stevepierson wrote:> On Feb 17, 12:03 pm, Jerry Avins <j...@ieee.org> wrote: >> fisico30 wrote: >>> Hello forum, >>> I have a few questions about bandwidth: >>> Take a finite time signal, like a pulse. It must be composed of a band of >>> Fourier frequencies. >> I don't know what a Fourier frequency is. I don't think you do either; I >> guess you mean something else. Can you clarify? > > it's standard terminology in harmonic analysis, read > > http://books.google.com/books?id=zQsupRg5rrAC&pg=PA37&lpg=PA37&dq=%22fourier+frequencies%22&source=web&ots=SuxllrEC0i&sig=bslLkLihXNKE2ch0KDdC4cBzFqg&hl=en&ei=qEacSYqDMYmGsQOe-qGsAg&sa=X&oi=book_result&resnum=10&ct=resultThat's a new one for me. What does it mean that /harmonics/ doesn't? Still, I'm not a good judge. People "do lunch" and "have sex". It seems to me "have lunch" and "do sex" makes more sense. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
true meaning of bandwidth
Started by ●February 17, 2009
Reply by ●February 18, 20092009-02-18
On Feb 18, 1:04�pm, Jerry Avins <j...@ieee.org> wrote:> stevepierson wrote: > > On Feb 17, 12:03 pm, Jerry Avins <j...@ieee.org> wrote: > >> fisico30 wrote: > >>> Hello forum, > >>> I have a few questions about bandwidth: > >>> Take a finite time signal, like a pulse. It must be composed of a band of > >>> Fourier frequencies. > >> I don't know what a Fourier frequency is. I don't think you do either; I > >> guess you mean something else. Can you clarify? > > > it's standard terminology in harmonic analysis, read > > >http://books.google.com/books?id=zQsupRg5rrAC&pg=PA37&lpg=PA37&dq=%22... > > That's a new one for me. What does it mean that /harmonics/ doesn't?it tells me what orthogonal basis function was used in the transform. the op comment "The notion of a single pure frequency belongs only to a sinusoidal signal" is only true if you use the fourier frequency sinusoids as a basis function in the transform (and not because the sine wave is inherently "pure" or single tone, you forced it to be single tone by your basis function choice to begin with)
stevepierson wrote: (snip)> it tells me what orthogonal basis function was used in the transform.Well, you usually don't have so much choice for the basis functions, but yes. Harmonic implies sine/cosine basis.> the op comment "The notion of a single pure frequency belongs only to > a sinusoidal signal" is only true if you use the fourier frequency > sinusoids as a basis function in the transform (and not because the > sine wave is inherently "pure" or single tone, you forced it to be > single tone by your basis function choice to begin with)In cylindrical symmetry the basis functions are usually Bessel functions. The radial modes of a drum head are Bessel functions, but the time dependence will again be sinusoidal. It isn't that you have so much choice, it is the solutions of the differential equation that matter. -- glen
Reply by ●February 20, 20092009-02-20
stevepierson wrote:> On Feb 17, 12:03 pm, Jerry Avins <j...@ieee.org> wrote: >> fisico30 wrote: >>> Hello forum, >>> I have a few questions about bandwidth: >> >>> Take a finite time signal, like a pulse. It must be composed of a >>> band of Fourier frequencies. >> >> I don't know what a Fourier frequency is. I don't think you do >> either; I guess you mean something else. Can you clarify? > > it's standard terminology in harmonic analysis, read > > http://books.google.com/books?id=zQsupRg5rrAC&pg=PA37&lpg=PA37&dq=%22fourier+frequencies%22&source=web&ots=SuxllrEC0i&sig=bslLkLihXNKE2ch0KDdC4cBzFqg&hl=en&ei=qEacSYqDMYmGsQOe-qGsAg&sa=X&oi=book_result&resnum=10&ct=resultWell ...... OK. That refers to a Fourier Series. It's not so clear when using a Fourier Transform. I thought that's what we were discussing here really. Fred
On Feb 17, 9:37�am, "fisico30" <marcoscipio...@gmail.com> wrote:> Hello forum, > I have a few questions about bandwidth: > > Take a finite time signal, like a pulse. It must be composed of a band of > Fourier frequencies.but, if your pulse is not repeated, these frequencies are really having vanishing spacing (they get infinitesimally close) and vanishing amplitude in proportion to each other. that's what the Fourier Integral means.> > 1) Back to the pulse: are those composing Fourier frequencies somewhat > real? How does the hardware measure them, since they only belong to > abstract functions?the hardware measures samples of the time-domain function. it gets a finite number of samples (we'll call that finite number "N"). either hardware or software performs a DFT on those samples. in each bin is an amplitude of what might be thought of as a frequency band of some sort. so there is some ambiguity. many different frequencies can contribute to the amplitude (to different degrees of contribution) in some given DFT bin. on thing that you might want to think about the meaning of bandwidth of a pulse; sometimes we define the bandwidth as the width of a fixed percentage of its energy spectrum. but it's all convention. sometimes it's just the space between "bandedges" which can be defined a zillion different ways. but, however it's defined, it is the proportional to the reciprocal of the "timewidth" of that pulse (defined in the same manner). the timewidth-bandwidth product is a dimensionless constant. if you like, you can choose a gaussian pulse (which happens to have a gaussian pulse as its Fourier Transform) and define bandwidth in such a way that, if the timewidth was defined the same way, the timewidth- bandwidth product would be the dimensionless 1. r b-j
Reply by ●March 2, 20092009-03-02
>On Feb 17, 12:03=A0pm, Jerry Avins <j...@ieee.org> wrote: >> fisico30 wrote: >> > Hello forum, >> > I have a few questions about bandwidth: >> >> > Take a finite time signal, like a pulse. It must be composed of aband =>of >> > Fourier frequencies. >> >> I don't know what a Fourier frequency is. I don't think you do either;I>> guess you mean something else. Can you clarify? > >it's standard terminology in harmonic analysis, read > >http://books.google.com/books?id=3DzQsupRg5rrAC&pg=3DPA37&lpg=3DPA37&dq=3D%= >22fourier+frequencies%22&source=3Dweb&ots=3DSuxllrEC0i&sig=3DbslLkLihXNKE2c= >h0KDdC4cBzFqg&hl=3Den&ei=3DqEacSYqDMYmGsQOe-qGsAg&sa=3DX&oi=3Dbook_result&r= >esnum=3D10&ct=3Dresult >For instance, a Gaussian pulse (cosine enveloped by Gaussian) is made ofmany frequencies but has just one constant instantaneous frequency.... The word single frequency pertains only to infinitelly long, periodic signals. Sorry for the misnomer>
On Mar 2, 2:37 pm, "fisico30" <marcoscipio...@gmail.com> wrote:> >On Feb 17, 12:03=A0pm, Jerry Avins <j...@ieee.org> wrote: > >> fisico30 wrote: > >> > Hello forum, > >> > I have a few questions about bandwidth: > > >> > Take a finite time signal, like a pulse. It must be composed of a > band = > >of > >> > Fourier frequencies. > > >> I don't know what a Fourier frequency is. I don't think you do either; > I > >> guess you mean something else. Can you clarify? > > >it's standard terminology in harmonic analysis, read > > >http://books.google.com/books?id=3DzQsupRg5rrAC&pg=3DPA37&lpg=3DPA37&... > >22fourier+frequencies%22&source=3Dweb&ots=3DSuxllrEC0i&sig=3DbslLkLihXNKE2c= > >h0KDdC4cBzFqg&hl=3Den&ei=3DqEacSYqDMYmGsQOe-qGsAg&sa=3DX&oi=3Dbook_result&r= > >esnum=3D10&ct=3Dresult > >For instance, a Gaussian pulse (cosine enveloped by Gaussian) is made of > > many frequencies but has just one constant instantaneous frequency.....> The word single frequency pertains only .> to infinitelly long, periodic signals. .> Sorry for the misnomer A transform sized set of samples of one of the basis functions of a complex DFT is a finitely long representation of a single frequency. Like many new to DSP you are taking theoretical concepts from the continuous/infinite domain and using them to pose questions about actual implementations which cannot be continuous/infinite. Such nonsense questions produce more smoke and heat than light. If you want useful answers, pick a domain, state your pick, and learn to ask your questions within a consistent domain.. Dale B. Dalrymple
