A Puzzle for Today
Started by Tim Wescott April 5, 2009
You have a Very Large Number, expressed as an binary integer, in the
memory of a machine that allows for byte-wide operations.  For some
unfathomable reason, you need to determine if this number is evenly
divisible by 17.
Without using long division or repeated subtraction, and without ever
performing a multiply or divide on a number greater than eight bits long,
how can you determine if your number is divisible by 17?
Once you know this technique, what other potential divisors can you test
for using this method?
http://www.wescottdesign.com
Tim Wescott wrote:
> You have a Very Large Number, expressed as an binary integer, in the > memory of a machine that allows for byte-wide operations. For some > unfathomable reason, you need to determine if this number is evenly > divisible by 17. > > Without using long division or repeated subtraction, and without ever > performing a multiply or divide on a number greater than eight bits long, > how can you determine if your number is divisible by 17? > > Once you know this technique, what other potential divisors can you test > for using this method?
That's simple: X must be (a << 4) + a; check the lowest byte. The magic numbers are 2^n +/- 1 Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Express the bytes as hex pairs. Subtract each high digit from the corresponding low digit and add the result to a running sum. When the entire number has been processed, repeat the operation on the sum, iteratively until the sum is just one digit. The value of that digit is the original number mod 17. Add all digits instead of subtracting alternate ones. the result is the original number mod 15. In any base, the alternate difference of the digits yields N mod base+1, while the sum of the digits yields N mod base-1. Work in octal, and get divisibility by 7 and 9. I once proved it. Can you? Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
Perhaps you meant (a<<4) + a; good question for job interview. Here is the question I like: We have to transmit RS-232 by the AC coupled line. Hence the signal has to be DC balanced, i.e. have equal amount of ones and zeroes. How many bit combinations like that can be made of one byte? How about the general case of the block of N bytes? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Sun, 05 Apr 2009 19:55:32 -0400, Jerry Avins <jya@ieee.org> wrote:
>Tim Wescott wrote: >> You have a Very Large Number, expressed as an binary integer, in the >> memory of a machine that allows for byte-wide operations. For some >> unfathomable reason, you need to determine if this number is evenly >> divisible by 17. >> >> Without using long division or repeated subtraction, and without ever >> performing a multiply or divide on a number greater than eight bits long, >> how can you determine if your number is divisible by 17? >> >> Once you know this technique, what other potential divisors can you test >> for using this method? > >Express the bytes as hex pairs. Subtract each high digit from the >corresponding low digit and add the result to a running sum. When the >entire number has been processed, repeat the operation on the sum, >iteratively until the sum is just one digit. The value of that digit is >the original number mod 17. > >Add all digits instead of subtracting alternate ones. the result is the >original number mod 15. > >In any base, the alternate difference of the digits yields N mod base+1, >while the sum of the digits yields N mod base-1. > >Work in octal, and get divisibility by 7 and 9. > >I once proved it. Can you?
Yes. As you say it works on the same basis as proving divibility by 11 using base 10 notation. 0x0001 0x0000 + 0x0001 0x00 x 0x11 + 1 0x0010 0x0011 - 0x0001 0x01 x 0x11 - 1 0x0100 0x00FF + 0x0001 0x0F x 0x11 + 1 0x1000 0x0111 - 0x0001 0xF1 x 0x11 - 1 etc. A number is divisible by 17 iff the alternating sum of its hexadecimal digits is a multiple of 17. Jon
On Sun, 05 Apr 2009 19:01:43 -0500, Vladimir Vassilevsky
<antispam_bogus@hotmail.com> wrote:
>Tim Wescott wrote: > >> You have a Very Large Number, expressed as an binary integer, in the >> memory of a machine that allows for byte-wide operations. For some >> unfathomable reason, you need to determine if this number is evenly >> divisible by 17. > >Perhaps you meant (a<<4) + a; good question for job interview. > >Here is the question I like: > >We have to transmit RS-232 by the AC coupled line. Hence the signal has >to be DC balanced, i.e. have equal amount of ones and zeroes. How many >bit combinations like that can be made of one byte? How about the >general case of the block of N bytes?
If I gather that you can permit the entire 8 bit field to be out of balance so long as it comes out balanced on 8 bit boundaries, it's just combinatorial stuff. 70 ways to select 4 '1's out of 8 bits. (n!/[r!*(n-r!)]) The notation is usually just a big paren with n on top and r on bottom. Since this is RS-232 signaling I might also assume it's asynch, and then the start and stop bits plus the long mark times that may intervene between byte transmissions may need accounting for. But then you said it's not RS-232 signaling since it is AC coupled, which isn't RS-232 which specifies a DC path, so all bets are off. Jon
On Sun, 05 Apr 2009 19:55:32 -0400, Jerry Avins wrote:
> Tim Wescott wrote: >> You have a Very Large Number, expressed as an binary integer, in the >> memory of a machine that allows for byte-wide operations. For some >> unfathomable reason, you need to determine if this number is evenly >> divisible by 17. >> >> Without using long division or repeated subtraction, and without ever >> performing a multiply or divide on a number greater than eight bits >> long, how can you determine if your number is divisible by 17? >> >> Once you know this technique, what other potential divisors can you >> test for using this method? > > Express the bytes as hex pairs. Subtract each high digit from the > corresponding low digit and add the result to a running sum. When the > entire number has been processed, repeat the operation on the sum, > iteratively until the sum is just one digit. The value of that digit is > the original number mod 17. > > Add all digits instead of subtracting alternate ones. the result is the > original number mod 15. > > In any base, the alternate difference of the digits yields N mod base+1, > while the sum of the digits yields N mod base-1. > > Work in octal, and get divisibility by 7 and 9. > > I once proved it. Can you? > > Jerry
Wow. I didn't know about the N mod base+1 rule; I was thinking add all the bytes together (to get the number mod 255), then check the resulting one-byte number for divisibility by 17 ('cause 255 is 15 * 17). Live and learn. (but note that on my proposed machine, my method's probably faster because you don't have to shift and mask for 8-bit access the way you would for 4-bit access). I once proved the N mod base-1 rule, but I can't remember the details; I'm going to look at Jon's proof. -- http://www.wescottdesign.com
On Mon, 06 Apr 2009 04:00:15 +0000, Jon Kirwan wrote:
> On Sun, 05 Apr 2009 19:01:43 -0500, Vladimir Vassilevsky > <antispam_bogus@hotmail.com> wrote: > >>Tim Wescott wrote: >> >>> You have a Very Large Number, expressed as an binary integer, in the >>> memory of a machine that allows for byte-wide operations. For some >>> unfathomable reason, you need to determine if this number is evenly >>> divisible by 17. >> >>Perhaps you meant (a<<4) + a; good question for job interview. >> >>Here is the question I like: >> >>We have to transmit RS-232 by the AC coupled line. Hence the signal has >>to be DC balanced, i.e. have equal amount of ones and zeroes. How many >>bit combinations like that can be made of one byte? How about the >>general case of the block of N bytes? > > If I gather that you can permit the entire 8 bit field to be out of > balance so long as it comes out balanced on 8 bit boundaries, it's just > combinatorial stuff. 70 ways to select 4 '1's out of 8 bits. > (n!/[r!*(n-r!)]) The notation is usually just a big paren with n on top > and r on bottom. > > Since this is RS-232 signaling I might also assume it's asynch, and then > the start and stop bits plus the long mark times that may intervene > between byte transmissions may need accounting for. But then you said > it's not RS-232 signaling since it is AC coupled, which isn't RS-232 > which specifies a DC path, so all bets are off. > > Jon
If both start and stop bits are one long they'll balance; you'll be left with just needing to balance your data. If you could allow one bit of imbalance either way you could have 156 combinations; that's gotta be better. -- http://www.wescottdesign.com
On Mon, 06 Apr 2009 03:58:15 GMT, Jon Kirwan
<jonk@infinitefactors.org> wrote:
>0x0001 0x0000 + 0x0001 0x00 x 0x11 + 1 >0x0010 0x0011 - 0x0001 0x01 x 0x11 - 1 >0x0100 0x00FF + 0x0001 0x0F x 0x11 + 1 >0x1000 0x0111 - 0x0001 0xF1 x 0x11 - 1
^^^^^^ woops...
>0x1000 0x1001 - 0x0001 0xF1 x 0x11 - 1
Typo thing easily seen and fixed. Sorry about that. Jon
Vladimir Vassilevsky wrote:
> We have to transmit RS-232 by the AC coupled line. Hence the signal has > to be DC balanced, i.e. have equal amount of ones and zeroes. How many > bit combinations like that can be made of one byte? How about the > general case of the block of N bytes?
This is an interesting problem from a mathematical point of view. I'm a programmer, so I have hacked a small program (see below), which calculates it for n bits, because this was faster and more safe than when I try to derive it mathematically. Then I searched the sequence at NJAS and found this one: http://www.research.att.com/~njas/sequences/A000984 So for N bytes there are (8*N)!/((4*N)!)^2 possible combinations. For practical reasons (would be bad to have 10 bytes with 0 and 10 bytes with 0xff) I would simply use some standard bi-phase encoding, like AES-3 or Manchester. (loop for bit from 1 to 24 with number = 2 do (loop for i to (1- number) with test = 0 finally (format t "~a ~a~%" bit test) do (loop for j to bit with sum = 0 and b = i finally (when (= sum (/ bit 2)) (incf test)) do (when (= (logand b 1) 1) (incf sum)) (setf b (truncate b 2)))) (setf number (* 2 number))) -- Frank Buss, fb@frank-buss.de http://www.frank-buss.de, http://www.it4-systems.de
