Can anyone suggest modern options for transmitting a few bits of information from deep in a mine over RF? The transmitter, battery, and antenna should be capable of being carried by a person. The receiver is outside the mine and can have much more size, weight, and power. Specifically, I'm interested in: RF frequency Waveform Reference clock accuracy FEC Thanks, John
RF transmission from a mine
Started by ●March 27, 2009
Reply by ●March 27, 20092009-03-27
On Fri, 27 Mar 2009 09:14:03 -0700 (PDT), John <sampson164@gmail.com> wrote:>Can anyone suggest modern options for transmitting a few bits of >information from deep in a mine over RF? The transmitter, battery, and >antenna should be capable of being carried by a person. The receiver >is outside the mine and can have much more size, weight, and power.Leaky coax? See, for a general discussion, <http://telephonyonline.com/wireless/mag/wireless_trouble_tunnels/> One vendor's glossy: <http://www.afltele.com/resourcecenter/specifications/fiberopticcable/pdfs/LeakyCoaxialCable.pdf> -- Rich Webb Norfolk, VA
John wrote:> Can anyone suggest modern options for transmitting a few bits of > information from deep in a mine over RF? The transmitter, battery, and > antenna should be capable of being carried by a person. The receiver > is outside the mine and can have much more size, weight, and power. > Specifically, I'm interested in: > > RF frequency > Waveform > Reference clock accuracy > FECThe path losses in the ground can be coarsely estimated as: loss = 1dB/m x sqrt(F/30kHz) At VLF, in addition to that, you have the 1/R^3 law due to the near field. The ambient noise follows ~1/F law. Hence, for any practical purpose, the operating distance is limited by 50 meters or so, unless you have a chain of repeaters, leaky waveguides or something like that. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
John wrote:> Can anyone suggest modern options for transmitting a few bits of > information from deep in a mine over RF? The transmitter, battery, and > antenna should be capable of being carried by a person. The receiver > is outside the mine and can have much more size, weight, and power. > Specifically, I'm interested in: > > RF frequency > Waveform > Reference clock accuracy > FEC >As others have said, it would be best to first determine what (if any) conductors run into the mine. Lighting, other power lines, metal pull cables, tracks, etc. You'll almost have to rely on coupling into those. -- Regards, Joerg http://www.analogconsultants.com/ "gmail" domain blocked because of excessive spam. Use another domain or send PM.
On Mar 27, 1:35�pm, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote:> John wrote: > > Can anyone suggest modern options for transmitting a few bits of > > information from deep in a mine over RF? The transmitter, battery, and > > antenna should be capable of being carried by a person. The receiver > > is outside the mine and can have much more size, weight, and power. > > Specifically, I'm interested in: > > > RF frequency > > Waveform > > Reference clock accuracy > > FEC > > The path losses in the ground can be coarsely estimated as: > > loss = 1dB/m x sqrt(F/30kHz) > > At VLF, in addition to that, you have the 1/R^3 law due to the near > field. The ambient noise follows ~1/F law. > > Hence, for any practical purpose, the operating distance is limited by > 50 meters or so, unless you have a chain of repeaters, leaky waveguides > � or something like that. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comThanks. I had already read about lower frequencies penetrating better; it is the skin effect. I haven't seen that approximation though, do you have a reference for it? At this point I'm not wanting to rely on any infrastructure (conduit, wires, leaky coax, etc) inside the mine, but it is possible the receiving site could have something like this: http://en.wikipedia.org/wiki/Beverage_antenna John
John wrote:> On Mar 27, 1:35 pm, Vladimir Vassilevsky <antispam_bo...@hotmail.com> > wrote: >> John wrote: >>> Can anyone suggest modern options for transmitting a few bits of >>> information from deep in a mine over RF? The transmitter, battery, and >>> antenna should be capable of being carried by a person. The receiver >>> is outside the mine and can have much more size, weight, and power. >>> Specifically, I'm interested in: >>> RF frequency >>> Waveform >>> Reference clock accuracy >>> FEC >> The path losses in the ground can be coarsely estimated as: >> >> loss = 1dB/m x sqrt(F/30kHz) >> >> At VLF, in addition to that, you have the 1/R^3 law due to the near >> field. The ambient noise follows ~1/F law. >> >> Hence, for any practical purpose, the operating distance is limited by >> 50 meters or so, unless you have a chain of repeaters, leaky waveguides >> or something like that. >> >> Vladimir Vassilevsky >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > Thanks. I had already read about lower frequencies penetrating better; > it is the skin effect. I haven't seen that approximation though, do > you have a reference for it? > > At this point I'm not wanting to rely on any infrastructure (conduit, > wires, leaky coax, etc) inside the mine, but it is possible the > receiving site could have something like this: > > http://en.wikipedia.org/wiki/Beverage_antenna >Be careful with very low frequency stuff, the defense guys might not like that. Possibly you can find publications from these guys: http://www.cmpdi.co.in/Services/Mining%20Electronics.htm -- Regards, Joerg http://www.analogconsultants.com/ "gmail" domain blocked because of excessive spam. Use another domain or send PM.
John <sampson164@gmail.com> wrote: (snip, Vladimir wrote) (>> The path losses in the ground can be coarsely estimated as:>> loss = 1dB/m x sqrt(F/30kHz)> Thanks. I had already read about lower frequencies penetrating better; > it is the skin effect. I haven't seen that approximation though, do > you have a reference for it?I will guess that it is the absorption due to water.> At this point I'm not wanting to rely on any infrastructure (conduit, > wires, leaky coax, etc) inside the mine, but it is possible the > receiving site could have something like this:There does have to be a hole out of the mine, right? Otherwise how do people get in? At some frequency and power level it will be easier to follow the mine shaft. Otherwise, VLF (or lower) is used by submarines communicating while under water. As I understand it, the resonant frequncy of the earth is 7Hz. That probably takes a lot of power, though, but at resonance it is hard for the enemy to locate you. -- glen
On Mar 27, 5:11�pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> John <sampson...@gmail.com> wrote: > > (snip, Vladimir wrote) > > (>> The path losses in the ground can be coarsely estimated as: > > >> loss = 1dB/m x sqrt(F/30kHz) > > Thanks. I had already read about lower frequencies penetrating better; > > it is the skin effect. I haven't seen that approximation though, do > > you have a reference for it? > > I will guess that it is the absorption due to water. > > > At this point I'm not wanting to rely on any infrastructure (conduit, > > wires, leaky coax, etc) inside the mine, but it is possible the > > receiving site could have something like this: > > There does have to be a hole out of the mine, right? > Otherwise how do people get in? �At some frequency and > power level it will be easier to follow the mine shaft. > > Otherwise, VLF (or lower) is used by submarines communicating > while under water. �As I understand it, the resonant > frequncy of the earth is 7Hz. �That probably takes a > lot of power, though, but at resonance it is hard for > the enemy to locate you. > > -- glenI'm thinking about a trapped miner. Normal infrastructure is broken, the only thing left is seismic or RF. I've read about VLF pulse transmitters in the miner's lamp, received with big loops above. John
On 28 Mar, 00:41, John <sampson...@gmail.com> wrote:> On Mar 27, 5:11�pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote: > > > > > > > John <sampson...@gmail.com> wrote: > > > (snip, Vladimir wrote) > > > (>> The path losses in the ground can be coarsely estimated as: > > > >> loss = 1dB/m x sqrt(F/30kHz) > > > Thanks. I had already read about lower frequencies penetrating better; > > > it is the skin effect. I haven't seen that approximation though, do > > > you have a reference for it? > > > I will guess that it is the absorption due to water. > > > > At this point I'm not wanting to rely on any infrastructure (conduit, > > > wires, leaky coax, etc) inside the mine, but it is possible the > > > receiving site could have something like this: > > > There does have to be a hole out of the mine, right? > > Otherwise how do people get in? �At some frequency and > > power level it will be easier to follow the mine shaft. > > > Otherwise, VLF (or lower) is used by submarines communicating > > while under water. �As I understand it, the resonant > > frequncy of the earth is 7Hz. �That probably takes a > > lot of power, though, but at resonance it is hard for > > the enemy to locate you. > > > -- glen > > I'm thinking about a trapped miner. Normal infrastructure is broken, > the only thing left is seismic or RF. I've read about VLF pulse > transmitters in the miner's lamp, received with big loops above.The problem is that the transmitter needs to be almost as large as the recievers to be efficient. If it isn't efficient you need a large power supply, which migh not be practical as personal equipment. But maybe you could deploy those sorts of things around the mine? Or use seismic transitters? I know some mines are equipped with seismic arrays to locate microfracturing. Use a powered hammer to bang on the walls. The problem with this would be that it requires that you hit bedrock, not stray boulders. Rune
John <sampson164@gmail.com> wrote:> I'm thinking about a trapped miner. Normal infrastructure is broken, > the only thing left is seismic or RF. I've read about VLF pulse > transmitters in the miner's lamp, received with big loops above.Such as after a cave in. I would think the thickness of the cave blockage would be less than the distance to the surface. Also, if there is conduit for lamps some signal would follow that out. -- glen
