60 GHZ uncompressed transmission
Started by fawzy ●April 9, 2009
Dear Sir;
A new technique in a multimedia transmission is transmitting a video
without compression on 60 GHZ unlicensed band.
It uses image partitioning.
I need some information about this image partitioning.
Regards
Eng. Fawzy
On Apr 9, 10:43&#4294967295;am, "fawzy" <ahmed.f...@gmail.com> wrote:
> Dear Sir; > > A new technique in a multimedia transmission is transmitting a video > without compression on 60 GHZ unlicensed band. > It uses image partitioning. > > I need some information about this image partitioning. > > Regards > Eng. Fawzy
It is undoubtably in the spec. See an article here about the spec being released. http://eetimes.eu/showArticle.jhtml?articleID=205207647 I would start a search using the info from this article. Clay
>On Apr 9, 10:43=A0am, "fawzy" <ahmed.f...@gmail.com> wrote: >> Dear Sir; >> >> A new technique in a multimedia transmission is transmitting a video >> without compression on 60 GHZ unlicensed band. >> It uses image partitioning. >> >> I need some information about this image partitioning. >> >> Regards >> Eng. Fawzy > >It is undoubtably in the spec. See an article here about the spec >being released. > >http://eetimes.eu/showArticle.jhtml?articleID=3D205207647 > >I would start a search using the info from this article. > >Clay >
Plz, can you check the link. The page Not Found. please resend it
On Apr 10, 4:16&#4294967295;am, "fawzy" <ahmed.f...@gmail.com> wrote:
> >On Apr 9, 10:43=A0am, "fawzy" <ahmed.f...@gmail.com> wrote: > >> Dear Sir; > > >> A new technique in a multimedia transmission is transmitting a video > >> without compression on 60 GHZ unlicensed band. > >> It uses image partitioning. > > >> I need some information about this image partitioning. > > >> Regards > >> Eng. Fawzy > > >It is undoubtably in the spec. See an article here about the spec > >being released. > > >http://eetimes.eu/showArticle.jhtml?articleID=3D205207647 > > >I would start a search using the info from this article. > > >Clay > > Plz, can you check the link. > The page Not Found. > please resend it > >
That link works for me. Plz, can you check your internet connection.
julius wrote:
> On Apr 10, 4:16 am, "fawzy" <ahmed.f...@gmail.com> wrote: >>> On Apr 9, 10:43=A0am, "fawzy" <ahmed.f...@gmail.com> wrote: >>>> Dear Sir; >>>> A new technique in a multimedia transmission is transmitting a video >>>> without compression on 60 GHZ unlicensed band. >>>> It uses image partitioning. >>>> I need some information about this image partitioning. >>>> Regards >>>> Eng. Fawzy >>> It is undoubtably in the spec. See an article here about the spec >>> being released. >>> http://eetimes.eu/showArticle.jhtml?articleID=3D205207647 >>> I would start a search using the info from this article. >>> Clay >> Plz, can you check the link. >> The page Not Found. >> please resend it >> >> > > That link works for me. Plz, can you check your internet connection.
I get a nice-looking page from /EE Europe/ that states that the requested page is unavailable. When Christopher Robin hit Pooh instead of the balloon, and asked if he had missed, Pooh answered, "You missed the balloon". Did you read the page that worked for you? Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Try clicking Clays original link instead of the one that the OP added a
mystery '3D' to.
HTH., Syms.
Symon wrote:
> Try clicking Clays original link instead of the one that the OP added a > mystery '3D' to. > HTH., Syms.
Ah! 3D is HEX ASCII for '='. The first sentence in the text is "... finalized its first specification for high-definition baseband video transmission at 60GHz." Baseband at 60GHz? how high is the definition? Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
The link is:
Anyhow; i don't want an article.
I need a technical specifications about this technique, and specially with
data partitioning.
On Apr 10, 5:40&#4294967295;pm, "fawzy" <ahmed.f...@gmail.com> wrote:
> The link is: > > http://eetimes.eu/showArticle.jhtml?articleID=205207647 > > Anyhow; i don't want an article. > I need a technical specifications about this technique, and specially with > data partitioning.
Then I repeat what I stated - read the spec!!!!
>On Apr 10, 5:40=A0pm, "fawzy" <ahmed.f...@gmail.com> wrote: >> The link is: >> >> http://eetimes.eu/showArticle.jhtml?articleID=3D205207647 >> >> Anyhow; i don't want an article. >> I need a technical specifications about this technique, and specially
wit=
>h >> data partitioning. > >Then I repeat what I stated - read the spec!!!! >
This Specs is not professional for my work, i need more more details
