Writing low level DSP code in C++ in lieu of C
Started by jjli...@hotmail.com March 24, 2009
Hello, in my experience I've mostly used the C programming language in
programming DSP's. I only have experience with Analog DSPs. I was
wondering if most people use  the C language rather than C++. I found
an article at embedded.com that you might find interesting:
http://www.embedded.com/212101526?printable=true
Are many DSP programmers switching to C++?
Thanks,
joe
On 24 Mrz., 22:14, "jjlind...@hotmail.com" <jjlind...@hotmail.com>
wrote:
> Hello, in my experience I've mostly used the C programming language in > programming DSP's. I only have experience with Analog DSPs. I was > wondering if most people use &#4294967295;the C language rather than C++. I found > an article at embedded.com that you might find interesting: > http://www.embedded.com/212101526?printable=true
I'm not exactly a "DSP programmer" or someone who tries to run code on embedded platforms. But I'd like to quote a paragraph of the article and comment on it: "My experience is that, with modern C++ compilers, introducing such abstractions rarely has any runtime cost. On the rare occasion that it does have a cost, you can always strip away the abstraction and use C++ as if it were C." This comes after some basic class/member function example. It's perfectly true. I would even go further and say that this kind of "abstraction" doesn't have ANY extra runtime costs EVER. Why should it? C++ being less efficient than C is kind of a myth. Debunking this myth was the main motivation for the authors of the following technical report: "Technical Report on C++ Performance" http://www.open-std.org/jtc1/sc22/wg21/docs/TR18015.pdf Cheers! SG
On 24 Mar, 23:08, SG <s.gesem...@gmail.com> wrote:
> &#4294967295;I would even go further and say that this kind of > "abstraction" doesn't have ANY extra runtime costs EVER. &#4294967295;Why should > it?
Well, one example is virtual functions. Virtual functions can not be inlined, which would be a performance cost compared to inlined code. Virtual functions also have to be dereferenced through a function table, which also is a performance cost.
It is certainly possible to write very efficient C++ code, but you'll have to know exactly what you are doing. Rune
On Mar 24, 6:33&#4294967295;pm, Rune Allnor <all...@tele.ntnu.no> wrote:
> On 24 Mar, 23:08, SG <s.gesem...@gmail.com> wrote: > > > C++ being less efficient than C is kind of a myth. > > It is certainly possible to write very efficient C++ code, > but you'll have to know exactly what you are doing. >
Rune is quite correct. i dunno specifically what the OP or others do with processing samples in C++, but you wouldn't want the sorta recursive invoking of inherited functions (or "methods", is that the right word?). things like connecting inputs and outputs of processing objects or connecting parameters, that can be done nicely and elegantly in C++, but the sampling processing should be done like it is in asm or C where the oopsey features of C++ are of no help. i also think that samples should be processed in blocks of multiple samples for efficiency. but if you're processing one sample at a time (with each object in the overall algorithm structure) and calling parent methods which themselves call their parent methods, i kinda think that would be dreadfully slow or inefficient. r b-j
On Tue, 24 Mar 2009 14:14:41 -0700, jjlindula@hotmail.com wrote:
> Hello, in my experience I've mostly used the C programming language in > programming DSP's. I only have experience with Analog DSPs. I was > wondering if most people use the C language rather than C++. I found an > article at embedded.com that you might find interesting: > http://www.embedded.com/212101526?printable=true > > Are many DSP programmers switching to C++? > > Thanks, > joe
In my experience with DSP applications, perhaps 0.1% of the code consumes 80% of the processor time. The rest of the code consumes, well -- the rest. That 0.1% gets written in assembly, the rest gets written in C++. -- http://www.wescottdesign.com
On 24 Mrz., 23:33, Rune Allnor <all...@tele.ntnu.no> wrote:
> On 24 Mar, 23:08, SG <s.gesem...@gmail.com> wrote: > > > &#4294967295;I would even go further and say that this kind of > > "abstraction" doesn't have ANY extra runtime costs EVER. &#4294967295;Why should > > it? > > Well, one example is virtual functions. Virtual functions > can not be inlined, which would be a performance cost > compared to inlined code. Virtual functions also have to > be dereferenced through a function table, which also is > a performance cost.
1. I was referring to the example in the article which doesn't contain virtual functions 2. You would not use virtual functions for no reason. An emulation in C via function pointers is not more efficient. Cheers! SG
Rune Allnor wrote:
> On 24 Mar, 23:08, SG <s.gesem...@gmail.com> wrote: >> I would even go further and say that this kind of >> "abstraction" doesn't have ANY extra runtime costs EVER. &#4294967295;Why should >> it? > > Well, one example is virtual functions. Virtual functions > can not be inlined, which would be a performance cost > compared to inlined code. Virtual functions also have to > be dereferenced through a function table, which also is > a performance cost.
This is true, but in C you must use function pointers or a switch statement to get the same functionality, and this also costs performance.
There are some features which should not be used because they insert hidden code almost everywhere: - exeptions - RTTI Otherwise all other advanced features in C++ do not result in a performance penalty over C, you just have to write much more code to get the same functionality, and you have the big chance to forget to write some of this code, resulting in a buggy program. One big advantage in C++ in embedded software development is the use of template classes and policy based design[1] such, that you write one implementation for the real hardware and one implementation for the software simulator and have only one place in the code where you define which version is used (usually just a typedef). In C you would clutter your code with macros. [1] as an example: device control via memory mapped IO You write to a fixed address to do some change in the hardware. This cannot work in the simulator where this hardware address does not exist. I wrote a template class with two templates which implements a write() function to a hardware address: - the 1st template parameter (AccessPolicy) specifies how the write is actually done - the 2nd template parameter (LogPolicy) specifies how the write to this address is logged (for debugging and test purposes) There are two versions of AccessPolicy: - one version writes to the specified address. It is used on the hardware. - one version writes to a STL map which simulates the memory on the hardware. It is used in the simulator. There are also two versions of LogPolicy: - one version does nothing. It is used on the hardware. - one version writes the memory access data (address and value) into a STL vector. It is used in the simulator. For the test of a given task you clear this vector, run the function to be tested and inspect the vector for the correct chain of write accesses. I use this for unit tests. In code: #ifdef SIMULATOR typedef MemAccess<AccessPolicyMap, LogPolicyVector> MyMemAccess; #else typedef MemAccess<AccessPolicyPhysical, LogPolicyNone> MyMemAccess #endif MyMemAccess mem_access; // switch output: mem_access.write(output_address, value); // same as: *(volatile int*)output_address = value; I verified that using this construction on the hardware creates the same assembler code like a direct write to an address, so there is no overhead. bye Andreas -- Andreas H&#4294967295;nnebeck | email: acmh@gmx.de ----- privat ---- | www : http://www.huennebeck-online.de Fax/Anrufbeantworter: 0721/151-284301 GPG-Key: http://www.huennebeck-online.de/public_keys/andreas.asc PGP-Key: http://www.huennebeck-online.de/public_keys/pgp_andreas.asc
I mostly use pen and paper for programming. For coding, I use whatever is appropriate: C, C++, assembler or anything else.
C is the outdated dialect of C++ which is sometimes handy for the small programs and resource constrained systems.
> I found > an article at embedded.com that you might find interesting: >http://www.embedded.com/212101526?printable=true
Ah, Dan Saks... Trivial and boring. Jack Gansle is the one worth reading in that magazine.
Think about the process. Coding it is the minor technical problem. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
