Hi, QPSK has - 4 constellation points; 16 QAM -16 constellation points; 64 - 64 constellation points. 16QAM vs QPSK -> Now with the 16 possible points in the constellation diagram we have 16 possible symbols. For this 16 symbols we need 4 bits for coding . Compared to the QPSK modulation now we have doubled the transfer rate when using the same symbol clock.But compared to the QPSK, points are closer to each other and so the allowed noise circle radius is decreased. Noise can be interpreted as a vector which turns around the points of the constellation diagram producing a circle with a noise amplitude dependend radius. If we have normalized constellation (i.e. max distance is 1 - i.e. distance between two outer edges of circle of outer constellation points), then: required distance QAM16 -> 1/(SQRT(QAM res.)) = 1/SQRT(16) = 0.25 required distance QPSK -> 1/(SQRT(QPSK res.)) = 1/SQRT(4) = 0.5 So we get a ratio of QPSK/QAM distance required to get no overlap of the points of: 20 * log(o.5/0.25) = 6dB. So to have the same S/N ratio with the same noise level the signal for 16QAM has to be 6 dB stronger than QPSK. The same case is between 64QAM and 16 QAM(6db difference), 256QAM and 64QAM(6db difference) .... We see that with each bit we add to the symbol rate we need a 3 dB better S/N of the received signal. So we see the tradeoff we have to do between the increasing transfer rate and the required S/N ratio. Of course another way to increase the transfer rate is a higher symbol clock with the same symbol width. (PS All this I found in AN97047.pdf http://www.nxp.com/acrobat_download/applicationnotes/AN97047_1.pdf) =================================================================== But, I saw also formula(in MATLAB help) Es/No = Eb/No + 10log10(k); where k is the number of information bits per symbol. By this formula we get: QPSK: Es/No = Eb/No + 10log10(2)=Eb/No + 3.0103; 16QAM: Es/No = Eb/No + 10log10(4)=Eb/No + 6.0206; 64QAM: Es/No = Eb/No + 10log10(6)=Eb/No + 7.7815; For BER of 10e-5, we get for QPSK that required Eb/No is about 9.5 dB, for 16QAM is about 13dB, for 64QAM is about 17,5dB...(I get this by MATLAB bertool). So we now have: QPSK: Es/No = Eb/No + 10log10(2)=9.5 + 3.0103 ~ 12.5 dB; 16QAM: Es/No = Eb/No + 10log10(4)=13 + 6.0206 ~ 20 dB; 64QAM: Es/No = Eb/No + 10log10(6)=17.5 + 7.7815 ~ 26.2 dB; So as You see the difference between 12.5 and 20 is not 6dB, in case QPSK vs 16QAM! (PS: I think that this is a very important line: "So to have the same S/N ratio with the same noise level the signal for 16QAM has to be 6 dB stronger than QPSK." - in AN97047.pdf) So what is correct? Is this the same thing I try to correlate or... If so, why is that? Thanks and best regards
Modulation 6 dB margin QPSK-16QAM-64QAM...
Started by ●March 19, 2009
Reply by ●March 19, 20092009-03-19
For QPSK, the *maximum* power and the *average* power are the same. For larger QAM constellations (yes, QPSK is 4QAM), these two quantities are different. So the comparison of maximum power and a comparison of average power give different answers. Hope this helps --Dilip Sarwate
>For QPSK, the *maximum* power and the >*average* power are the same. For larger >QAM constellations (yes, QPSK is 4QAM), >these two quantities are different. So the >comparison of maximum power and a >comparison of average power give different >answers. > >Hope this helps > >--Dilip Sarwate > >Hi, Thanks for replay but I didn't understand very well. What is a *maximum* and what is *average* in formulas above? i.e. which value is the *maximum* and which *average* in formulas above? Can You clear this up for me... and also You said "For QPSK, the *maximum* power and the *average* power are the same." . how You see this from formulas above can You tell me which values, and also how for QAM constellations these two quantities are different.? Best regards
