Multichannel receiver (SDR based)
Started by alberto.fuggetta ●March 28, 2009
>Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote: > >> For the variety of reasons, the SDR will never reach the performance >> level of the traditional superhet. That may or may not be important >> depending on the particular application. > >I probably agree, but I think you should say what is >fixed and what isn't. If you have a cheap superhet receiver, >and no holds SDR (high sample rate and dynamic range on >the A/D conversion, etc.) then I would probably believe >the SDR was better. > >-- glen >
Thanks everybody for the feedback. Just some info more to clarify my questions. My idea is to translate the band of interest to a very low IF (i.e. 0-25 MHz)by means of a standard analog mixer, then sample the overall band with several channels. The target is to receive (at least) two different channels at the same time with only one analog front end. I guess, it should not be a problem if the received signal strength of different channels is almost the same. Let's simplify the model so that to have only two channels: a strong one and a weak one. If I had an AGC system, how should I set the gain? I was not able to find any similar example in the literature. Thanks Alberto
glen herrmannsfeldt wrote:
> Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote: > > >>For the variety of reasons, the SDR will never reach the performance >>level of the traditional superhet. That may or may not be important >>depending on the particular application. > > > I probably agree, but I think you should say what is > fixed and what isn't. If you have a cheap superhet receiver, > and no holds SDR (high sample rate and dynamic range on > the A/D conversion, etc.) then I would probably believe > the SDR was better.
The farther is the main selectivity stage from the front end, the worse is the dynamic range. Especially as the low IF receiver is hit by the products of the 2nd order nonlinearity whereas the superhet is hit in the third order. The ADC has poor dynamic range, and the digital artifacts come into play also. It also burns a lot of power. The SDR has its place where the flexibility is more important then performance. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
> > >glen herrmannsfeldt wrote: >> Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote: >> >> >>>For the variety of reasons, the SDR will never reach the performance >>>level of the traditional superhet. That may or may not be important >>>depending on the particular application. >> >> >> I probably agree, but I think you should say what is >> fixed and what isn't. If you have a cheap superhet receiver, >> and no holds SDR (high sample rate and dynamic range on >> the A/D conversion, etc.) then I would probably believe >> the SDR was better. > >The farther is the main selectivity stage from the front end, the worse >is the dynamic range. Especially as the low IF receiver is hit by the >products of the 2nd order nonlinearity whereas the superhet is hit in >the third order. The ADC has poor dynamic range, and the digital >artifacts come into play also. It also burns a lot of power. The SDR has
>its place where the flexibility is more important then performance. > >Vladimir Vassilevsky >DSP and Mixed Signal Design Consultant >http://www.abvolt.com >
The receiver architecture I have in mind is the one shown in figure 3.5 (page 61) of the book "RF and Baseband Techniques for Software Defined Radio" (Artech House)
On Sun, 29 Mar 2009 07:18:33 -0500, "alberto.fuggetta"
<alberto.fuggetta@gmail.com> wrote:
>>Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote: >> >>> For the variety of reasons, the SDR will never reach the performance >>> level of the traditional superhet. That may or may not be important >>> depending on the particular application. >> >>I probably agree, but I think you should say what is >>fixed and what isn't. If you have a cheap superhet receiver, >>and no holds SDR (high sample rate and dynamic range on >>the A/D conversion, etc.) then I would probably believe >>the SDR was better. >> >>-- glen >> > >Thanks everybody for the feedback. > >Just some info more to clarify my questions. >My idea is to translate the band of interest to a very low IF (i.e. 0-25 >MHz)by means of a standard analog mixer, then sample the overall band with >several channels. >The target is to receive (at least) two different channels at the same >time with only one analog front end. >I guess, it should not be a problem if the received signal strength of >different channels is almost the same. >Let's simplify the model so that to have only two channels: a strong one >and a weak one. >If I had an AGC system, how should I set the gain? >I was not able to find any similar example in the literature. > >Thanks > >Alberto
Cellular base stations have done this sort of thing for a long time. As someone else pointed out, search the web for "near-far problem" and maybe include "dynamic range" or something like that. It is a difficult problem if you can't adequately constrain the input conditions. If the power levels of the signals fluctuate independently over a broad range it gets bad. If they can change power levels quickly (or, say, come and go quickly) then it's even worse. As Steve mentioned, usually it's advantageous to have an AGC, since it provide the opportunity to maximize SNR in the analog stages, which is where much of the noise and distortion comes from, anyway. The problem with a multi-channel system is that the AGC has to be set according to the composite power of all signals present, plus some headroom for fluctuation. If, for example, most channels are empty and the present channels are low-level, the AGC may crank up the analog gain to increase the level of the weak signals that are present. If a strong signal then appears if adequate headroom was not left in the dynamic range the amps can go into saturation and then it's essentially game over until it can correct itself. So a constant-gain system with a lot of dynamic range does have an advantage for the case where the signal levels can vary broadly and quickly in that it will avoid such dynamic problems as saturation. It's very expensive to build such a system, but sometimes it's what has to be done. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
On Mar 29, 2:18 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote:
> On Sun, 29 Mar 2009 07:18:33 -0500, "alberto.fuggetta" > > <alberto.fugge...@gmail.com> wrote: > >>Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote: > > >>> For the variety of reasons, the SDR will never reach the performance > >>> level of the traditional superhet. That may or may not be important > >>> depending on the particular application. > > >>I probably agree, but I think you should say what is > >>fixed and what isn't. If you have a cheap superhet receiver, > >>and no holds SDR (high sample rate and dynamic range on > >>the A/D conversion, etc.) then I would probably believe > >>the SDR was better. > > >>-- glen > > >Thanks everybody for the feedback. > > >Just some info more to clarify my questions. > >My idea is to translate the band of interest to a very low IF (i.e. 0-25 > >MHz)by means of a standard analog mixer, then sample the overall band with > >several channels. > >The target is to receive (at least) two different channels at the same > >time with only one analog front end. > >I guess, it should not be a problem if the received signal strength of > >different channels is almost the same. > >Let's simplify the model so that to have only two channels: a strong one > >and a weak one. > >If I had an AGC system, how should I set the gain? > >I was not able to find any similar example in the literature. > > >Thanks > > >Alberto > > Cellular base stations have done this sort of thing for a long time. > As someone else pointed out, search the web for "near-far problem" and > maybe include "dynamic range" or something like that. > > It is a difficult problem if you can't adequately constrain the input > conditions. If the power levels of the signals fluctuate > independently over a broad range it gets bad. If they can change > power levels quickly (or, say, come and go quickly) then it's even > worse. > > As Steve mentioned, usually it's advantageous to have an AGC, since it > provide the opportunity to maximize SNR in the analog stages, which is > where much of the noise and distortion comes from, anyway.
I wouldn't say that the analog stages are where the noise and distortion come in. The ADC is a major limiting factor in a digital radio. Although they have been steadily improving over the years, the ADC still has less dynamic range than the analog circuitry driving it. That is why an AGC is more important for a digital back end than an analog one. If you don't do a good job of digitizing the signals, they are hosed from then on.
> The > problem with a multi-channel system is that the AGC has to be set > according to the composite power of all signals present, plus some > headroom for fluctuation. If, for example, most channels are empty > and the present channels are low-level, the AGC may crank up the > analog gain to increase the level of the weak signals that are > present. If a strong signal then appears if adequate headroom was > not left in the dynamic range the amps can go into saturation and then > it's essentially game over until it can correct itself. > > So a constant-gain system with a lot of dynamic range does have an > advantage for the case where the signal levels can vary broadly and > quickly in that it will avoid such dynamic problems as saturation. > It's very expensive to build such a system, but sometimes it's what > has to be done.
Yes, a fast AGC is important. I was working on a system once that was trying to do a job on the cheap using commercial handheld radios. They seemed to do a good job in most respects, but when a signal was keyed, the AGC took some ms to settle down and in the meantime it would oscillate a bit pinching off the start of the signal. No one I was working with would tackle the modification of the AGC to make it respond without this overshoot, so the cheap units were not usable in the end. This was one of those lessons in corporate (dis) functionality. The PM was due for shipping out to a new assignment in a couple of months. When we did the testing and found the receivers did not work in narrow band mode; rather than to take the time and money to fix the problem, the PM swept it under the rug until after he was gone. The project moved ahead as if there was nothing wrong and in the final testing stage they found that it would not work in some environments, so it was literally shelved, never to see the light of day. When the problem was first found, we could have either fixed it, or stopped the project without spending all the money. But then the PM likely would not have gotten his new assignment... I won't tell you who paid for all of this, because you wouldn't like it. I'll just say that no one was held accountable because there was no "profit" incentive. Rick
alberto.fuggetta <alberto.fuggetta@gmail.com> wrote:
> My idea is to translate the band of interest to a very low IF > (i.e. 0-25 >MHz) by means of a standard analog mixer, then > sample the overall band with several channels.
You do realize this creates a completely unrejected image band 25 MHz wide, right next to the band of interest, that is aliased into your passband? (Barring any selectivity at RF, which will be slight.) I have seen successful low-IF receivers, but they would will to place the IF passband at something like 15-40 MHz rather than 0-25 MHz.
That part should be no problem. Steve
> The farther is the main selectivity stage from the front end, the worse > is the dynamic range. Especially as the low IF receiver is hit by the > products of the 2nd order nonlinearity whereas the superhet is hit in > the third order. The ADC has poor dynamic range, and the digital > artifacts come into play also. It also burns a lot of power. The SDR has > its place where the flexibility is more important then performance.
I asked previously about 24 bit audio A/D, but what is available in RF A/D? 24 bit is about 150dB, which doesn't sound so bad. -- glen
>alberto.fuggetta <alberto.fuggetta@gmail.com> wrote: > >> My idea is to translate the band of interest to a very low IF >> (i.e. 0-25 >MHz) by means of a standard analog mixer, then >> sample the overall band with several channels. > >You do realize this creates a completely unrejected image band >25 MHz wide, right next to the band of interest, that is aliased >into your passband? (Barring any selectivity at RF, which >will be slight.) > >I have seen successful low-IF receivers, but they would will to place >the IF passband at something like 15-40 MHz rather than 0-25 MHz. > >>The target is to receive (at least) two different channels at the same >>time with only one analog front end. > >That part should be no problem. > >Steve >
The system is supposed to have all the necessary anti aliasing filters before and after the mixer. The signal is oversampled by means of a delta-sigma and decimated. The desired channel is than translated to zero-IF through a digital image reject mixer. A similar approach is quite common in a cellular receiver for a 200 kHz channel. However, there's no multichannel reception. I guess, this approach is quite common and in my case I would reuse that part. To summarize, it seems that the AGC strategy is not suited for this kind of situation: a very high dynamic range receiver would be more appropriate. Is that correct? Are you aware of any off the shelf product adopting this solution?
>>> My idea is to translate the band of interest to a very low IF >>> (i.e. 0-25 >MHz) by means of a standard analog mixer, then >>> sample the overall band with several channels.
>>You do realize this creates a completely unrejected image band >>25 MHz wide, right next to the band of interest, that is aliased >>into your passband? (Barring any selectivity at RF, which >>will be slight.)
>>I have seen successful low-IF receivers, but they would will to place >>the IF passband at something like 15-40 MHz rather than 0-25 MHz.
>The system is supposed to have all the necessary anti aliasing filters >before and after the mixer.
Let's think about this. If the desired RF passband is (for example) 5.000 to 5.025 GHz, and you mix this down to 0 - 25 MHz, with a LO at 5.000 GHz, then RF frequencies in the range 4.975 to 5.000 GHz will also appear in your passband. This image is too close to your band of interest to reliably filter in the RF front end. Whereas if you use, say, a 4.985 GHz LO, placing your low IF a 15 to 40 MHz, you stand a better chance of filtering out the image which is now at 4.945 - 4.970 GHz -- a ceramic filter might be able to take care of it. If you're doing a single-conversion radio, you either want a zero-IF radio, or a low IF radio where the IF starts somewhere above zero, as opposed to right at zero.
>A similar approach is quite common in a cellular receiver for a 200 kHz >channel.
Sure. They use a frequency plan that works. Steve
> Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote: > > >>The farther is the main selectivity stage from the front end, the worse >>is the dynamic range. Especially as the low IF receiver is hit by the >>products of the 2nd order nonlinearity whereas the superhet is hit in >>the third order. The ADC has poor dynamic range, and the digital >>artifacts come into play also. It also burns a lot of power. The SDR has >>its place where the flexibility is more important then performance. > > > I asked previously about 24 bit audio A/D,
The state of the art audio ADCs have the S/(THD+N) about 120dB in the band from 20Hz to 20kHz.
Depends on the bandwidth and the sample rate. Anywhere from ~40dB at Fsa = 2GHz to ~90dB at 200KHz.
The 150dB is unrealistic. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
