Communicate system organization ideas to 'laymen'?
Started by Rune Allnor ●March 24, 2009
On 26 Mar, 00:39, Jerry Avins <j...@ieee.org> wrote:
> Rune Allnor wrote: > > Hi folks. > > Hi. I've read the comments you've gotten. Most are worth thinking about. > I have a piece of non-specific advice that might be worth something too. > > Whatever you propose, have a sensible plan for introducing it.
I know. That's why I nase my approach on tying together the tools that are already in use, instead of coming up with something entirely new. Somebody mentioned that they already had tried the database idea, but it had failed. I never heard the details of why, but I have seen enough to suspect the reason. The problem is simply the logistics of working at sea. LOts of stuff you take for granted shore-side just doesn't work at sea. Identifying such factors and planning around them, is the key. With these thing one only gets one shot. Fail the first attempt, and you will never be trusted again. Rune
Rune Allnor wrote:
> On 26 Mar, 00:39, Jerry Avins <j...@ieee.org> wrote: >> Rune Allnor wrote: >>> Hi folks. >> Hi. I've read the comments you've gotten. Most are worth thinking about. >> I have a piece of non-specific advice that might be worth something too. >> >> Whatever you propose, have a sensible plan for introducing it. > > I know. That's why I nase my approach on tying together > the tools that are already in use, instead of coming up > with something entirely new. > > Somebody mentioned that they already had tried the > database idea, but it had failed. I never heard the > details of why, but I have seen enough to suspect the > reason. > > The problem is simply the logistics of working at sea. > LOts of stuff you take for granted shore-side just > doesn't work at sea. Identifying such factors and > planning around them, is the key. > > With these thing one only gets one shot. Fail the first > attempt, and you will never be trusted again. > > Rune
Rune, We do about the same sort of work that you are engaged in. Except on smaller and less capable work boats, ~100 feet. We have two 8' X 20' ISO vans set up for data acquisition ( GPS, subbottom, sidescan, single beam fathometer, swath bathymetry, sound velocity profilers, you get the idea. The other van is set up for just data processing. Like you we do 12 hour watches. Our shipboard staff consists of a Chief Scientist (a Geologist) skilled technical folks for the data acquisition side of the house and Master degree Geologist on the processing side. Some or technical folks would not know how to turn on an o'scope, but they are good a making sure data is good and locating troublesome components of systems. Virtually all of our processing folks know how to write Unix scripts that enable the batch processing of say the seismic data and other data sets. Some others can and have written "C" programs for sonar data processing. After a two or three week program, we are able to walk of the boat with preliminary sidescan mozaics, all seismic data processed and pdf images generated, swath bathy data processed with sound velocity corrections applied and in some occasions RTK tide corrections applied. More processing is applied once on the beach but the preliminary stuff is done. Please visit: http://woodshole.er.usgs.gov/operations/sfmapping/index.htm for more details of what we are doing. I hope that there maybe something there that you could use to convince your management that it is time for a change. We get real support from the folks in fuzzy carpet area for the most part because we are doing good work, the staff works well together and support each other. Best regards, Tom
On Thu, 26 Mar 2009 13:55:18 -0400, Thomas O'Brien <tobrien@usgs.gov>
wrote:
   [Snipped by Lyons]
> > >We get real support from the folks in fuzzy carpet area for the most >part because we are doing good work, the staff works well together and >support each other. > >Best regards, Tom
Hi Tom, Ha ha. "The folks in the fuzzy carpet area." I like that phrase! [-Rick-]
On 2 Apr, 15:55, Rick Lyons <R.Lyons@_BOGUS_ieee.org> wrote:
> On Thu, 26 Mar 2009 13:55:18 -0400, Thomas O'Brien <tobr...@usgs.gov> > wrote: > > &#4294967295; &#4294967295;[Snipped by Lyons] > > > > >We get real support from the folks in fuzzy carpet area for the most > >part because we are doing good work, the staff works well together and > >support each other. > > >Best regards, Tom > > Hi Tom, > &#4294967295; Ha ha. &#4294967295;"The folks in the fuzzy carpet area." > I like that phrase!
Hmmm... kind of hints at the 'padded walls area'...? Rune
On Thu, 2 Apr 2009 07:20:32 -0700 (PDT), Rune Allnor
<allnor@tele.ntnu.no> wrote:
>On 2 Apr, 15:55, Rick Lyons <R.Lyons@_BOGUS_ieee.org> wrote: >> On Thu, 26 Mar 2009 13:55:18 -0400, Thomas O'Brien <tobr...@usgs.gov> >> wrote: >> >> &#4294967295; &#4294967295;[Snipped by Lyons] >> >> >> >> >We get real support from the folks in fuzzy carpet area for the most >> >part because we are doing good work, the staff works well together and >> >support each other. >> >> >Best regards, Tom >> >> Hi Tom, >> &#4294967295; Ha ha. &#4294967295;"The folks in the fuzzy carpet area." >> I like that phrase! > >Hmmm... kind of hints at the 'padded walls area'...? > >Rune
Hi Rune, Another Ha ha. That was good. I have a much more unfriendly, almost vicious, wisecrack that we used to say about managers. See Ya', [-Rick-]
