Steve Pope <spope33@speedymail.org> wrote: (snip)>>I agree. Even if the A/D was that good, would >>the other amplifiers be? For live recording, the >>background noise is never that low, anyway.> A live audio source probably has the largest dynamic > range of any source you will ever see in your engineering > career.Yes. In this case it is also a live audience with lots of kids. I try to stay away from the noisier ones, but you never know. Also, fans and even a PA system with audible hum. -- glen
Multichannel receiver (SDR based)
Started by ●March 28, 2009
Reply by ●March 30, 20092009-03-30
Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote:> Signal/noise of 150dB is feasible, however > Signal/(Noise+distortion) is not.Which distortion source(s) are you considering? In the OP case of wanting to recover a strong and weak signal at the same time, that could be a problem. In my case, wanting to record a signal with unknown in advance peaks, maybe it isn't so much of a problem. Strange thought. Is it possible to measure the non-linearities of the A/D converter, and then correct for them digitally? -- glen
glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote:>Strange thought. Is it possible to measure the >non-linearities of the A/D converter, and then correct >for them digitally?Sure. Some ADC's have an error ROM feeding an auxillary DAC combining with the ADC input. It's a down-and-dirty, low-level correction but it can be made to work. It could even be hidden in the guts of some commerical ADC IP you might buy. Steve
Eric Jacobsen <eric.jacobsen@delete.ieee.org> wrote:>On Sun, 29 Mar 2009 23:39:03 -0500, Vladimir Vassilevsky[Low-IF]>>It is the crap architecture. It suffers from all sorts of problems >>starting from the second order nonlinearity products falling in the band >>to the shooting yourself in the foot by the feedthrough of your own >>geterodyne to antenna and re-modulating it on all sorts of >>nonlinearities around, and then receiving it back.>Digital IF is crap? As Steve mentioned, it's low-cost and high >performance. I've built systems this way that had nearly >immeasurable implementation loss and kept costs down. Low MER on a >modulator is easier this way, too, IMHO.If the requirements are just right, a low-IF receiver can meet spec and be about the least expensive compliant architecture. But for tighter requirements, the incentive is to go -- at added cost - to a a zero-IF (common in WLAN as you state), or all the way to a superhet (best performing, nearly always, since you can add selectivity as the first IF). These are just generalizations, but they often hold. Steve
glen herrmannsfeldt wrote:> Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote: > > >>Signal/noise of 150dB is feasible, however >>Signal/(Noise+distortion) is not. > > > Which distortion source(s) are you considering?At those levels of distortion, everything is nonlinear, time variant, and has memory. That includes resistors, capacitors and conductors.> In the OP case of wanting to recover a strong and weak > signal at the same time, that could be a problem.OP is the stupident. He should start with building a basic AM/FM radio from the basic components. There is no point in discussing the rocket science before that.> In my case, wanting to record a signal with unknown > in advance peaks, maybe it isn't so much of a problem.Can you describe what problem are you working on?> Strange thought. Is it possible to measure the > non-linearities of the A/D converter, and then correct > for them digitally?The crude static nonlinearities can be corrected. BTW, that is routinely done in the pipelined ADCs that we discussed before. You can do some further improvement using the Volterra series math, however the variance of the parameters with temperature, voltage, time, etc. quickly sets the limit to that. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Eric Jacobsen wrote:> On Sun, 29 Mar 2009 23:39:03 -0500, Vladimir Vassilevsky > <antispam_bogus@hotmail.com> wrote: >>>> >>>Right, that would be a zero-IF, single conversion radio. >> >>Utterly bad idea. Poor performance guaranteed. > > Pretty much every 802.11 device made uses this architecture, as do > many handsets, etc. The small performance tradeoff is often taken in > order to get the size, cost, and power consumption reduction that > comes with it.Exactly. This is a cheap stuff intended to operate at the tabletop distances, with the ideal signal and away from the any sources of interference.> Digital IF is crap?But it really is.> As Steve mentioned, it's low-cost and high > performance. I've built systems this way that had nearly > immeasurable implementation loss and kept costs down. Low MER on a > modulator is easier this way, too, IMHO.From time to time, just another company introduces just another low IF or direct conversion chipset, promising the miraculous performance. As soon as you connect the external antenna, that low IF receiver is swamped in the various IMD products. Seen that many times. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Mon, 30 Mar 2009 09:05:42 -0500, Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote:> > >Eric Jacobsen wrote: > >> On Sun, 29 Mar 2009 23:39:03 -0500, Vladimir Vassilevsky >> <antispam_bogus@hotmail.com> wrote: >> > >>>> >>>>Right, that would be a zero-IF, single conversion radio. >>> >>>Utterly bad idea. Poor performance guaranteed. >> >> Pretty much every 802.11 device made uses this architecture, as do >> many handsets, etc. The small performance tradeoff is often taken in >> order to get the size, cost, and power consumption reduction that >> comes with it. > >Exactly. This is a cheap stuff intended to operate at the tabletop >distances, with the ideal signal and away from the any sources of >interference.I think you don't understand 802.11 very well. The dominating impairments are interference and frequency selective channels, so the little bit of performance loss from a direct conversion receiver will essentially never be noticed.>> Digital IF is crap? > >But it really is. > >> As Steve mentioned, it's low-cost and high >> performance. I've built systems this way that had nearly >> immeasurable implementation loss and kept costs down. Low MER on a >> modulator is easier this way, too, IMHO. > > From time to time, just another company introduces just another low IF >or direct conversion chipset, promising the miraculous performance. As >soon as you connect the external antenna, that low IF receiver is >swamped in the various IMD products. Seen that many times.Having built many such systems over the years in my experience sampled IF systems have always exhibited the least implementation loss. There are always tradeoffs, but if you know what you're doing you can get very good performance from low-IF systems. These days there are other considerations that drive tradeoffs to direct conversion, but it's generally understood that there's performance loss associated with that method. Superhet is good, but usually way more complicated and expensive than necessary. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
Reply by ●March 31, 20092009-03-31
Eric Jacobsen <eric.jacobsen@delete.ieee.org> wrote:>On Mon, 30 Mar 2009 09:05:42 -0500, Vladimir Vassilevsky>Vladimir wrote,>>Eric Jacobsen wrote:>>> On Sun, 29 Mar 2009 23:39:03 -0500, Vladimir Vassilevsky[ a zero-IF, single conversion radio ]>>>>Utterly bad idea. Poor performance guaranteed.>>> Pretty much every 802.11 device made uses this architecture, as do >>> many handsets, etc. The small performance tradeoff is often taken in >>> order to get the size, cost, and power consumption reduction that >>> comes with it.>>Exactly. This is a cheap stuff intended to operate at the tabletop >>distances, with the ideal signal and away from the any sources of >>interference.>I think you don't understand 802.11 very well.>The dominating impairments are interference and frequency selective >channels, so the little bit of performance loss from a direct >conversion receiver will essentially never be noticed.>>> Digital IF is crap?>>But it really is.>>> As Steve mentioned, it's low-cost and high >>> performance. I've built systems this way that had nearly >>> immeasurable implementation loss and kept costs down. Low MER on a >>> modulator is easier this way, too, IMHO.>> From time to time, just another company introduces just another low IF >>or direct conversion chipset, promising the miraculous performance. As >>soon as you connect the external antenna, that low IF receiver is >>swamped in the various IMD products. Seen that many times.>Having built many such systems over the years in my experience sampled >IF systems have always exhibited the least implementation loss.>There are always tradeoffs, but if you know what you're doing you can >get very good performance from low-IF systems. These days there are >other considerations that drive tradeoffs to direct conversion, but >it's generally understood that there's performance loss associated >with that method.This is a very interesting discussion and I will say my opinion lies mid-way between those of Eric and Vladimir. First, to answer Vladimir's prior question about my experience, while I have been a contributing designer to several radio chips and the lead designer of discrete (e.g. connectorized) radios, I have not been a lead radio chip designer and so I cannot claim the Full Monty of authority here. With that out of the way, what Vladimir says makes a lot of sense. The superhet is superior because it allows you to introduce selectivity earlier in the signal chain, and it allows a frequency plan that allows your images to fall somewhere where they can be filtered out. In contrast, the zero-IF approach requires near-ideal performance from a quadrature mixer at RF, and the low-IF approach can have images too close-in, as I previously described. Yes, they can be made to meet spec and they might be very economical, but they are not as naturally robust, and if some interference condition comes up that your specs did not anticipate, you're much more likely to be in trouble. It does not surprise me if most 802.11 radios now are single-conversion. My 802.11 experience is mostly prior to 2005, but back in that time frame I was at least somewhat familiar with nearly every 802.11 radio in use (it was my job to specify and evaluate these radios), and at that time they were nearly all superhets. However, nearly every design group had a stated goal of moving to single-conversion. This was a challenging goal -- implementing a good-enough quadrature mixer at 5 GHz, without burning enormous power, was not exactly an obvious thing to be able to do. However given five years more progress on the problem, it's easy for me to also accept Eric's point of view that these are now the preferred designs. (Plus, many of them still do not implement the 4.9 - 6 GHz band, or do not implement all of it, which does make things easier.) (But with regards to the OP's situation, his stated frequency plan combined with his stated architecture seem like a problem to me; but he could probably fix things up and still use a single-conversion approach.) Steve
On Tue, 31 Mar 2009 05:00:41 +0000 (UTC), spope33@speedymail.org (Steve Pope) wrote:>Eric Jacobsen <eric.jacobsen@delete.ieee.org> wrote: > >>On Mon, 30 Mar 2009 09:05:42 -0500, Vladimir Vassilevsky > >>Vladimir wrote, > >>>Eric Jacobsen wrote: > >>>> On Sun, 29 Mar 2009 23:39:03 -0500, Vladimir Vassilevsky > >[ a zero-IF, single conversion radio ] > >>>>>Utterly bad idea. Poor performance guaranteed. > >>>> Pretty much every 802.11 device made uses this architecture, as do >>>> many handsets, etc. The small performance tradeoff is often taken in >>>> order to get the size, cost, and power consumption reduction that >>>> comes with it. > >>>Exactly. This is a cheap stuff intended to operate at the tabletop >>>distances, with the ideal signal and away from the any sources of >>>interference. > >>I think you don't understand 802.11 very well. > >>The dominating impairments are interference and frequency selective >>channels, so the little bit of performance loss from a direct >>conversion receiver will essentially never be noticed. > >>>> Digital IF is crap? > >>>But it really is. > >>>> As Steve mentioned, it's low-cost and high >>>> performance. I've built systems this way that had nearly >>>> immeasurable implementation loss and kept costs down. Low MER on a >>>> modulator is easier this way, too, IMHO. > >>> From time to time, just another company introduces just another low IF >>>or direct conversion chipset, promising the miraculous performance. As >>>soon as you connect the external antenna, that low IF receiver is >>>swamped in the various IMD products. Seen that many times. > >>Having built many such systems over the years in my experience sampled >>IF systems have always exhibited the least implementation loss. > >>There are always tradeoffs, but if you know what you're doing you can >>get very good performance from low-IF systems. These days there are >>other considerations that drive tradeoffs to direct conversion, but >>it's generally understood that there's performance loss associated >>with that method. > >This is a very interesting discussion and I will say my opinion >lies mid-way between those of Eric and Vladimir. > >First, to answer Vladimir's prior question about my experience, >while I have been a contributing designer to several radio chips >and the lead designer of discrete (e.g. connectorized) radios, >I have not been a lead radio chip designer and so I cannot claim >the Full Monty of authority here. > >With that out of the way, what Vladimir says makes a lot of sense. >The superhet is superior because it allows you to introduce >selectivity earlier in the signal chain, and it allows a >frequency plan that allows your images to fall somewhere where >they can be filtered out. In contrast, the zero-IF approach >requires near-ideal performance from a quadrature mixer at RF, >and the low-IF approach can have images too close-in, as I previously >described. Yes, they can be made to meet spec and they >might be very economical, but they are not as naturally robust, >and if some interference condition comes up that your specs did >not anticipate, you're much more likely to be in trouble.There are certainly issues that must be considered with any architecture. Managing selectivity and dynamic range is a concern in all of them, and the tradeoffs are just different for each, IMHO. Modern synths and image-reject mixers are quite good for controlling channel and phase balance and LO bleed-through (DC-offset). In the past those were always the things that made that last baseband mix stage difficult or time-consuming to tweak on the factory floor. Initially that's why (in my experience) many designs moved to digital-IF, so that those tweak steps could be avoided in the factory. The improved performance due to perfect channel and phase balance and DC rejection were a bonus. Paying attention to the areas that get harder just goes with the territory. That being said, one just has to understand the operating realities and requirements and design to them, regardless of the architecture chosen. That includes finding a band-plan that meets one's needs when direct conversion is not used.>It does not surprise me if most 802.11 radios now are >single-conversion. My 802.11 experience is mostly prior >to 2005, but back in that time frame I was at least somewhat >familiar with nearly every 802.11 radio in use (it was my >job to specify and evaluate these radios), and at that time they >were nearly all superhets. However, nearly every design >group had a stated goal of moving to single-conversion. >This was a challenging goal -- implementing a good-enough >quadrature mixer at 5 GHz, without burning enormous power, >was not exactly an obvious thing to be able to do. However >given five years more progress on the problem, it's easy >for me to also accept Eric's point of view that these are now >the preferred designs. (Plus, many of them still do not >implement the 4.9 - 6 GHz band, or do not implement all of it, >which does make things easier.)I think much of the switch for some implementers came between 802.11b and a/g. The a/g/n specs were intended from the beginning to work with direct conversion (hence no data in the center subcarrier). Some of the early a/g implementations may have been something other than direct conversion, but I don't think anybody is using anything other than direct conversion now. At least, the implementations of which I'm aware (and there aren't that many) are zero-IF. FWIW, we're in the middle of a project that has multi-band tuning requirements, and the plan at the moment (which is reasonably mature) is to use direct conversion for all cases, UHF, 2.4G, 5G, 8G. It doesn't look like a big problem. It's not trivial by any means, but definitely doable with good performance.>(But with regards to the OP's situation, his stated frequency >plan combined with his stated architecture seem like a problem to >me; but he could probably fix things up and still use a >single-conversion approach.)I've just been speaking generally, not in the specific context of the OP. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
Reply by ●April 1, 20092009-04-01
"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message news:rf05t41aiqadfr2r39cbse5gepa434hpp6@4ax.com...> On Tue, 31 Mar 2009 05:00:41 +0000 (UTC), spope33@speedymail.org> Modern synths and image-reject mixers are quite good for controlling > channel and phase balance and LO bleed-through (DC-offset).The acceptance level was lowered: it was decided that 20dB is "very good". As for the LO leakage, this is the worse problem then just the offset: it gets modulated with AC and jams not only the similar receivers nearby, but your own receiver as well.> That being said, one just has to understand the operating realities > and requirements and design to them, regardless of the architecture > chosen.My prior experience is in the SMR and WLL; so I am inclined to look from that prospective.> That includes finding a band-plan that meets one's needs > when direct conversion is not used.When operating in the heavily trashed ISM bands, you don't have any choice and nothing is for granted. Hence the receiver should be designed keeping the interference in mind.> >It does not surprise me if most 802.11 radios now are > >single-conversion.It does not surprise me that many of 802.11 radios now are very poor performance, as they drop communication even at the distances less then 10m. Vladimir Vassilevsky DSP and Mixed Signal Consultant www.abvolt.com
