input
and 14 bit address for output.
So does it  mean what I wrote in my OP: size of the memory is 2^25 * 2
bytes
Sorry I am not in digital signal processing area, so might be it is so
simple question to you, but not to me. Thanks,
AE
On Jan 27, 11:57&#4294967295;am, spop...@speedymail.org (Steve Pope) wrote:
> Randy Yates &#4294967295;<ya...@ieee.org> wrote: > > >Jerry Avins <j...@ieee.org> writes: > >> Randy Yates wrote: > >>> Jerry Avins <j...@ieee.org> writes: > >>>> A.E lover wrote: > >>>>> In a technical report about hardware implementation, I see > >>>>> that they use &#4294967295;the term 25 bit depth to describe a 1-D LUT. Also > >>>>> on the diagram, they use the notation 25x14 on this 1-D LUT. > > A 25x14 table would almost always mean 25 words, 14 bits per words. > Not 2^25 words. > > >>>>> From this, is it true that the memory of this 1-D LUT is 2^25 * 2 > >>>>> bytes= 64Mbytes? > >>>> In plain English, I take that to mean 14 words of 25 bits each. In > >>>> jargon, it could be anything. > >>> It has been my experience that such dimensions are usually in "address x > >>> width" form so I would say it's 25 14-bit words, but who knows in such a > >>> case? > >> I normally construe "bit depth" to be akin to "bus width". Do you > >> think that's misguided? > >No, I don't. Therin lies the inconsistency in their terminology, > >purportedly. > > "Bit depth" is pretty non-standard so that could mean anything. > If they're saying 25x14 and they mean something other than > 25 words in the table, that is very non-standard. > > Steve
A.E lover wrote:
> I just learnt that the notation 25x14 means 15 bit address for input > and 14 bit address for output.
Is 15 a typo? Did you mean 25-bit addresses by 14-bit outputs? That *would* be 2^25 by 14 bits.
> So does it mean what I wrote in my OP: size of the memory is 2^25 * 2 > bytes
There's no need to waste two bits per entry unless it's cheaper that way.
> Sorry I am not in digital signal processing area, so might be it is so > simple question to you, but not to me. Thanks,
... Don't be sorry; rejoice! Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
in digital audio it's pretty common. at least with audio practitioners who record, manipulate, and master audio files of various sizes. the size (in bytes) of an uncompressed audio file is a function of various attributes which include length (in time), sample rate, number of channels, and bit depth. it basically means the word width (in bits) and normally applies to left-justified words (so increased "bit depth" means adding bits to the right and quantization usually means reducing the bit depth). r b-j
>in digital audio it's pretty common. at least with audio >practitioners who record, manipulate, and master audio files of >various sizes. the size (in bytes) of an uncompressed audio file is a >function of various attributes which include length (in time), sample >rate, number of channels, and bit depth. it basically means the word >width (in bits) and normally applies to left-justified words (so >increased "bit depth" means adding bits to the right and quantization >usually means reducing the bit depth).
Thanks, this is useful to know. Steve
