Hi, I am created a pitch detector and I have noticed that I get shifted results depending on which microphone I use. Has anyone else noticed this type of behavior? I've created a calibration curve to compensate but the shift did surprise me a bit.
Should there be a frequency shift dependent on microphone?
Started by ●February 26, 2009
Reply by ●February 26, 20092009-02-26
noodle22 wrote:> Hi, > > I am created a pitch detector and I have noticed that I get shifted > results depending on which microphone I use. Has anyone else noticed this > type of behavior? I've created a calibration curve to compensate but the > shift did surprise me a bit.When the output frequencies differ from the input frequencies (microphone, speaker, tone control, whatever) the thingy distorts. That doesn't apply to amplitudes. Probably, your microphones emphasize different harmonics, affecting the software you use. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
