We are using Code Composer Studio V3.3 for generating code for DSP TMS320F28027, using CONTROL STICK hardware. We developed program for our application, tested using RAM, now we want to check this using flash in stand alone system. so, tried to program a flash, there We are facing problem. Generating error target “halted during flash operation flash operation aborted” So to verify the flash programming, the sample program blinking LED in following directory: C:\tidcs\c28\Flash28_API\Flash2802x_API_V100\example We tried to run; there also it is generating same error, To check working of flash a program, in following directory: C:\Texas Instruments\Piccolo controlSTICK\Timer – BlinkingLED Also tried to run in flash, the steps are followed are as under: Step 1: I have opened the BlinkingLED.pjt Step 2: I have kept the option as F2802x_FLASH Step 3: I have make Rebuild All in the project Step 4: It has Builded Successfully Step 5: Then Tools->F28xx-on chip Flash Programmer Step 6: click execute operation Step 7: It has generating same error. Can some body suggest how to program flash successfully,
PICCOLO FLASH PROGRAM
Started by ●March 13, 2009
