I have a PC based guitar effects software. Some of the effects are great. First is Vienna Philharmonic Concert Hall Acoustic effect , Second is a tube based guitar amp effect. I want to analyse these input and output sounds digitally and train a dsp neural networks chip . If I am not wrong , I will be needed + A/D + DSP CHIP for finding the spectrum peaks of the input sounds- raw guitar sound and effected guitar effect sound - + NN DSP CHIP for finding the function between guitar input spectrum peaks and guitar effect output spectrum peaks , and after all , this NN DSP chip will change every input guitar spectrum peak to new one + D/A It looks basic but i need help. What kind of chips do I need ? They must cost cheap. I need similar reference codes for these chips. Thanks for your help , Mustafa Umut Sarac Istanbul
NN Copying of a guitar effect with Reverse Engineering
Started by ●February 23, 2009
Reply by ●February 23, 20092009-02-23
MustafaUmutSarac wrote:> I have a PC based guitar effects software.Wow. You didn't say.> Some of the effects are great.Good for you.> First is Vienna Philharmonic Concert Hall Acoustic effect , Second is a > tube based guitar amp effect.Hall effect in the tube? Interesting.> I want to analyse these input and output sounds digitally and train a dsp > neural networks chip .Why? It is well known that fractal fuzzy wavelets make the best result.> If I am not wrong ,You are wrong.> I will be neededYou will be needed smart head and stubborn arse, and many years of learning.> + A/D > > + DSP CHIP for finding the spectrum peaks of the input sounds- raw guitar > sound and effected guitar effect sound - > > + NN DSP CHIP for finding the function between guitar input spectrum peaks > and guitar effect output spectrum peaks , > > and after all , this NN DSP chip will change every input guitar spectrum > peak to new one > > + D/A > > It looks basic but i need help.How much are you going to pay for help?> What kind of chips do I need ? They must cost cheap.The 741, 7400 and 555 would probably do.> I need similar reference codes for these chips.Sure.> Mustafa Umut Sarac > IstanbulYea. Messages like that are always from that side of the world. VLV
MustafaUmutSarac wrote:> I have a PC based guitar effects software.> Some of the effects are great.> First is Vienna Philharmonic Concert Hall Acoustic effect, > Second is a tube based guitar amp effect.> I want to analyse these input and output sounds > digitally and train a dsp neural networks chip .Easier to go read the patent. If you are sued, it will be assumed that you have read it, so you might as well do it. -- glen
