Windowing in the Frequency Domain
Started by OldUncleSilas ●April 4, 2009
Rune Allnor wrote:
> My position might seem absurd in context with the OP. > However, a totally separate discussion started with > this post of mine: > > http://groups.google.no/group/comp.dsp/msg/be1c2b9af37a1641?hl=no >
Which reminds me: you sort of diverted the subject there from "how" to "why" (do time-domain windowing while using the SDFT); I am still interested to know "how". One reason is to be able to try out the Kaiser window, widely used in pvoc. Being not based on cosines, there is no obvious way to do it as a convolution, and quite possibly no non-obvious way either. Needs more maths chops than I am capable of, anyway. I fear it would require too high-order a convolution to be useful, unless the audio results are truly stellar. Richard Dobson
Rune Allnor wrote:
> > Only when you know what you aim to achieve, can you > start discussing how to go about achieving it. >
Right. So why do you keep insisting one method is better than another when you don't what the aim is? -jim
Rune Allnor wrote:
> > So you have a messy (magnitude) spectrum you would > like to 'clean up' to be better able to see what > is 'actual' spectral features and what is just > noise and random fluctuations? >
Not really. The plain output of the SDFT corresponds to equally plain rectangular windowing, where the input is arbitrary audio invariably not periodic to the window length. So what you get is the usual spectral leakage due to the rectangular window, that hides the peaks of low-level components. Beyond that, it is not "messy" at all in the way you suggest.
> If my interpretation is correct, what you have is > a real-life application for PSD estimation. Just for > fun, try to use the 'proper' N-1-period windows and > see how the results compare to both the 'raw' spectrum > and the 3pt kernel spectrum. You'd presumably want > to do this with recorded data, not on-line.
As part of my development work, I made a test program to perform among other things a direct comparison between the time-domain window function and the frequency-domain convolution (via ifft), basically to make sure the code for the latter was correct and like was being compared to like. They are, to at least 10 decimal places, with the usual f/p roundoff accounting for the error differences at and below 1.0e-10. Maybe that can be improved, but it was decided that was "good enough" give the very short duration for the project. Both forms comply with your "N-1 period" criterion. I have in fact not attempted the other form ("N period"?). For what we are trying to do (interesting musical transformations), I suspect the difference between N and N-1 windowing is rather less critical than for the processes you refer to. But if I ever get the chance to do a follow-up, that may be something to look at in the cause of filling in the gaps.
> > My prediction is that the 3pt averaged spectrum will > be a lot closer to the 'raw' spectrum, but the N-1- > period windowed spectrum will show smoother spectral > features.
Given the windows are identical (allowing for the above low-level numerical differences), hopefully it will not surprise you that both windowing methods give similarly identical results on the same input.
> > I won't have any opinions about what method to use > (that would depend on what you look for in the spectra), > just ask you to try to be aware what you are doing and > why. From the above experiment you might end up with > the conclusion that you don't need the windows at all. >
I tried it early on. I do, as I need the separation of partial amplitudes the windowing give me. We may want to do Cool Things such as removing odd partials, stretching them, making sounds inharmonic etc. There may be new "exciter" algorithms just waiting to be developed. To say nothing of partial tracking, which is something I do want to investigate, not least as we already have such tools in Csound.
> A more interesting outcome might be that you start > experimenting with weighted averages in spectrum domain, > where the weight coefficients have nothing to do with > the 'classic' window functions at all. If all you do > is to compute weighted averages in spectrum domain, why > constrain the weight coefficients by time-doamin > properties?
It was more important at this early stage to be able to relate the SDFT/SPV results directly to familiar time-domain equivalents. It is nevertheless a very interesting question. We have different priorities at present (such as developing a Constant-Q version of the transform), but I did experiment briefly with hacking a quasi-Kaiser window by taking its FFT, and using the bottom few values of the output as the coefficients for a convolved version. It works as well (or as badly) as could be expected. As we are in fact very happy with how the Hann window works (and found a few other choices that work as well, but not obviously better), it is not something we have pursued. I would be delighted if someone was sufficiently interested to investigate that aspect further. Richard Dobson
On 15 Apr, 20:36, jim <"sjedgingN0Sp"@m@mwt,net> wrote:
> Rune Allnor wrote: > > > Only when you know what you aim to achieve, can you > > start discussing how to go about achieving it. > > Right. So why do you keep insisting one method is better than another > when you don't what the aim is?
Read my posts again, and try to see if you can discover where I: 1) Explain what uses for window function I am aware of 2) Explain why I think the frequency-domain computation approach is a) irrelevant b) plain wrong for those uses 3) Asks for anyone who knows something I don't, to enlighten me. To rip off a quotation Dale offered earlier on: Those who don&#4294967295;t read are no better off than those who can&#4294967295;t. &#4294967295; Mark Twain Unlike Dale, who apparently writes for merely literate readers, judging from this quote, I aim a bit higher. For *intelligent* readers. In vain, it seems. Rune
Rune Allnor wrote:
> > On 15 Apr, 20:36, jim <"sjedgingN0Sp"@m@mwt,net> wrote: > > Rune Allnor wrote: > > > > > Only when you know what you aim to achieve, can you > > > start discussing how to go about achieving it. > > > > Right. So why do you keep insisting one method is better than another > > when you don't what the aim is? > > Read my posts again, and try to see if you can discover > where I: > > 1) Explain what uses for window function I am aware of
> 2) Explain why I think the frequency-domain computation > approach is > a) irrelevant > b) plain wrong
Then you are saying that using the Hann window is irrelevant and plain wrong. For all I know, the OP's purpose is to determine if that is true.
> for those uses > 3) Asks for anyone who knows something I don't, to enlighten > me. >
The Op made it clear it is trivial to implement the window function in the frequency domain, but more work than he cares to do in the time domain. How many times does something need to be explained before you become enlightened. -jim
> To rip off a quotation Dale offered earlier on: > > Those who don&#4294967295;t read are no better off than those who can&#4294967295;t. > &#4294967295; Mark Twain > > Unlike Dale, who apparently writes for merely literate > readers, judging from this quote, I aim a bit higher. > For *intelligent* readers. In vain, it seems. > > Rune
On Apr 15, 12:43 pm, Rune Allnor <all...@tele.ntnu.no> wrote:
>... > > Unlike Dale, who apparently writes for merely literate > readers, judging from this quote, I aim a bit higher. > For *intelligent* readers. In vain, it seems. > > Rune
Rune The reasons to cite a reference on usenet include: 1) Providing a reviewed, readily available source. 2) Providing a media with equations and figures. 3) Providing a basis in established terminology. 4) Avoiding an error prone restart from scratch to explain topics that have long since been documented and reduced to effective practice. The cited portions of the harris paper serve these purposes with regard to the topic of this thread. I'm happy to settle for writing for those who do read. They won't be mislead by errors about frequency kernel size, limited by your unfamiliarity with windows applications or confused by the repeated denial of the presence of material posted in this thread. Dale B. Dalrymple
On 16 Apr, 05:10, dbd <d...@ieee.org> wrote:
> On Apr 15, 12:43 pm, Rune Allnor <all...@tele.ntnu.no> wrote: > > >... > > > Unlike Dale, who apparently writes for merely literate > > readers, judging from this quote, I aim a bit higher. > > For *intelligent* readers. In vain, it seems. > > > Rune > > Rune > > The reasons to cite a reference on usenet include: > > 1) Providing a reviewed, readily available source.
Obtaining the paper requires access to IEEE archives. You have in previous posts presented the view that paying $10-$15 to get that access is a neglectable issue. I happen to disagree. Could you please, for the benefit of those who don't have access to the paper through IEEE archives, give a short summary of why it is worth $10-$15 to read about these N-period windows, and why they are relevant in contemporary applications?
Where? Through IEEE archives one must pay to get access to?
> 3) Providing a basis in established terminology. > > 4) Avoiding an error prone restart from scratch to explain topics that > have long since been documented and reduced to effective practice.
If this is true, that these N-period windows indeed have been "reduced to effective practice" there should be no problems coming up with a quick, comprehensable explanation about why, and what their purpose are?
> The cited portions of the harris paper serve these purposes with > regard to the topic of this thread.
I have to disagree.
> I'm happy to settle for writing for those who do read. They won't be > mislead by errors about frequency kernel size, limited by your > unfamiliarity with windows applications or confused by the repeated > denial of the presence of material posted in this thread.
This might come as a surprise to you, but I actually try to learn something. Either by DSP or the human psychology. I never stop being amazed by the lengths people go to, to avoid answering even the simplest questions, when they either have no answers or are plain wrong. Say 'hi' to harris from me next time you see him. Rune
Rune Allnor wrote:
>> The reasons to cite a reference on usenet include: >> >> 1) Providing a reviewed, readily available source. > > Obtaining the paper requires access to IEEE archives. > You have in previous posts presented the view that > paying $10-$15 to get that access is a neglectable > issue. I happen to disagree. > > Could you please, for the benefit of those who don't > have access to the paper through IEEE archives, give > a short summary of why it is worth $10-$15 to read > about these N-period windows, and why they are relevant > in contemporary applications? >
Or, go to the bottom of this page: http://en.wikipedia.org/wiki/Window_function Find the link to the Harris paper, and download it. As it is scanned, some of the figs have lost definition; apart from that is is very readable. Richard Dobson
> > Ouch... I am not aware of a single application where > windows are applied in frequency domain... >
Hello Rune, Sometimes one defines a signal via a windowed frequency domain function. One example is the ghost cancellation reference used in analog television. This is a frequency chirp. See details here: http://www.claysturner.com/dsp/Analog%20GCR%20Details.pdf Clay
On 16 Apr, 17:12, c...@claysturner.com wrote:
> > Ouch... I am not aware of a single application where > > windows are applied in frequency domain... > > Hello Rune, > > Sometimes one defines a signal via a windowed frequency domain > function.
Sure. That's an obvious corollary to the idea that time-domain windowing for PSD estimation is an efficient way to implement frequency-domain weighted averages. Both Kay and Papoulis, two of the 'heavy' writers on statistical DSP, explain that windowing in time domain is a means to reduce the influence of the outer coefficients in the autocorrelation sequence, which have high variance. The difference might seem one of merely semantics, but the 'standard' texts on statistical DSP represent lobe widths and side lobe levels as very big problems. They are, if you restrict attention only to the 'classical' window functions. But as you point out, one can just as well design the desired frequency response and compute the desired time domain coefficients. But that's *design*. I still haven't seen any reason to do the *computations* in frequency domain. Rune
