Hi, I am working on radar processing and I am new to this study. I have 1D time domain data and I used windowing technique and 'fft'ed the data and plotted the data using imagesc and it is a spectrogram. My question is to denoise the spectrogram and to extract the data from the envelope obtained in the spectrogram. I am working this study in Matlab. Can any one suggest me denoising algorithm and envelope detection. Thank you.
Denoising and envelop detection
Started by ●February 23, 2009
Reply by ●February 23, 20092009-02-23
On Feb 23, 8:22�am, "wolverine_w2000" <jeetu...@gmail.com> wrote:> Hi, I am working on radar processing and I am new to this study. I have 1D > time domain data and I used windowing technique and 'fft'ed the data and > plotted the data using imagesc and it is a spectrogram. My question is to > denoise the spectrogram and to extract the data from the envelope obtained > in the spectrogram. I am working this study in Matlab. Can any one suggest > me denoising algorithm and envelope detection.Noise is separated from signal by knowing something that is different between the two. You use that difference to separate them. What do you know about your signal and the noise that you could use to separate them? What can you change about the way you collect the data? Rick
Reply by ●February 25, 20092009-02-25
On Feb 23, 8:22�am, "wolverine_w2000" <jeetu...@gmail.com> wrote:> Hi, I am working on radar processing and I am new to this study. I have 1D > time domain data and I used windowing technique and 'fft'ed the data and > plotted the data using imagesc and it is a spectrogram. My question is to > denoise the spectrogram and to extract the data from the envelope obtained > in the spectrogram. I am working this study in Matlab. Can any one suggest > me denoising algorithm and envelope detection. > > Thank you.If this is a pulsed time domain signal, I'm confused as to why you'd want to envelope detect it in the frequency domain. You will lose time resolution on the pulse edges, which is typically important. You could perform frequency domain processing to "denoise" the signal and then return to time domain prior to envelope detection. As mentioned before, any algorithm will exploit some difference between signal and noise. For example, you might know that the signal spectrum is symmetric and restore that property by adjusting FFT bins on opposite sides of the carrier frequency. Or, you might know that signal is absent in certain intervals and create a noise spectrum to be divided out during intervals when signal is present. In the time domain, you might consider applying a median filter followed by a matched filter. John
