Multichannel receiver (SDR based)
Started by alberto.fuggetta ●March 28, 2009
> >"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message >news:rf05t41aiqadfr2r39cbse5gepa434hpp6@4ax.com... > >> On Tue, 31 Mar 2009 05:00:41 +0000 (UTC), spope33@speedymail.org > >> Modern synths and image-reject mixers are quite good for controlling >> channel and phase balance and LO bleed-through (DC-offset). > >The acceptance level was lowered: it was decided that 20dB is "very
good".
>As for the LO leakage, this is the worse problem then just the offset:
it
>gets modulated with AC and jams not only the similar receivers nearby,
but
>your own receiver as well. > >> That being said, one just has to understand the operating realities >> and requirements and design to them, regardless of the architecture >> chosen. > >My prior experience is in the SMR and WLL; so I am inclined to look from >that prospective. > >> That includes finding a band-plan that meets one's needs >> when direct conversion is not used. > >When operating in the heavily trashed ISM bands, you don't have any
choice
>and nothing is for granted. Hence the receiver should be designed
keeping
>the interference in mind. > >> >It does not surprise me if most 802.11 radios now are >> >single-conversion. > >It does not surprise me that many of 802.11 radios now are very poor >performance, as they drop communication even at the distances less then
10m.
> >Vladimir Vassilevsky >DSP and Mixed Signal Consultant >www.abvolt.com > >
Thanks everybody for the precious feedback. However, I didn't want to focus the attention on the "very low IF" vs "direct conversion" choice. The main question is how to implement a multichannel receiver (i.e simultaneous reception) when there are signals that can quickly vary their power over the time. I understood that a BTS architecture already implement this solution, unfortunately I was not able to find proper docs about that. Thanks Alberto
You don't yet know how precious it is. Wait till I send you the invoice.
> The main question is how to implement a multichannel receiver (i.e > simultaneous reception) when there are signals that can quickly vary their > power over the time. > I understood that a BTS architecture already implement this solution, > unfortunately I was not able to find proper docs about that.
Architecture is a good word for that, since BTS is a piece of real estate. First, there is a huge cavity filter selecting the band of interest. Then there is a splitter and a bunch of conventional narrowband receivers. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
> The acceptance level was lowered: it was decided that 20dB is > "very good". As for the LO leakage, this is the worse problem > then just the offset: it gets modulated with AC and jams not > only the similar receivers nearby, but your own receiver as well.
Another mechanism by which LO leakage is not just a DC offset is when it occurs in the transmitter. Due to frequency offset between RX and TX, it shows up as a low-frequency tone. In some systems, this might actually overlay one of the datatones. Steve
On Mar 28, 9:01&#4294967295;pm, Vladimir Vassilevsky <antispam_bo...@hotmail.com>
wrote:
> alberto.fuggetta wrote: > > I'm new in the forum. I started reading some book and papers about SDR and > > suddenly had some question about a multichannel receiver. > > [...] > > For the variety of reasons, the SDR will never reach the performance > level of the traditional superhet. That may or may not be important > depending on the particular application. >
Have u heard of Vanu? They have built GSM basestations using SDR. I will be interested to know the reasons u have in mind
> > I am not aware of state of the art solutions for multi channel reception > > in case of different signal strength. Any clue on that? > > You got to have enough of the dynamic range. > Google "RF digital subsystem", "Near-Far problem". Check the web sites > of AD, TI, Intersil and other major vendors. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.com
On Apr 1, 4:44&#4294967295;pm, YTach <y.tachw...@gmail.com> wrote:
> On Mar 28, 9:01&#4294967295;pm, Vladimir Vassilevsky <antispam_bo...@hotmail.com> > wrote:> alberto.fuggetta wrote: > > > I'm new in the forum. I started reading some book and papers about SDR and > > > suddenly had some question about a multichannel receiver. > > > [...] > > > For the variety of reasons, the SDR will never reach the performance > > level of the traditional superhet. That may or may not be important > > depending on the particular application. > > Have u heard of Vanu? They have built GSM basestations using SDR. I > will be interested to know the reasons u have in mind
Nevermind, I should have read the whole thread. A lot of discussion about this issue.
> > > > I am not aware of state of the art solutions for multi channel reception > > > in case of different signal strength. Any clue on that? > > > You got to have enough of the dynamic range. > > Google "RF digital subsystem", "Near-Far problem". Check the web sites > > of AD, TI, Intersil and other major vendors. > > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultanthttp://www.abvolt.com
On Apr 1, 4:36&#4294967295;am, "alberto.fuggetta" <alberto.fugge...@gmail.com>
wrote:
> >"Eric Jacobsen" <eric.jacob...@ieee.org> wrote in message > >news:rf05t41aiqadfr2r39cbse5gepa434hpp6@4ax.com... > > >> On Tue, 31 Mar 2009 05:00:41 +0000 (UTC), spop...@speedymail.org > > >> Modern synths and image-reject mixers are quite good for controlling > >> channel and phase balance and LO bleed-through (DC-offset). > > >The acceptance level was lowered: it &#4294967295;was decided that 20dB is "very > good". > >As for the LO leakage, &#4294967295;this is the worse problem then just the offset: > it > >gets modulated with AC and jams not only the similar receivers nearby, > but > >your own receiver as well. > > >> That being said, one just has to understand the operating realities > >> and requirements and design to them, regardless of the architecture > >> chosen. > > >My prior experience is in the SMR and WLL; so I am inclined to look from > >that prospective. > > >> That includes finding a band-plan that meets one's needs > >> when direct conversion is not used. > > >When operating in the heavily trashed ISM bands, you don't have any > choice > >and nothing is for granted. Hence the receiver should be designed > keeping > >the interference in mind. > > >> >It does not surprise me if most 802.11 radios now are > >> >single-conversion. > > >It does not surprise me that many of 802.11 radios now are very poor > >performance, as they drop communication even at the distances less then > 10m. > > >Vladimir Vassilevsky > >DSP and Mixed Signal Consultant > >www.abvolt.com > > Thanks everybody for the precious feedback. > However, I didn't want to focus the attention on the "very low IF" vs > "direct conversion" choice. > The main question is how to implement a multichannel receiver (i.e > simultaneous reception) when there are signals that can quickly vary their > power over the time. > I understood that a BTS architecture already implement this solution, > unfortunately I was not able to find proper docs about that. > > Thanks > > Alberto
Are you looking for some details like this: www.eetindia.co.in/ARTICLES/2002APR/2002APR08_NTEK_RFD_DSP_CT_TAC.PDF?SOURCES=DOWNLOAD channelization in that article is done in FPGA. In SDRs, there is a group of people who implement the BB DSP in GPP and others DSP+FPGA but in most of the cases, FPGA is used after ADCs to perform some high speed processing such as DDCs.
> Thanks everybody for the precious feedback. However, I didn't > want to focus the attention on the "very low IF" vs "direct > conversion" choice. The main question is how to implement a > multichannel receiver (i.e simultaneous reception) when there > are signals that can quickly vary their power over the time.
The general answer is you will need a very well thought-out AGC algorithm. Note that in most wireless systems, signals which are not interferers do not arrive at completely random times. There will be an expected time frame in which your AGC is expected to function dynamically, and there will probably be other time frames in which the AGC is expected to be frozen. You algorithm needs to function over the any expected scenarios of signal statistics (both signals of interest, and interferers). This suggests you will need a lot of simulation. You may also find it useful to use signal processing to try to track smaller gain (and phase) changes in each channel. And to couple results from the AGC with your power control algorithms. The problem you are describing could well be a significant fraction of the entire receiver/modem design effort. Steve
