Multichannel receiver (SDR based)
Started by alberto.fuggetta ●March 28, 2009
rickman  <gnuarm@gmail.com> wrote:
>On Mar 29, 2:18 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote:
>> As Steve mentioned, usually it's advantageous to have an AGC, since it >> provide the opportunity to maximize SNR in the analog stages, which is >> where much of the noise and distortion comes from, anyway.
>I wouldn't say that the analog stages are where the noise and >distortion come in. The ADC is a major limiting factor in a digital >radio. Although they have been steadily improving over the years, the >ADC still has less dynamic range than the analog circuitry driving >it.
I would say it a bit differently. It is the goal of a good receiver design that performance be dominated by the noise figure of the front-end of the receiver (i.e. the LNA). You do not want implementation losses deeper in the design to determine performance -- including phase noise, ADC noise, digital round-off, or any other downstream source. These impairments will be there, but the goal is almost always to make their impact small. Some receivers do not meet this goal, and for these receivers in fact something like the ADC might dominate performance. But if so, it would not be considered a really successful design -- you want your sensitivity to be as close as you can get to that of an ideal receiver/modem with the same equivalent input noise. Steve
On Mar 29, 7:57 pm, spop...@speedymail.org (Steve Pope) wrote:
> alberto.fuggetta <alberto.fugge...@gmail.com> wrote: > >>alberto.fuggetta <alberto.fugge...@gmail.com> wrote: > >>> My idea is to translate the band of interest to a very low IF > >>> (i.e. 0-25 >MHz) by means of a standard analog mixer, then > >>> sample the overall band with several channels. > >>You do realize this creates a completely unrejected image band > >>25 MHz wide, right next to the band of interest, that is aliased > >>into your passband? (Barring any selectivity at RF, which > >>will be slight.) > >>I have seen successful low-IF receivers, but they would will to place > >>the IF passband at something like 15-40 MHz rather than 0-25 MHz. > >The system is supposed to have all the necessary anti aliasing filters > >before and after the mixer. > > Let's think about this. If the desired RF passband is (for example) > 5.000 to 5.025 GHz, and you mix this down to 0 - 25 MHz, with > a LO at 5.000 GHz, then RF frequencies in the range 4.975 to 5.000 > GHz will also appear in your passband. This image is too close > to your band of interest to reliably filter in the RF front end. > > Whereas if you use, say, a 4.985 GHz LO, placing your low IF a > 15 to 40 MHz, you stand a better chance of filtering out the image > which is now at 4.945 - 4.970 GHz -- a ceramic filter might be able > to take care of it. > > If you're doing a single-conversion radio, you either want a zero-IF > radio, or a low IF radio where the IF starts somewhere above zero, > as opposed to right at zero. > > >A similar approach is quite common in a cellular receiver for a 200 kHz > >channel. > > Sure. They use a frequency plan that works.
It has been a while since I did much with the front end of radios, but I seem to recall a plan for a receiver that skipped the IF and directly converted the RF to baseband with one conversion. They used an LO in the middle of the band of interest and did the conversion in quadrature so that both frequencies above and below 0 Hz were in the passband. So aliasing of signals just outside the passband was not a problem. I never saw this receiver operate, but supposedly this was how they were doing it. Rick
>> If you're doing a single-conversion radio, you either want a zero-IF >> radio, or a low IF radio where the IF starts somewhere above zero, >> as opposed to right at zero.
>It has been a while since I did much with the front end of radios, but >I seem to recall a plan for a receiver that skipped the IF and >directly converted the RF to baseband with one conversion. They used >an LO in the middle of the band of interest and did the conversion in >quadrature so that both frequencies above and below 0 Hz were in the >passband. So aliasing of signals just outside the passband was not a >problem.
Right, that would be a zero-IF, single conversion radio. The OP was describing a low-IF radio instead. (At least, that was my interpretation.) A low-IF radio does not have a quadrature mixer and needs only one ADC instead of two; so conceptually it is one of the least expensive radio architectures possible. Steve
Steve Pope wrote:
> I would say it a bit differently. It is the goal of a good > receiver design that performance be dominated by the noise > figure of the front-end of the receiver (i.e. the LNA).
Wrong. Achieving the near ideal noise figure is not a problem; it is just the matter of a good LNA and enough gain. Especially as at the frequencies up to 100MHz the ambient noise is dominating, at the higher frequencies if the antenna is looking in the horizontal direction, there is no point in having the noise temperature lower then ~300K. The goal of the receiver is the maximum dynamic range from the noise floor to the IP3 (or the IP2 in the case of the low IF or zero IF crap). The SDR shit is additionally limited by the ADC performance and digital artifacts.
> Some receivers do not meet this goal, and for these receivers > in fact something like the ADC might dominate performance.
My dear highly educated friend. Have you ever designed a receiver?
> But if so, it would not be considered a really successful design -- > you want your sensitivity to be as close as you can get to that of > an ideal receiver/modem with the same equivalent input noise.
Bla-bla-bla, bla-bla-bla. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Steve Pope wrote:
> rickman <gnuarm@gmail.com> wrote: >
>>It has been a while since I did much with the front end of radios, but >>I seem to recall a plan for a receiver that skipped the IF and >>directly converted the RF to baseband with one conversion. They used >>an LO in the middle of the band of interest and did the conversion in >>quadrature so that both frequencies above and below 0 Hz were in the >>passband. So aliasing of signals just outside the passband was not a >>problem. > > > Right, that would be a zero-IF, single conversion radio.
Utterly bad idea. Poor performance guaranteed.
> The OP > was describing a low-IF radio instead. (At least, that was my > interpretation.) A low-IF radio does not have a quadrature mixer > and needs only one ADC instead of two; so conceptually it is > one of the least expensive radio architectures possible.
It is the crap architecture. It suffers from all sorts of problems starting from the second order nonlinearity products falling in the band to the shooting yourself in the foot by the feedthrough of your own geterodyne to antenna and re-modulating it on all sorts of nonlinearities around, and then receiving it back. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky  <antispam_bogus@hotmail.com> wrote:
>Steve Pope wrote:
>> I would say it a bit differently. It is the goal of a good >> receiver design that performance be dominated by the noise >> figure of the front-end of the receiver (i.e. the LNA).
>Wrong.
>Achieving the near ideal noise figure is not a problem; it is just the >matter of a good LNA and enough gain. Especially as at the frequencies >up to 100MHz the ambient noise is dominating, at the higher frequencies >if the antenna is looking in the horizontal direction, there is no point >in having the noise temperature lower then ~300K.
>The goal of the receiver is the maximum dynamic range from the noise >floor to the IP3 (or the IP2 in the case of the low IF or zero IF crap).
This is one example of what I wrote above. If your performance was dominated by a too-low value of IP3, then that deviates from a good (or at least, ideal) design.
>The SDR shit is additionally limited by the ADC performance and digital >artifacts.
I'm wondering if I was not clear, as you seem to be espousing the same viewpoint that I was. If the ADC is dominating the performance -- which we agree is not particularly desirable, and is likely to occur in the OP's proposed design -- then the EIN is *not* dominating performance, true? (I am not claiming such receivers do not exist; however if during the design phase, there is a strongly-held belief that IP3, or the ADC or the phase noise or similar will be dominant, then in my view something is amiss...) Thanks as always for your contributions, Vladimir. Steve
(snip, I wrote)
>> I asked previously about 24 bit audio A/D,
> The state of the art audio ADCs have the S/(THD+N) > about 120dB in the band from 20Hz to 20kHz.
So about 20 bits. It seems that 24 bit recorders are much more popular than 20 bit recorders. In any case, 20 bits is enough for me. I can record 24 bit WAV files, and select the appropriate 16 bits. That allows keeping the record level low for unexpected transients. (Symphonies with drums and cymbals can easily do that.)
>> but what is available in RF A/D?
> Depends on the bandwidth and the sample rate. > Anywhere from ~40dB at Fsa = 2GHz to ~90dB at 200KHz.
I remember a high speed sampling system many years ago (1980's) that ran 8 bit at 200MHz. The hardware included a four bit A/D converter, a four bit D/A converter, a subtractor, and another four bit A/D. The incoming signal was digitized, then converted back to analog and subtracted from the input signal. The difference into the second four bit converter gave the low four bits for the result. It seems that fast eight bit converters weren't available. Maybe some tricks could still be used for fast conversion at 16 bits or more.
>> 24 bit is about 150dB, which doesn't sound so bad.
> The 150dB is unrealistic.
I agree. Even if the A/D was that good, would the other amplifiers be? For live recording, the background noise is never that low, anyway. -- glen
>I agree. Even if the A/D was that good, would >the other amplifiers be? For live recording, the >background noise is never that low, anyway.
A live audio source probably has the largest dynamic range of any source you will ever see in your engineering career. Certain musical instruments have huge intrinsic dynamic range (percussion and piano, for example), and audio amplifiers can have a huge dynamic range also -- it requires low impedances and large voltage swings, but it can be and is done. Steve
glen herrmannsfeldt wrote:
> I remember a high speed sampling system many years > ago (1980's) that ran 8 bit at 200MHz. The hardware > included a four bit A/D converter, a four bit D/A > converter, a subtractor, and another four bit A/D. > The incoming signal was digitized, then converted > back to analog and subtracted from the input signal. > The difference into the second four bit converter > gave the low four bits for the result. It seems > that fast eight bit converters weren't available. > > Maybe some tricks could still be used for fast > conversion at 16 bits or more.
This is what is called the pipelined ADC. The ADCs of this type are often used for video applications; they can achieve ~14 true bits at the rates ~10 megasamples.
>>>24 bit is about 150dB, which doesn't sound so bad. > >>The 150dB is unrealistic. > > > I agree. Even if the A/D was that good, would > the other amplifiers be?
Signal/noise of 150dB is feasible, however Signal/(Noise+distortion) is not. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Sun, 29 Mar 2009 23:39:03 -0500, Vladimir Vassilevsky
> > >Steve Pope wrote: > >> rickman <gnuarm@gmail.com> wrote: >> > >>>It has been a while since I did much with the front end of radios, but >>>I seem to recall a plan for a receiver that skipped the IF and >>>directly converted the RF to baseband with one conversion. They used >>>an LO in the middle of the band of interest and did the conversion in >>>quadrature so that both frequencies above and below 0 Hz were in the >>>passband. So aliasing of signals just outside the passband was not a >>>problem. >> >> >> Right, that would be a zero-IF, single conversion radio. > >Utterly bad idea. Poor performance guaranteed.
Also called a "direct conversion" architecture. They're everywhere, since they're cheap, low-power, greatly simplify the architecture, and also allow tuning over a very broad range. Pretty much every 802.11 device made uses this architecture, as do many handsets, etc. The small performance tradeoff is often taken in order to get the size, cost, and power consumption reduction that comes with it.
>> The OP >> was describing a low-IF radio instead. (At least, that was my >> interpretation.) A low-IF radio does not have a quadrature mixer >> and needs only one ADC instead of two; so conceptually it is >> one of the least expensive radio architectures possible. > >It is the crap architecture. It suffers from all sorts of problems >starting from the second order nonlinearity products falling in the band >to the shooting yourself in the foot by the feedthrough of your own >geterodyne to antenna and re-modulating it on all sorts of >nonlinearities around, and then receiving it back.
Digital IF is crap? As Steve mentioned, it's low-cost and high performance. I've built systems this way that had nearly immeasurable implementation loss and kept costs down. Low MER on a modulator is easier this way, too, IMHO. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
