Hi everyone, Just got handed a 600000 line software application with lots of DSP. I am trying to understand a few things and as I am new to DSP, it is a bit complicated. Here is a scenario. There is a signal that is being fed into a cascaded Bessel filter bank that splits it into 0-60 Hz, 60-120 Hz, 120-180 Hz, 180-240 Hz uptil 480 Hz... i.e. in bands of 60 Hz. After this, the output of these filters is again fed to a low pass filter at 60 Hz...now, what effect will this have on the signals... I mean, 0-60 Hz would not have any components above 60 HZ and the rest will have components above 60 Hz. So what si the point of low pass filtering it again? I am sure I am missing something very fundamental here and was hoping that someone would be able to help with this. Thanks, Sincerely, N
newbie filter question
Started by ●October 14, 2004
Reply by ●October 14, 20042004-10-14
Pankaj Daga wrote:> Hi everyone, > > Just got handed a 600000 line software application with lots of DSP. I > am trying to understand a few things and as I am new to DSP, it is a > bit complicated. > > Here is a scenario. There is a signal that is being fed into a > cascaded Bessel filter bank that splits it into 0-60 Hz, 60-120 Hz, > 120-180 Hz, 180-240 Hz uptil 480 Hz... i.e. in bands of 60 Hz. > > After this, the output of these filters is again fed to a low pass > filter at 60 Hz...now, what effect will this have on the signals... I > mean, 0-60 Hz would not have any components above 60 HZ and the rest > will have components above 60 Hz. So what si the point of low pass > filtering it again? I am sure I am missing something very fundamental > here and was hoping that someone would be able to help with this. > > Thanks, > > Sincerely, > > NThe scenario you describe is too stupid to be real. The 0-60 Hz signal would hardly be changed by the low-pass, and the others would be suppressed. There must be more to it that isn't clear yet. The use of Bessel filters is an indication that phase linearity is more important than sharp band edges, whatever that's worth. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> Pankaj Daga wrote: > > >>Hi everyone, >> >>Just got handed a 600000 line software application with lots of DSP. I >>am trying to understand a few things and as I am new to DSP, it is a >>bit complicated. >> >>Here is a scenario. There is a signal that is being fed into a >>cascaded Bessel filter bank that splits it into 0-60 Hz, 60-120 Hz, >>120-180 Hz, 180-240 Hz uptil 480 Hz... i.e. in bands of 60 Hz. >> >>After this, the output of these filters is again fed to a low pass >>filter at 60 Hz...now, what effect will this have on the signals... I >>mean, 0-60 Hz would not have any components above 60 HZ and the rest >>will have components above 60 Hz. So what si the point of low pass >>filtering it again? I am sure I am missing something very fundamental >>here and was hoping that someone would be able to help with this. >> >>Thanks, >> >>Sincerely, >> >>N > > > The scenario you describe is too stupid to be real. The 0-60 Hz signal > would hardly be changed by the low-pass, and the others would be > suppressed. There must be more to it that isn't clear yet. > > The use of Bessel filters is an indication that phase linearity is more > important than sharp band edges, whatever that's worth. > > JerryIs there anything else going on between the filter banks and the final 60Hz filtering? Squaring of the signals, perhaps? If some sort of modulation is being extracted from the signals (i.e. by squaring) then the resulting demodulated waveforms _would_ have content below 60Hz, as well as unwanted content above. This is just supposition, of course... -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
pankajdaga@excite.com (Pankaj Daga) wrote in message news:<1a4b2aef.0410140424.35997638@posting.google.com>...> Hi everyone, > > Just got handed a 600000 line software application with lots of DSP. I > am trying to understand a few things and as I am new to DSP, it is a > bit complicated. > > Here is a scenario. There is a signal that is being fed into a > cascaded Bessel filter bank that splits it into 0-60 Hz, 60-120 Hz, > 120-180 Hz, 180-240 Hz uptil 480 Hz... i.e. in bands of 60 Hz. > > After this, the output of these filters is again fed to a low pass > filter at 60 Hz...now, what effect will this have on the signals... I > mean, 0-60 Hz would not have any components above 60 HZ and the rest > will have components above 60 Hz. So what si the point of low pass > filtering it again? I am sure I am missing something very fundamental > here and was hoping that someone would be able to help with this.What you describe doesn't make much sense to me; it appears that only the 0-60 Hz channel would remain after this operation. So you might want to check that second filter bank in more detail. Could they be phase-correcting all-pass filters? Rune
"Tim Wescott" <tim@wescottnospamdesign.com> wrote in message news:10mt6oggn54m71b@corp.supernews.com...> > Pankaj Daga wrote: > > > > > >>Just got handed a 600000 line software application with lots of DSP. I > >>am trying to understand a few things and as I am new to DSP, it is a > >>bit complicated. > >> > >>Here is a scenario. There is a signal that is being fed into a > >>cascaded Bessel filter bank that splits it into 0-60 Hz, 60-120 Hz, > >>120-180 Hz, 180-240 Hz uptil 480 Hz... i.e. in bands of 60 Hz. > >> > >>After this, the output of these filters is again fed to a low pass > >>filter at 60 Hz...now, what effect will this have on the signals... I > >>mean, 0-60 Hz would not have any components above 60 HZ and the rest > >>will have components above 60 Hz. So what si the point of low pass > >>filtering it again? I am sure I am missing something very fundamental > >>here and was hoping that someone would be able to help with this. > > Is there anything else going on between the filter banks and the final > 60Hz filtering? Squaring of the signals, perhaps? > > If some sort of modulation is being extracted from the signals (i.e. by > squaring) then the resulting demodulated waveforms _would_ have content > below 60Hz, as well as unwanted content above. > > This is just supposition, of course...That is exactly what I was thinking. Squaring the signal or doing some other non-linear operation could generate additional frequencies that might need to be filtered out by the 60Hz LP.
Tim Wescott wrote:> Jerry Avins wrote: > >> Pankaj Daga wrote: >> >> >>> Hi everyone, >>> >>> Just got handed a 600000 line software application with lots of DSP. I >>> am trying to understand a few things and as I am new to DSP, it is a >>> bit complicated. >>> >>> Here is a scenario. There is a signal that is being fed into a >>> cascaded Bessel filter bank that splits it into 0-60 Hz, 60-120 Hz, >>> 120-180 Hz, 180-240 Hz uptil 480 Hz... i.e. in bands of 60 Hz. >>> >>> After this, the output of these filters is again fed to a low pass >>> filter at 60 Hz...now, what effect will this have on the signals... I >>> mean, 0-60 Hz would not have any components above 60 HZ and the rest >>> will have components above 60 Hz. So what si the point of low pass >>> filtering it again? I am sure I am missing something very fundamental >>> here and was hoping that someone would be able to help with this. >>> >>> Thanks, >>> >>> Sincerely, >>> >>> N >> >> >> >> The scenario you describe is too stupid to be real. The 0-60 Hz signal >> would hardly be changed by the low-pass, and the others would be >> suppressed. There must be more to it that isn't clear yet. >> >> The use of Bessel filters is an indication that phase linearity is more >> important than sharp band edges, whatever that's worth. >> >> Jerry > > > Is there anything else going on between the filter banks and the final > 60Hz filtering? Squaring of the signals, perhaps? > > If some sort of modulation is being extracted from the signals (i.e. by > squaring) then the resulting demodulated waveforms _would_ have content > below 60Hz, as well as unwanted content above. > > This is just supposition, of course...I'd be more inclined to think that it's demodulation if we knew that the various bands were squared separately, each representing a separate channel. What happens to the outputs of all the low-pass filters would be an interesting bit of information. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●October 15, 20042004-10-15
Hi, There is something that is going on which I failed to notice before. It takes the absolute value of the filter bank returned output and then does the low pass filtering. What kind of information will that provide? Thanks, N Tim Wescott <tim@wescottnospamdesign.com> wrote in message news:<10mt6oggn54m71b@corp.supernews.com>...> Jerry Avins wrote: > > > Pankaj Daga wrote: > > > > > >>Hi everyone, > >> > >>Just got handed a 600000 line software application with lots of DSP. I > >>am trying to understand a few things and as I am new to DSP, it is a > >>bit complicated. > >> > >>Here is a scenario. There is a signal that is being fed into a > >>cascaded Bessel filter bank that splits it into 0-60 Hz, 60-120 Hz, > >>120-180 Hz, 180-240 Hz uptil 480 Hz... i.e. in bands of 60 Hz. > >> > >>After this, the output of these filters is again fed to a low pass > >>filter at 60 Hz...now, what effect will this have on the signals... I > >>mean, 0-60 Hz would not have any components above 60 HZ and the rest > >>will have components above 60 Hz. So what si the point of low pass > >>filtering it again? I am sure I am missing something very fundamental > >>here and was hoping that someone would be able to help with this. > >> > >>Thanks, > >> > >>Sincerely, > >> > >>N > > > > > > The scenario you describe is too stupid to be real. The 0-60 Hz signal > > would hardly be changed by the low-pass, and the others would be > > suppressed. There must be more to it that isn't clear yet. > > > > The use of Bessel filters is an indication that phase linearity is more > > important than sharp band edges, whatever that's worth. > > > > Jerry > > Is there anything else going on between the filter banks and the final > 60Hz filtering? Squaring of the signals, perhaps? > > If some sort of modulation is being extracted from the signals (i.e. by > squaring) then the resulting demodulated waveforms _would_ have content > below 60Hz, as well as unwanted content above. > > This is just supposition, of course...
On 15 Oct 2004 02:17:30 -0700, pankajdaga@excite.com (Pankaj Daga) wrote:>Hi, > >There is something that is going on which I failed to notice before. >It takes the absolute value of the filter bank returned output and >then does the low pass filtering. What kind of information will that >provide? > >Thanks, > >NHi, that depends on what "follow on" operations are performed on the absolute value samples. You'll have to keep decyphering the code ***very*** carefully to find. Keep asking questions. The guys here will be able to answer them. Good Luck, [-Rick-]
Pankaj Daga wrote:> Hi, > > There is something that is going on which I failed to notice before. > It takes the absolute value of the filter bank returned output and > then does the low pass filtering. What kind of information will that > provide? > > Thanks, > > NAbsolute value is what an ideal full-wave rectifier creates from an analog signal. Low-passed absolute value is AM demodulation. What happens after the filters? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
pankajdaga@excite.com (Pankaj Daga) wrote in message news:<1a4b2aef.0410150117.67096704@posting.google.com>...> Hi, > > There is something that is going on which I failed to notice before. > It takes the absolute value of the filter bank returned output and > then does the low pass filtering. What kind of information will that > provide?Eh... I'm getting very curious now. What is the task of the program system you "inherited"? Or are you completely in the dark as of what problem it was designed to solve? Rune
