On Feb 26, 10:32�pm, Jerry Avins <j...@ieee.org> wrote:> aitezaz....@gmail.com wrote: > > On Feb 26, 9:00 pm, Jerry Avins <j...@ieee.org> wrote: > >> aitezaz....@gmail.com wrote: > >>> jerry would you please comment on my previous post ? it is here for > >>> your reference > >>> -------------------------------------------------------------------------- > >>> Jerry i read article about Gibbs Phenomenon. What i got from this is > >>> that this problem arises when we truncate the filter response in time. > >> Nit exactly. Truncating the coefficients decreases the *frequency* of > >> the ringing, extending it further from the transition. It has no effect > >> in the *amplitude*. > > >>> That means if i increase the filter length with the same sharp > >>> filters, i should get the better performance. But, when i increased > >>> the filter length of the sharp filter, the performance improved from > >>> what it was with fewer number of taps but it was still worse than the > >>> performance of filter with larger transition bandwidth. Now where can > >>> be the problem? > >> The sharper transition. > > >>> Im using the following code to generate the filter. > >>> Fs_3 = 1e6; �% Sampling Frequency > >>> Fpass = 250e3; � � � � � � �% Passband Frequency > >>> Fstop = 500e3; � � � � � � % Stopband Frequency > >>> Dpass = 0.0028782312868; �% Passband Ripple > >>> Dstop = 0.001; � � � � � �% Stopband Attenuation > >>> dens �= 80; � � � � � � � �% Density Factor > >> That's not code, it's specification. Some program uses it to run code. > >> Bad things happen when a sorcerer's apprentice lets himself believe he's > >> a sorcerer. > > > of course i wrote below the MATLAB command firpm that uses Parks- > > McClellan algo for filter design. does that imply i should know this > > algorithm before designing filters? > > No. I meant to distinguish between the specification for a filter and > the code that calculates coefficients to meed that specification. > Driving a car doesn't involve knowing how to design one. Believing that > driving is akin to mechanical engineering does nobody any good. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > �����������������������������������������������������������������������All right thanks for your help anyways. it meant a lot to me... i will try to compensate in the regions you highlighted jerry. Best Regards, Aitezaz
Design of multirate filters
Started by ●February 24, 2009
Reply by ●February 26, 20092009-02-26
