How ? correlation FFT ? thanks Is there a theory about ?
recognize material from sound !
Started by ●March 26, 2009
Reply by ●March 26, 20092009-03-26
On Mar 26, 2:42�pm, "nino" <npkpe...@libero.it> wrote:> How ? correlation FFT ? > thanks > Is there a theory about ?This can be real hard (impossible) or real easy. Do you know beforehand how many different materials you need to be able to identify? And do these "sound" very different from each other or are they alike? Back in the days where I worked with color print paper, you would figure out which side of the paper had the emulsion by rubbing your finger across it and the emulsion side was quieter than the other side. But in this case you were able to compare the sound of two materials against each other. Clay
Reply by ●March 27, 20092009-03-27
On 26 Mar, 19:42, "nino" <npkpe...@libero.it> wrote:> How ? correlation FFT ? > thanks > Is there a theory about ?Be *very* careful. You can *characterize* the sound in various ways (decay times, resonance frequencies, etc) but in general, you can't use that info to *classify* the sound, i.e. deduce what material or effect caused the characteristic. The world is an ambiguous place, so there might be other causes for any given effect that those you happen to think of. However, if you have a (small) number of candidates, you can likely get a long way towards deciding which of the candidates caused the characteristic. But again, if whatever characteristic was actually caused by something else than the alternatives you are looking for, you have trouble. Rune
On Mar 26, 2:42�pm, "nino" <npkpe...@libero.it> wrote:> How ? correlation FFT ? > thanks > Is there a theory about ?There are some forms of this, but you have not stated enough detail to understand what you want to do. When I worked in Chemistry a professor was working on Photo Acoustic Spectroscopy. A monochromatic light source is shown on the sample in pulses. The light is absorbed by the sample in relation to its wavelength and the properties of the material. The absorbed light produces vibrations in the sample which can be detected as sound. The sound is analyzed as a function of frequency of the light giving a spectrograph. I expect this is not the sort of thing you are looking for, but you have not given enough info to know what you are thinking about. Rick
On Mar 26, 2:42�pm, "nino" <npkpe...@libero.it> wrote:> How ? correlation FFT ? > thanks > Is there a theory about ?Acoustic signaling has been used to estimate properties of the earth for geophysical applications in oilfield, etc. Is this the kind of application that you are asking about? Julius
Thanks.! I only want recognize material froma set of 4-5 possibilities by hitting it and analizing sound Thanks Nini "rickman" <gnuarm@gmail.com> ha scritto nel messaggio news:1b614c17-b411-4051-95b9-7dd71fc742fd@l38g2000vba.googlegroups.com... On Mar 26, 2:42 pm, "nino" <npkpe...@libero.it> wrote:> How ? correlation FFT ? > thanks > Is there a theory about ?There are some forms of this, but you have not stated enough detail to understand what you want to do. When I worked in Chemistry a professor was working on Photo Acoustic Spectroscopy. A monochromatic light source is shown on the sample in pulses. The light is absorbed by the sample in relation to its wavelength and the properties of the material. The absorbed light produces vibrations in the sample which can be detected as sound. The sound is analyzed as a function of frequency of the light giving a spectrograph. I expect this is not the sort of thing you are looking for, but you have not given enough info to know what you are thinking about. Rick
On 27 Mar, 19:47, "nino" <npkpe...@libero.it> wrote:> Thanks.! > I only want recognize material froma set of 4-5 possibilities by hitting it > and analizing soundYou need to standardize the shape of the objects, as well as doing both the calibrations and tests in controlled environments. The shape will dominate the signatures on a similar scales as the materials. Imagine comparing the ringing of two wine glasses, one made of 'plain' glass and another made of crystal glass. The compare two glasses of the same kind, but where one has a fracture. Reflections from walls in the room where the test is done, and reverberations in small rooms, will also influence the signatures. Rune
On Mar 26, 11:42 am, "nino" <npkpe...@libero.it> wrote:> How ? correlation FFT ? > thanks > Is there a theory about ?Google: ultrasonic materials analysis Dale B. Dalrymple
Reply by ●March 28, 20092009-03-28
